JonMotoring
Old 02-23-2014, 01:01 PM   #21659
nelsmar
Originally Posted by Doctor Who View Post
Can any OFT gurus chime in on my log? Its been about 2 weeks since I flashed v1.55 stage 1 and the car feels great but my mpg avg has dropped significantly, leading me to believe the tune could be excessively rich. I definitely tend to drive in a more exuberant manner then before the OFT, so this could also be the reason...Also, I've read that on 91 oct it is normal for the adv multiplier to fluctuate but 0.59 seems really low...Basically does everything look OK and do I have anything to worry about? Only engine mods are perrin inlet tube and perrin drop-in filter.
3rd gear WOT pull:
http://www.datazap.me/u/rbutler33/3r...log=0&data=1-9
Your maf may need to be rescaled for the perrin inlet tube. Your log looks not so wonderful. Your running an entire AFR point rich on the top end, and a 0.59 IAM is not something you should have. Shiv's maps are supposed to be made for 91 octane, so you shouldn't have IAM dropping. This means you have had multiple knock events.
The maf scaling in shiv's OTS seems to mostly match up with the OEM intake and if otherwise modified it can be skewed.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
SirBrass (02-23-2014)
Old 02-23-2014, 01:06 PM   #21660
nelsmar
Also you don't need an OFT guru, you just need any general tuner that can look at your logs. :P
The Following 2 Users Say Thank You to nelsmar For This Useful Post:
Doctor Who (02-23-2014), SirBrass (02-23-2014)
Old 02-23-2014, 02:57 PM   #21661
Cross
It's the Mad Cow
Cross's Avatar
3rd gear WOT pull:
Alright tell me what mods do you have, I see nelsmar mentioned a Perrin Intake anything else? Are you running E85 (I am guesing not) or Stage x Gas?
Are you just using the feature where the OFT builds the maps for you or did you make any changes yourself?
Old 02-23-2014, 04:28 PM   #21662
nelsmar
Im in his passenger seat right now. OTS 1.55 map. Perrin tube & filter no other mods. Lots of timing being pulled especially up top... 91 octane... =x
Old 02-23-2014, 04:32 PM   #21663
Shad0ez
Shad0ez's Avatar
Drives: 2013 Raven Black
Sounds just like the same issue I had with the OTS map prior to 1.55 being opened. Oddly enough, after switching to 1.55, things seem to be running smooth.
Shad0ez is offline   Reply With Quote
Old 02-23-2014, 05:09 PM   #21664
Cross
It's the Mad Cow
Cross's Avatar
Hmm so Stage 1 or Stage 2, should be Stage 1. If nelsmar is on it he will take care of you, but it does sound like you either got bad gas or there is another issue, a .78 or above I would say tune correction but at your level something else is up.
The 1.55 is an interesting update, for me and a few others I have spoken with we have seen some strange behavior that changes over time. I keep going back and forth between the 1.42 and 1.55B.
Old 02-23-2014, 06:04 PM   #21665
Cross
It's the Mad Cow
Cross's Avatar
So while I was working on a few additions to the FRS I found that the sway bars were well... bendable with my thumbs... So I just ordered a Sway Bar set for it 20.6mm in Front 17.5mm in the Rear both solid with Poly Bushings.
I then happened upon a set of Fog Lights with everything for under 90 shipped.... so I bought those too lol.
Back to installing the new LCA's though (been waiting for the black paint to dry), then to get the car aligned tomorrow and I put the modified front snorkel on.
Old 02-23-2014, 06:04 PM   #21666
nelsmar
Stage 1... timing was pretty aggressive. Had to pull almost 5 degree's in the top end. Looks like it may not be bad gas =x
Old 02-23-2014, 07:27 PM   #21667
beastinator
beastinator's Avatar
Drives: 2014 WRB BRZ
I was officially spotted by @Bonks86 at Frys today in Chandler. My first "Spotted" card!
beastinator is offline   Reply With Quote
The Following 2 Users Say Thank You to beastinator For This Useful Post:
Bonks86 (02-23-2014), thesleeper (02-24-2014)
Old 02-23-2014, 07:31 PM   #21668
kavanagh
Fat on Corn Syrup
Detailed and debadged her. That dealer sticker was the worst, but I told them I'd leave it on for two months (friends of the family). And after it was gone, decided to pull the FRS badge too.
And my buddy and I took turns driving each other's cars. His is a 2013 M3. He loves our auto in manual mode (as do we).
To quote him, "it's amazing how much your car is just like mine. The power is at the same rpms and the shifting response with the paddles is sooooo fast. I LOVE that downshift autoblip"
The Following 3 Users Say Thank You to kavanagh For This Useful Post:
brenesk91 (02-23-2014), jeffsides (02-24-2014), SirBrass (02-23-2014)
Old 02-23-2014, 07:40 PM   #21669
Doctor Who
Equinsu Ocha
Doctor Who's Avatar
Drives: SWP BRZ Limited
Huge shoutout to @nelsmar for helping a brother out! Things look to be ironed out but I'll be keeping a close eye and logging my progress from now on. Now, if we can only figure out a way to cut down on the ~7min flash time...
Doctor Who is offline   Reply With Quote
The Following User Says Thank You to Doctor Who For This Useful Post:
Pizzman (02-24-2014)
Old 02-23-2014, 07:51 PM   #21670
Cross
It's the Mad Cow
Cross's Avatar
Good to hear!
Old 02-23-2014, 11:47 PM   #21671
TwoFourFive
TwoFourFive's Avatar
Drives: 13 HOT LAVA
Anyone have any wheels for sale? looking for some wheels but not sure what to go with. Maybe some of you guys have any wheels your looking to get rid of thanks
TwoFourFive is offline   Reply With Quote
Old 02-23-2014, 11:50 PM   #21672
brenesk91
brenesk91's Avatar
Drives: 2013 SS BRZ
@Cross has his STR wheels for sale
brenesk91 is offline   Reply With Quote
The Following User Says Thank You to brenesk91 For This Useful Post:
Cross (02-23-2014)
