#15 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
![]() All I'm going to say.. Morimoto 6.0 retrofit |
| The Following 2 Users Say Thank You to Gixxersixxerman For This Useful Post: | retrosmiths (09-21-2013), STV3 (09-21-2013) |
#16 |
Drives: 2013 Scion FR-S Raven
The new 6.0 is so much sharper than the original morimotos I used last summer, very nice.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#17 |
Drives: Scion FR-S Whiteout
4300K bulbs?
2013 Scion FR-S
#18 |
#19 |
I want to try 4300k but I don't want to lose the colorful cutoff. Any updates on those 6.0 adapters btw?
2013 Scion FR-S
#20 |
#RememberTheBuster
Drives: Firestorm FRS MT
don't know about the projectors itself, but I can tell you TRS has exceptional customer service. I had a bad relay that was sent to me with the harness and they replaced it no questions asked. They even help troubleshoot and isolate a problem if you do have one, and will correct it as well. I've bought from them many times and will continue to do so.
#21 |
Custom User Title
Drives: Asphalt FR-S MT
@Gixxersixxerman
Do our stock type low beam bulbs fit, or would I have to get new bulbs? These are the projectors by themselves. They come with "optional" shrouds. Will the stock shroud not work?
#22 | |
Drives: 2015 Series.Blue
You want these: http://www.theretrofitsource.com/com...l#.UwgvdouYaUk They come with application specific mounting brackets that make the kit bolt in. Stock bulbs will not fit. |
| The Following User Says Thank You to Poodles For This Useful Post: | boredom.is.me (02-22-2014) |
#23 |
Custom User Title
Thanks @Poodles
I'm currently running an HID kit from HID Powerhouse. Anything wrong with reusing the Platinum R ballast? I would get the XB35 bulbs.
#24 |
Drives: White
If your ballast has standard AMP connectors, I'd go ahead and give them a shot.
| The Following User Says Thank You to speedrye For This Useful Post: | boredom.is.me (02-22-2014) |
#26 |
Question for those who did the retrofit with the 6.0 does the bi-xenon setup affect the DRL? Pics of how it was wired?
Sent from my Nexus 5 using Tapatalk |
#27 |
Ridge Racerrrrrrrrr
Yes.
| DIY: TheRetrofitSource/Morimoto Retro-Quik Install in FR-S | civicdrivr | DIY (Do-It-Yourself) Guides | 236 | 07-10-2017 01:04 AM |
| Morimoto Retro-Quik Xenon Retrofit System for FR-S | Xenocide117 | Cosmetic Modification (Interior/Exterior/Lighting) | 63 | 07-18-2014 08:37 PM |
| Help Morimoto HID kit | Jacob G. | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 02-18-2013 03:03 AM |
| DRL and Morimoto Retro-Quik Xenon Retrofit System | denverizzles | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 09-07-2012 11:46 AM |
| Any chance of a group-buy on TRFS Morimoto Retro-Quik? | SkAsphalt | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-20-2012 02:06 PM |
