| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#2143 | |
KCCO
Drives: 2013 Raven Scion FR-S, AT
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/ |
#2144 | |
Drives: '13 BRZ Ltd WRB
You may gain a teeny bit of negative camber due to lowering on a Mac strut, but the only way the wheel will get closer to the suspension is with crash/camber bolts since the wheel is affixed to the strut. Now, with camber bolts in the lower holes, I was pretty damn close to the strut with 17x8 +48. Putting them in the upper holes would be even closer or touching. The rear suspension will gain much more negative camber upon lowering due to the upper/lower arm configuration. And since the shock is mounted to the LCA, the wheel WILL get closer to the suspension. Shouldn't be a problem back there, though, since there is so much more room.
| The Following User Says Thank You to 2point0 For This Useful Post: | Assunta (02-19-2014) |
#2145 | |
Drives: FR-S Firestorm 6MT
See here, especially page 2. http://www.ft86club.com/forums/showthread.php?t=30196 |
| The Following User Says Thank You to Slick For This Useful Post: | FLIPs_FR-S (02-11-2014) |
#2146 |
KCCO
Thanks a million @Slick. I am in the next few weeks purchasing forgestar cf5 18x9.5 +38 for all four corners. 245/35 18 potenza R760 tires all four corners too.
#2147 | |
Sorry for the delay, saw u already got the answer but yes if u lower u will see a little more camber (depending how much u lower u will NEED camber to bring the tops of the wheels inside the fenders or ull rub like crazy) and every bit of camber u add will bring the edge of the rim that much closer (unless u get coilovers) In the pic, green is the rim and the arrow is pointing to the spring perch (black), this is stock height stock camber Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to jshadeck For This Useful Post: | FLIPs_FR-S (02-14-2014) |
#2148 |
Wayward Member
Drives: Hot Lava 86
Okay, new question. Still the same 17x9 +45 wheels with 245/40 tires (8.2" tread width, so may go to the 255 for 9" tread, but only if that size doesn't rub.) but instead of lowering it on coils to make it fit, how about 10mm spacers? Effectively making it a +35 offset. It will probably poke a little, but that's okay. I think I could keep them from poking with a +40, but that would most likely rub.
#2149 |
It won't poke at +35. (poke is subjective though)
See my sig for pics and pretty much looks like jshadeck's car (rear fitment) at the top of the page too. Doesn't "look" like it sticks out much unless you put a ruler against it. 255 is a good size tire for the rim, ideal size actually. Won't rub with a +35 effective offset unless camber settings are way off. You should try to be between -1.5 and -2.5 all around. Last edited by Slick; 02-12-2014 at 06:48 PM. |
#2150 |
Drives: Whiteout FR-S
Sorry if something similar has been asked..
I have RS* Sports-i coil overs that I will install soon and 18x9.5 +40 Rays Gramlights 57C6 wheels on order. I don't think I will have a problem fitting these but I'm now looking for tires. I was thinking of getting 255/35/18 Michelin Pilot Super Sports but I keep reading that they run a bit wide. Will these fit? Thanks! |
#2151 | |
Tires will fit the rims with no issue. Your camber settings will determine if the outside sidewall rubs the fender or not, but the Michelins have more of a rounded profile so I don't see an issue, plus some folks have run 265's up front and even 275's.
| The Following User Says Thank You to Slick For This Useful Post: | Nsot (02-14-2014) |
#2152 |
Drives: Toyota Gt86
Hi guys. The xxr 522 in 18x8.5 measure what et they need for stay in safe fit (they can't stay out)
#2153 | |
Not sure I understand your question, what's best but won't stick out? Best offset for an 18x8.5 would be between +35 and +40. The +35 will give you more poke, the +40 will tuck in a bit more. Both should clear stock coils. |
#2154 |
Drives: 2003 FR-S
Need some help guys,
Will the wheels with 18x9 - 5x114.3 with offset 35 and 215/40/18 tires (all corners) will fit to my stock 2013 FR-S? Currently, the OEM wheels are 17 inch. With these specs, will the wheels tuck in or perfect flush with the fender? I am thinking putting the Eibach Pro-kit later. Thanks. |
#2155 | |
Here is what it looks like on stock springs, wheels were on for only 3 days before spring swap: ![]() And after the 1" drop on Eibach ProKit:
#2156 |
Oh wait, you said 5x114.3 bolt pattern? That's a no go.
You need 5x100 for this car. |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
