Old 09-21-2013, 12:13 AM   #15
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
All I'm going to say.. Morimoto 6.0 retrofit
Gixxersixxerman is offline   Reply With Quote
The Following 2 Users Say Thank You to Gixxersixxerman For This Useful Post:
retrosmiths (09-21-2013), STV3 (09-21-2013)
Old 09-21-2013, 10:21 AM   #16
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
The new 6.0 is so much sharper than the original morimotos I used last summer, very nice.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-21-2013, 09:42 PM   #17
retrosmiths
Drives: Scion FR-S Whiteout
4300K bulbs?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 09-21-2013, 09:48 PM   #18
Gixxersixxerman
Originally Posted by retrosmiths View Post
4300K bulbs?
5K... All I'll run with.. Anything more and I start to lose my depth.. I have never tried 4300 but was thinking of picking up a set of XB35 H1 bulbs in 4300 and 5K to see which I like better
Old 09-21-2013, 10:52 PM   #19
retrosmiths
I want to try 4300k but I don't want to lose the colorful cutoff. Any updates on those 6.0 adapters btw?
2013 Scion FR-S
Old 09-22-2013, 09:14 AM   #20
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
don't know about the projectors itself, but I can tell you TRS has exceptional customer service. I had a bad relay that was sent to me with the harness and they replaced it no questions asked. They even help troubleshoot and isolate a problem if you do have one, and will correct it as well. I've bought from them many times and will continue to do so.
Enraged21 is offline   Reply With Quote
Old 02-21-2014, 11:42 PM   #21
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
@Gixxersixxerman
Do our stock type low beam bulbs fit, or would I have to get new bulbs? These are the projectors by themselves. They come with "optional" shrouds. Will the stock shroud not work?
Old 02-22-2014, 12:03 AM   #22
Poodles
Drives: 2015 Series.Blue
Originally Posted by boredom.is.me View Post
@Gixxersixxerman
You want these: http://www.theretrofitsource.com/com...l#.UwgvdouYaUk
They come with application specific mounting brackets that make the kit bolt in. Stock bulbs will not fit.
The Following User Says Thank You to Poodles For This Useful Post:
boredom.is.me (02-22-2014)
Old 02-22-2014, 12:24 AM   #23
boredom.is.me
Custom User Title
Thanks @Poodles
I'm currently running an HID kit from HID Powerhouse. Anything wrong with reusing the Platinum R ballast? I would get the XB35 bulbs.
Old 02-22-2014, 06:20 AM   #24
speedrye
Drives: White
If your ballast has standard AMP connectors, I'd go ahead and give them a shot.
speedrye is offline   Reply With Quote
The Following User Says Thank You to speedrye For This Useful Post:
Old 02-22-2014, 10:22 AM   #25
boredom.is.me
Custom User Title
Sweet thanks guys.
Old 04-23-2014, 12:43 PM   #26
Rican_D
Rican_D's Avatar
Question for those who did the retrofit with the 6.0 does the bi-xenon setup affect the DRL? Pics of how it was wired?
Rican_D is offline   Reply With Quote
Old 04-23-2014, 01:45 PM   #27
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Yes.
DIY: TheRetrofitSource/Morimoto Retro-Quik Install in FR-S civicdrivr DIY (Do-It-Yourself) Guides 236 07-10-2017 12:04 AM
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 07:37 PM
Help Morimoto HID kit Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 4 02-18-2013 02:03 AM
DRL and Morimoto Retro-Quik Xenon Retrofit System denverizzles Cosmetic Modification (Interior/Exterior/Lighting) 1 09-07-2012 10:46 AM
Any chance of a group-buy on TRFS Morimoto Retro-Quik? SkAsphalt Cosmetic Modification (Interior/Exterior/Lighting) 2 07-20-2012 01:06 PM
