Old 02-20-2014, 11:04 PM   #29
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by CSG David View Post
Just added WE1 to the website and GB thread. Don't you use CL6E for endurance though? I know CT RP2 and PMU Racing Sintered are comparable.
Yowza! I guess there is quite the premium for longevity.
Old 02-20-2014, 11:30 PM   #30
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Let's say first place gets $1,500, second gets $500. Is it worth an extra 5-10 minute pit stop?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
solidONE (02-21-2014)
Old 02-20-2014, 11:38 PM   #31
TOTO_86
TOTO_86's Avatar
Drives: Scion FR-S
I mostly care about the lifespan of them. The OEM didn't last for me, and I know it depends on how I drive. I've had 3 encounters on the freeway where I had to brake extra hard. Plus, I find that I get annoyed from the noise. I was also looking into the W1 because of the lifespan.
TOTO_86 is offline   Reply With Quote
Old 02-21-2014, 02:43 AM   #32
CSG David
CSG David's Avatar
Lifespan can be a function of how much you use your brakes because you're not getting nearly enough braking that you need. This causes you to ride your brakes a little more and thus, wear quicker. Honestly, W2 will probably work a little better for your application as it provides a little more sportiness, but yields close to OE characteristics. As with any performance pad, you will run into the possible situation of noise. Bed them in like a rockstar and you'll be perfectly fine. I mean I run full race pads on my daily driver that I use to commute all over socal and have no issues right now.
The Following User Says Thank You to CSG David For This Useful Post:
TOTO_86 (02-23-2014)
Old 02-21-2014, 02:45 AM   #33
CSG David
CSG David's Avatar
Standard sprint race pads will not last for endurance purposes. The compound makeup is different and gets "activated" in its optimal temperature range. Anything outside of that has poor bite and wear on both the pad and disc. That's basically what an endurance pad is. Oh...and they're noisy as hell like a truck trying to stop...
Old 02-21-2014, 03:24 AM   #34
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Sorry to hijack but I didn't want to create another thread just to ask these question:
1) What is the best way to bed-in new pads (say W1 or Stoptech SP) on a used disc? Discs are slotted, and in good condition since only recently installed.
2) Do I need to remove the old transfer layer?
3) What is the easiest way of removing this transfer layer?
4) Any negatives if I don't remove old transfer layer?
Fizz is offline   Reply With Quote
Old 02-21-2014, 04:19 AM   #35
CSG David
CSG David's Avatar
1. Like any brake pad, you will need to warm up the rotors properly and then do repeated quick deceleration from a decent velocity to a relatively slow velocity (close to stopping by still moving) without engaging ABS until you feel a hint a fade. After a good cool down without using your brakes, you can park the car and you should see a hint of color on the rotors as some indicator.
2. Not really.
3. Scotch brite, a track brake pad without using the brake pedal during cruising, or turning the rotor on the lathe.
4. Your pads may or may not wear as evenly and your brakes will not be in its "optimal" state. To be honest, all you really need to focus on is bedding your brake pads properly. We provide bed in instructions with our brake orders.
Fizz (02-21-2014)
Old 02-21-2014, 10:04 AM   #36
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The CLs aren't any noisier then their other pads. Every pad is loud on my BRZ.
<< all of my cars also run race pads all the time
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
CSG David (02-21-2014)
Old 02-21-2014, 10:28 AM   #37
OrbitalEllipses
Drives: Attitude
When ya put in yer new pads, drive around on 'em for a week (without hard braking) before you bed them in. This will accomplish number 3 and prevent any pad deposits (#4) that can cause vibrations in the pedal.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
CSG David (02-21-2014), Fizz (02-21-2014)
Old 02-21-2014, 11:30 AM   #38
Sargy
Long Distance Driver
Sargy's Avatar
Waiting for my W4s to be installed all around with Spiegler lines and RT700 fluid.
so far the front rotors have been resurfaced with the W4 front pads on and stock old fluid.
even with this I can notice the lack of bite compared to oem but the consitency and overall performance is simply amazing! (mind you the old fluid is 30k old so it wasnt consistent for long haha)
still need to resurface the rears, install rear pads and then flush out the old fluid and install the lines. should be interesting
and I have not heard any noise since properly bedding them in
Sargy is offline   Reply With Quote
Old 02-21-2014, 11:49 AM   #39
CSG David
CSG David's Avatar
The Winmax don't "bite" or "grab" hard when you get on the brakes. It's a whole different characteristic and requires you to change your braking style a little bit. What's nice is it teaches you how to be very smooth on the brakes.
The Following 3 Users Say Thank You to CSG David For This Useful Post:
HachirocksU (08-21-2019), Sargy (02-21-2014), solidONE (02-21-2014)
Old 02-21-2014, 06:06 PM   #40
solidONE
solidONE's Avatar
You got a point there.
So would you guys not recommend using endurance pads for sprint purposes? Even if noise is a non-issue? I figure I could be very deliberate on the warmup lap to put enough heat in them and the temps should be good for the rest of the laps. Good strategy or no?
Old 02-21-2014, 07:46 PM   #41
CSG David
CSG David's Avatar
From what I've seen, some guys have used the endurance pads on their cars and weren't too happy. While it may seem like it'll last longer, sometimes it may not work as well in your favor. You are free to try for TA, but we won't particular recommend that pad for standard HPDE or TA use.
Old 02-21-2014, 08:40 PM   #42
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
^^ Depends on the pad. I love the CL RC6Es. Some other endurance pads.. eh.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
CounterSpace Garage - Winmax USA Brake Pads Group Buy - EXTENDED!! CounterSpace Garage Groupbuys 21 01-28-2015 06:48 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
