#15 |
Drives: BRZ Club blanc perle
Saw the same problem.
Watch the low det or high det map : that was accurate to the high det as my AM was 1 ! Seems that it doesn't care of AM much... |
#16 | |
Drives: UK GT86
I've noticed there is logging available for intake and exhaust VVT #1 & 2 and commanded values for them as well. I wonder if #1 and 2 are the different banks? I guess a log of everything might help.
.: Stealth 86 :.
#17 |
Drives: 2013 Asphalt FR-S
Range of adjustment on the intake cam in the rom is from -10 to 40, -10 is max retard, 40 is max advance. On the exhaust cam 0 is max advance 50 is max retard.
~Namaste~ |
#18 | |
Drives: UK GT86
@mad_sb the map range is correct, but what angle does the cam sit physically when the map is at 0?
.: Stealth 86 :.
#19 |
Drives: UK GT86
Right, I thought I'd collate some better info. I'm comparing the OFT v1.55 maps and stock. This is based on base cam timing (map value of 0):
Exhaust opens 81 deg. BBDC and closes 9 deg BTDC Intake opens 14 deg ATDC and closes 89 deg ABDC Note - these base timing may be incorrect. I'll update if I get any confirmed information. This means that the overlap is an indicator in what the map is doing. Negative figures in the overlap table show the range between closing of the exhaust valve and opening of the intake valve. I did this to show if there is any relationship even if the individual cam timings are being changed. The graphs are WOT timing. It's worth noting that this is for N/A applications. F/I requires a different approach, even turbo and S/C are different due to the timing affecting turbo spool up. ![]() ![]() ![]() ![]()
.: Stealth 86 :.
Abbey Motorsport/K47 Tuned Sprintex 210 Supercharger Kodename 47 DJ: Soundcloud / Instagram / Facebook Last edited by Kodename47; 02-18-2014 at 05:30 AM. |
#20 |
Drives: car
Thanks for putting those charts together. I'm having some trouble understanding the exhaust opening timing in degrees BBDC. Looking at the stock timing: So with the 800rpm row, the phasing is set to 0. Shouldn't the opening timing be 81 in your map instead of 31? and then at 2400 full load, the phasing is 50. So shouldn't it be 31 degrees BBDC opening?
The exhaust opening timing is retarded (fewer degrees before bottom dead center) for greater expansion ratio. The exhaust closing timing would at the same time be retarded for more overlap or for more evacuation of exhaust gases. |
#21 | |
Drives: UK GT86
Edit - Pics updated
.: Stealth 86 :.
Abbey Motorsport/K47 Tuned Sprintex 210 Supercharger Kodename 47 DJ: Soundcloud / Instagram / Facebook Last edited by Kodename47; 02-18-2014 at 02:08 PM. |
#22 |
Drives: UK GT86
Just stumbled upon another good discussion thread started by @Td-d:
http://igotasti.com/vBforum/archive/...hp/t-4616.html
.: Stealth 86 :.
Abbey Motorsport/K47 Tuned Sprintex 210 Supercharger Kodename 47 DJ: Soundcloud / Instagram / Facebook Last edited by Kodename47; 02-21-2014 at 09:10 AM. |
#23 | |
They prefer Virtual Dyno to monitor the changes on torque, power and load. I also find it more readable, instead of a VRE, too linked to MAF crappy signal... |
#24 |
Drives: 86
good
#25 |
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
The Virtual dyno sounds interesting. Anyone try that?
#26 |
Drives: 86
#27 |
Drives: Whiteout FR-S, Evo 8 RS
VDR is good if you have a baseline pull on the same stretch of road you plan on doing your tuning on. Of course atmospheric pressure and IAT temps will very the reading a bit, but its great!
#28 |
Calle Atun
I down loaded it I will check it out. At least I will have a better idea if my changes made more or less power.
| Timing chain issue? | Hardpack | Issues | Warranty | Recalls / TSB | 14 | 01-10-2016 11:25 PM |
| AVCS failures? | hmong337 | Forced Induction | 26 | 02-12-2015 03:01 PM |
| Stock Rom: Timing + Learn Value | sw20kosh | Software Tuning | 7 | 12-11-2013 07:09 PM |
| E85, Boost and Ignition Timing | jamesm | Software Tuning | 23 | 12-11-2013 02:19 PM |
| Timing belt shredded..?! | drei | CANADA | 5 | 12-06-2013 05:54 PM |
