Old 10-01-2013, 08:45 PM   #1
Nissanfan
Drives: subaru brz
Door speaker vibrations? Subaru BRZ
I don't know, if that's how it was, but after driving around in loaner Mazda 3 with bose, I started playing with audio adjustments. I usually play music loud, but decided to play around with bass etc setting. Went back to "preinstalled" profile, and seems like speakers vibrate in doors now. Kinda start to feel like an old car atmosphere when driving. Did anybody else experience that with stock setup?
2013 BRZ Limited 6speed Manual
Nissanfan is offline   Reply With Quote
Old 10-01-2013, 08:46 PM   #2
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
I have a limited. The driver side door speaker cover rattles like a mofo and drives me nuts...
Acree is offline   Reply With Quote
Old 10-01-2013, 09:17 PM   #3
Senzai
Drives: 2013 FR-S & 2011 TC
Remove the door panel and then the speaker grille. Remove the drivers door power window switch plate and fit some dynamat (or equivalent) between the door panel and lower door trim. I did two layers and this solved the rattle.
Senzai is offline   Reply With Quote
The Following 4 Users Say Thank You to Senzai For This Useful Post:
Calin (12-22-2013), charged86 (10-01-2013), JSUB (07-11-2014), Steve201brz (10-03-2013)
Old 02-20-2014, 04:48 PM   #4
DrivingEnthusiast86
Did your door switches rattle or the entire switch pad? It's occurring on both of my doors. The speaker covers seem to be fine.
DrivingEnthusiast86 is offline   Reply With Quote
Old 02-20-2014, 11:40 PM   #5
kodyo
Drives: Scion FR-S
It's the door switches for me. Stops when you put pressure on the plate, so I know it's that on mine.
kodyo is offline   Reply With Quote
Old 02-21-2014, 02:08 AM   #6
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
My audio install guy says that Lowe's sells a roofing product that accomplishes the same thing as dynamat for a lot cheaper. I haven't stopped yet to check it out, but I'm guessing it's this stuff:
http://www.lowes.com/pd_124018-81326-TS433_4294736327__?productId=1007825&Ns=p_product_ qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_produ ct_qty_sales_dollar%7C1&facetInfo=
or this
http://www.lowes.com/pd_236541-711-5003104_4294736327__?productId=3027049&Ns=p_produc t_qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_pro duct_qty_sales_dollar%7C1&facetInfo=
robwbright is offline   Reply With Quote
Old 02-21-2014, 12:52 PM   #7
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Mine buzzes when I always listen to AM talk sports radio… The guy's voice sometimes hits a frequency to makes it vibrate. Any idea what part of the speaker/grill is buzzing?
Old 02-22-2014, 07:53 AM   #8
kodyo
Drives: Scion FR-S
Same here, but I still think it is the window switches, not the grill.
Old 02-22-2014, 09:50 AM   #9
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Put dynamat or equivalent in all the nooks and crannies of the door and window switches. I did that along with silicon/caulking. It now takes a lot of bass to rattle anything. I had to remove and reinstall the door cards a few times to completely get rid of all the rattles but it's OH so worth it. One of my best "mod".
Rayme is offline   Reply With Quote
Old 02-22-2014, 11:55 AM   #10
White64Goat
This is probably more like it:
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
The Following User Says Thank You to White64Goat For This Useful Post:
robwbright (03-02-2014)
Old 02-24-2014, 02:02 PM   #11
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
mine does. Dealership fixed it by adding insulation on the panel. I can still hear it tho. looks like they need to add another layer.
jacjac3 is offline   Reply With Quote
Old 02-27-2014, 07:07 PM   #12
Hogue_caleb
Drives: 2014 scion frs (black)
I took mine in today with the same problem and they fixed it (for now) by adding a felt/ tape layer in between the window switch module and the plastic decorative piece it snaps into. Havent heard anything yet but im keeping my ears open.
Hogue_caleb is offline   Reply With Quote
Old 02-27-2014, 07:19 PM   #13
andrew20195
Drives: 2013 Subaru BRZ
Both of those products use asphault. I would strongly recommend against using them in your car. Long term you will have a huge mess.
IMO Dynamat is overpriced, but there are other brands of similar products that don't use asphault.
andrew20195 is offline   Reply With Quote
The Following User Says Thank You to andrew20195 For This Useful Post:
Old 03-01-2014, 04:10 PM   #14
kodyo
Drives: Scion FR-S
http://www.ft86club.com/forums/showt...?t=9676&page=2
Just took the door panel off to fix this. I used 3m tape and put it between all interfaces between the speaker-grill/window switches and the door. Also, the actual switches/box they sit in has some play, so put a little in there as well. Whole process took about 45 minutes. Hardest part for most will be removing door handle inserts, but mine where already off from previous project.
No more rattles, but waiting for a little cooler temps outside to be sure.
FRS door speaker vibration? hislargeness Electronics | Audio | NAV | Infotainment 12 08-19-2013 06:22 PM
Will sub remove door speaker rattle? ZionsWrath Electronics | Audio | NAV | Infotainment 18 08-11-2013 01:38 AM
Door speaker question BlackyRose Electronics | Audio | NAV | Infotainment 2 07-26-2013 11:45 PM
Door Speaker Vibration MattM232 Issues | Warranty | Recalls / TSB 16 03-19-2013 08:03 PM
Subaru Audio door speaker adapters JoeBoxer Audio/Visual, Electronics, Infotainment, NAV 0 12-17-2012 12:13 AM
