Old 11-23-2013, 12:13 AM   #43
Fast_Freddy
Drives: Passat
Originally Posted by Coheed View Post
The heat range code for these plugs is really cold already. I don't think it is necessary to change them, but you may want to remove them and gap them down a bit if you are experiencing spark issues with boost.
The oem plugs are matched to the specific requirements of the stock FA20 engine. Whether or not the plugs are colder or hotter than other plugs used in other engines is irrelevant. The important thing is that the increased combustion chamber temps caused by FI require a colder plug to compensate.
Fast_Freddy is offline   Reply With Quote
Old 11-23-2013, 12:44 AM   #44
lexusb3
Drives: FRS
I'm using stock plugs
lexusb3 is offline   Reply With Quote
The Following User Says Thank You to lexusb3 For This Useful Post:
hmong337 (02-19-2014)
Old 11-23-2013, 07:27 AM   #45
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Im using oem plugs too
Old 12-15-2013, 06:55 PM   #46
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Anyone having any detonation issues with the factory plugs yet?
I don't think we will see anyone having issues with the stock plugs on most FI setups, other than changing gap requirements.
The stock plugs are about as cold as you can get from NGK or Denso.
Coheed is offline   Reply With Quote
Old 12-15-2013, 09:21 PM   #47
Dan@AWD
Drives: 2013 Argento FR-S
No issues except when I burnt one from leaning out due fuel delivery issue.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Dan@AWD is offline   Reply With Quote
Old 02-19-2014, 07:42 AM   #48
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Need help.
Ive been advised to use one colder plugs for SC
Now investigating some are saying stock is 7 heat and some are saying 9 heat.
im looking at NGK plugs been advised to use these R2558A
Now do i use 8 heat or 10 heat
please help
Ryan86 is offline   Reply With Quote
Old 02-19-2014, 08:30 AM   #49
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Originally Posted by Ryan86 View Post
Need help.
please help
i don't think you need colder spark plugs from what i had research.
maybe the best can chime in @Sportsguy83 @King Tut @Ironsquid @jamesm
The Following User Says Thank You to whitefrs For This Useful Post:
Ryan86 (02-19-2014)
Old 02-19-2014, 09:40 AM   #50
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Need help.
please help
Solely depends on what PSI SC Pulley you have on. Normally in a lower compression motor, you don't go with colder plugs unless you're increasing VE to a point that 1 step colder plug will still ignite fuel but reduces knock chance.
That aside, I don't think I've heard anyone on the Turbo kits running colder plugs yet. I honestly don't think it's needed for street use. My recommendation is factory plugs. If your tuner is advising colder plugs because you are knocking a lot, I would maybe get a second opinion from another tuner.
@FullBlown what range plugs are you guys using on that 700+ hp project
Edit: I have a hard time answering this. My knowledge from lower compression turbo applications is telling me that 1 step colder plugs could be worth it and not cause much issue. Have to remember we're dealing with a new territory. If it was my car I would wait for others with proven track history to mention the effects of colder plugs on this application. I know I've seen people make huge power without pushing timing to the point you need colder plugs.
Ironsquid is offline   Reply With Quote
The Following User Says Thank You to Ironsquid For This Useful Post:
Ryan86 (02-19-2014)
Old 02-19-2014, 09:55 AM   #51
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I know nothing about spark plugs...but logically thinking about it, a colder setup I think will only be needed if your under consultant heated situations, like say at the track or drag strip or building a @FullBlown project. In *most* street applications the combustion temps are not high enough to warrent the switch to colder plugs. Even if someone is pushing ridiculous power, 500+ it's usually on E85 which has significant knock resistance in itself.
Old 02-19-2014, 10:04 AM   #52
arghx7
Drives: car
So is there a consensus on whether they are the equivalent of an NGK 9 or an NGK 7? NGK 7 is not uncommon on turbo engines for a stock plug--iirc the Evo 4B11T engine has a 7. 9 is very cold, and is only stock plugs on rotary engines (trailing plug) or engines that are not for passenger car applications (small engines).
Old 02-19-2014, 10:13 AM   #53
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Need help.
please help
I would stick with the OEM plugs. If you are having issues, then pull them out and check the gaps. If you are blowing out the spark, then close the gap up a little and put them back in.
Ryan86 (02-19-2014)
Old 02-19-2014, 10:21 AM   #54
jamesm
i'm on oem plugs. just gapped down a bit.
Old 02-19-2014, 05:19 PM   #55
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
What kind of boost/power are you making? I had a short discussion about this but the consensus was "fuck it".
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
Old 02-19-2014, 05:40 PM   #56
jamesm
hell i don't know, don't really care. i'm a drivability guy. the car makes more power than i can use. i have maps for 9.5, 11, 12.5, and 14 psi. it'll roast the tires on a 2-3 shift on dry pavement, if that means anything. i usually just drive around on the 9.5psi map.
last time it was on a dyno it made 259whp on a mustang @ ~8.5psi. going to a dynojet for some tuning monday, maybe i'll throw it up on a higher boost map then.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
Boss Paco (02-19-2014), SKELLINGTON (02-19-2014)
spark plugs change... fistpoint Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 53 02-23-2022 09:37 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
Where do these plugs go from? Z3D BRZ First-Gen (2012+) — General Topics 10 02-18-2013 10:59 AM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 12:29 PM
Jowett Jupiter/spark plugs aspera Engine, Exhaust, Transmission 6 02-25-2010 05:47 PM
