Old 01-22-2014, 05:59 PM   #211
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
Originally Posted by sure74 View Post
I mounted a Rydeen Duo (ZH07-150B) in the stock rear view camera location on a BRZ Limited.
Enjoy
Originally Posted by Foobar View Post
I've seen the Duo sell for around $140.
As far as cost = picture quality, for these cameras, picture quality is actually the least part of the cost. Even a $12 camera produces a great picture on our head unit. Most of the cost goes into the size and quality of the housing. A $12 camera is going to end up with moisture in it and will fail quickly.
I have both a $12 camera and a $115 camera. Can't tell the difference between the video quality, but one's plastic, big, and had moisture fogging up the lens after being exposed to the elements. The other's metal, slim, and has endured rainstorms and my pressure washer without a problem.
Thanks.
Hard to see in the picture but they are there.
Like I mentioned, it isn't hooked up yet. I tested it on my kitchen TV to be sure it works and that the lines were deleted.
Thanks.
139.00 for the camera via eBay
21.80 for the RCA w\pins from SVXdc (also got the ground wire)
160.80 total
Agreed. I feel like it was worth the money just based on how it looks. As long as I don't run over any toys when backing out of the garage and I never have to swap it out I will be happy.
Originally Posted by xcelir8brz View Post
You did exactly what I was planning on doing with my BOYO that I'm waiting to receive from Amazon. Looks great!
What is everyone's opinion on this camera
http://www.ebay.ca/itm/Car-Rear-View...ef44e4f&_uhb=1
I know it's a $20 one and like foobar said it's made of plastic probably and might fail. Aside from quality issue, will connecting it to the deck be the same? Back to the quality issue, is there a way to fix the moisture issue. Like opening it up and adding like rubber or film or other sorts to help combat that moisture issue?
Thanks!
joergasm is offline   Reply With Quote
Old 02-24-2014, 12:37 PM   #212
zinzan
zinzan's Avatar
Drives: Subaru BRZ 2014 Limited WRB
Quick question--the trunk trim/fascia that needs a 5/16" hole drilled--is that made of plastic or sheet metal? I'm not near my car at the moment, but was going to stop by and get a drill bit, and want to make sure I get the proper one.
Thanks,
-Z
zinzan is offline   Reply With Quote
Old 02-24-2014, 12:49 PM   #213
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
Plastic
sure74 is offline   Reply With Quote
Old 02-24-2014, 03:51 PM   #214
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
had my rydeen about a year now...after this winter ALL paint peeled off on it, anyone have the same issues? its bare metal now, very annoying.
-ivan
Jive Turkey is offline   Reply With Quote
Old 02-24-2014, 03:58 PM   #215
sure74
sure74's Avatar
My camera was on for last winter but car hasn't seen snow at all this year. Paint on the camera is fine.
Old 02-25-2014, 06:44 PM   #216
Monoman
Drives: '13 BRZ - SWP
Anyone ordered recently? I emailed 96svx.dc a couple of days ago but haven't heard back yet. Do they take a few days to reply typically?
Monoman is offline   Reply With Quote
Old 02-25-2014, 10:36 PM   #217
Monoman
Update: quote received. Order placed.
Old 02-25-2014, 11:53 PM   #218
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
-ivan
I had mine for about 8 months, the paint is still good.
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
Old 03-18-2014, 04:47 PM   #219
BRZprime
Drives: 2013 Subaru BRZ
Has anyone tried installing the duo directly into the license plate hole? Is this at all possible without drilling?
BRZprime is offline   Reply With Quote
Old 03-18-2014, 08:42 PM   #220
Driften
Driften's Avatar
Drives: 2014 BRZ Limited, 2010 Forester XT
Originally Posted by davesbrz View Post
Okay - did it. Pic below shows the painted Rydeen duo mounted on a SWP BRZ limited.
Cool.... I was thinking about the Duo for my SWP BRZ Limited and was thinking black sure would draw attention where white would blend in better....
Driften is offline   Reply With Quote
Old 03-18-2014, 09:57 PM   #221
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
thats exactly how the beatsonic cam installs, just pull the plastic insert out behind the plate, where the plate screw would go into, then fish wires through hole in liscence plate / hole in trunk / put the camera in its place and bolt securely from the back with a washer. No Drilling required.
It Is ESSENTIAL that you order/purchase the correct model camera though that is meant to be mounted "upside down" or the pic on your screen will be flipped upside down.
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 03-20-2014, 02:40 PM   #222
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
Hey y'all,
I've seen a couple people with this install have their little "guide" lines off-center due to the mounting point of the camera. I am confident this would drive me up the fucking wall. Can the guide lines (green, yellow, red) be set up by the user?
XanRules is offline   Reply With Quote
Old 03-20-2014, 03:09 PM   #223
sshole
Originally Posted by XanRules View Post
Hey y'all,
Guide lines are set in the headunit. Hold down all 3 hard buttons on the headunit at once to get into the system diagnostics menu and click your way to camera settings. It's in there somewhere and will allow you to move the lines left/right/up/down or curve left/curve right. There should also be a guide somewhere on the forum with pictures of what I just described.
sshole is offline   Reply With Quote
Old 03-20-2014, 03:10 PM   #224
sshole
-ivan
Only thing I've noticed on mine is the ring around the lens has gone all funky rainbow colored, like it's covered in a thin film of oil.
DGM BRZ limited on the way? Coheed Member's Car Journals 16 04-11-2013 03:09 AM
My LR BRZ Limited epson1 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-08-2012 03:18 PM
BRZ Limited Available JohnATL Southeast 3 08-12-2012 12:32 PM
Want to buy a BRZ Limited AT kgc Northwest 1 06-17-2012 12:45 AM
DGM BRZ Limited (man) available Mitchs_86 BRZ First-Gen (2012+) — General Topics 6 06-14-2012 01:50 PM
