Old 02-18-2014, 01:32 PM   #43
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by FR-Slide View Post
Thanks, at my desk right now and not able to check.
Does the switch supplied light up with the rest of the dash equipment, like the dimmer does? Or only the indicator LED when it's on? And, as asked earlier, does/can this setup trigger the OEM fog light indicator bulb in the dash?
If the button plugs into the existing connection behind the dash, then yes, I think so.
This is such a tempting purchase, but I always get nervous when the instructions strongly recommend removing the front bumper. Stuff like that makes me nervous.
It has priests in it?
HunterGreene is offline
Old 02-18-2014, 01:44 PM   #44
FR-Slide
Drives: 13 Whiteout 6MT
Shouldn't need to remove the bumper at all. The bezels pop out, and you can access the fog light "holes" from under the car by loosening the splash shield.
Agree, though; I just can't decide between these or the Diode Dynamics, as I really like having glass housings, and will probably just wire mine into the parking lights...
FR-Slide is offline
The Following User Says Thank You to FR-Slide For This Useful Post:
Wes (02-18-2014)
Old 02-18-2014, 01:46 PM   #45
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Don't need to remove bumper. Check out Diode Dynamics vid on how to take bezels out and access the back of bumper, super easy
Wes is offline
The Following User Says Thank You to Wes For This Useful Post:
HunterGreene (02-18-2014)
Old 02-18-2014, 01:52 PM   #46
HunterGreene
Hail Magnet
Fantastic, thank you. I'm having trouble finding the video, though. Any chance you can PM it to me or link it here? (not sure how FT86SF would like having a competetor's video in their thread).
EDIT: Nevermind, found their Youtube Channel.
The Following User Says Thank You to HunterGreene For This Useful Post:
Wes (02-18-2014)
Old 02-18-2014, 07:06 PM   #47
FR-Slide
Originally Posted by KDad2 View Post
I am planning on getting the yellow kit. Here is the Toyota USDM fog light install. Looks similar to the Spyder kit.
http://www.ft86club.com/forums/showt...+light+install
I'm not electrically savvy enough to tell from looking at the pics on SF's site, so hopefully someone can chime in.
There's a 4-pin connection in the linked install of the "OEM switch"; this switch lights up when on AND triggers the in-dash indicator, since it taps into that hidden connector. Does the Spyder kit have the ability to attach to that connector as well? I'd like both of those functions (switch light and dash light) if I go for the switch route. Or, does that setup require the use of the existing OEM wiring in the car? I can't really tell from the write-up He mentions popping connections and pins in and out, and I don't see any of that in the Diode video, which is basically plug-n-play.
I'd LIKE to have the switch, just for the sake of options, even though I'd be running the fogs 99.99% of the time that the parking lights are on, so maybe it's just easier to tap into those and skip all the extra wiring...
Ugh.
FR-Slide is offline
Old 02-18-2014, 11:15 PM   #48
soundman98
ProCrastinationConsultant
soundman98's Avatar
Ugh.
if you do end up getting the kit and not using the switch and the panel, i'd be interested in it. i'm kind of a lighting addict and need the extra switch location..
soundman98 is offline
Old 02-26-2014, 12:31 PM   #49
dunnr
Boston WhiteOut
Drives: 2013 FR-S white-out, 2015 MB C300W4
Originally Posted by immaculate View Post
My point was that if a company has made crap products in the past, they might make crap products in the future.
FT86SF is awesome, and I don't want to derail the thread and cost them sales, so I'll just stop with that. I was just sharing my previous experience with Spyder on another platform, which I thought bears some relevance. These will sell like hotcakes regardless.
I bought the Spyder fog lights and don't like them aesthetically. I exchanged them for Toyota's OEM fog lights which look fantastic :on my whiteout.
dunnr is offline
The Following User Says Thank You to dunnr For This Useful Post:
FR-Slide (02-26-2014)
Old 02-26-2014, 12:57 PM   #50
FR-Slide
So another strike against Spyder? Just curious, but what about them didn't you like? I've been on the fence between those and the Diode kit, given their differences (OEM bezels, glass housings, tinted lenses, etc).
Guess I'll be going with Diode+Lamin-X when I pull that trigger
FR-Slide is offline
Old 02-26-2014, 09:21 PM   #51
dunnr
Boston WhiteOut
Spyder fog lights look like a knockoff of the Toyota OEM (http://toyotaofmcdonoughparts.net/pr...-fog-light-kit) Fog lights . Thats the only way I can describe the Spyder fog lights.
dunnr is offline
Old 03-21-2014, 01:20 PM   #52
STS-V
any other reviews?
STS-V is offline
Old 03-21-2014, 01:25 PM   #53
FR-Slide
Originally Posted by STS-V View Post
any other reviews?
My review: http://www.ft86club.com/forums/showthread.php?t=60469
After much support from Jeremy and Yo, we finally got a pair of working bulbs. Bezels still don't sit right, but it's not terrible. Since I tinted the front markers, it's not as obvious that they're out of place.
I may try and source some OEM bezels down the road.
FR-Slide is offline
Old 03-21-2014, 10:18 PM   #54
STS-V
Yes, I read your review FR-Slide, I was hoping there would be 90% more positive ones and you got a bad batch, rather than them all being bad.
STS-V is offline
Old 10-10-2014, 07:52 PM   #55
axelo
Drives: Whiteout frs
considering spyder's fogs....hope this helps
I didn't get them from ft86 speedfactory... simple install really but if you are a perfectionist, you are going to have a challenge on your hands...fog bezels dont fit right, not oem fit at all, if you look in detail, you notice instantly...will need oem bezels...2... button for fogs is not same material as stock, is more glossy so it will stand out in the cabin...3... you will have to work with pins in the bulbs, be careful not to break them, they have a very poor design and if not treated well, they will break when trying to get them work...usually is only one that give trouble not both...there other threads reviewing this kits, so if you are reading this opting for this kit keep looking, you will find this same setbacks i have mentioned.....overall is good for the money paid...but i had to invest on oem foglight bezels
axelo is offline
Fr-s Spyder tail light wiring. ettorres15 Southern California 4 04-17-2017 12:31 PM
Sonar/Spyder Tail Light Issues Mr.Jay Cosmetic Modification (Interior/Exterior/Lighting) 5 11-10-2015 07:29 PM
Sonar (Spyder) Tail Light Unboxing and Review Yruyur Cosmetic Modification (Interior/Exterior/Lighting) 28 10-20-2013 03:42 PM
Spyder Pink Light Issue? iJason Cosmetic Modification (Interior/Exterior/Lighting) 3 09-08-2013 09:55 PM
New Product Release: StopTech Big Brake Kits for Scion FR-S and Subaru BRZ !!! PRO Import Tuners Brakes, Suspension, Chassis 16 08-24-2012 07:59 PM
