Old 08-19-2013, 10:16 PM   #1
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Sonar/Spyder Tail Light Issues
So I have had these for a while but havent installed as I wanted to red them out. Now that they are painted I install them to find this.
My turn signals and brake lights are switched.
this is how they should work
[ame="http://www.youtube.com/watch?v=Vl22qz8tQp4"]Spyder L.E.D. Tail Lights for Scion FR-S / Subaru BRZ Demo Video - YouTube[/ame]
here are the ones I have
waiting to hear back from the site i got them from. Lots of bad luck so far with them. 1st suppose to get the lights in 2 weeks never came for a month and now this
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 08-19-2013, 10:35 PM   #2
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
I have a lot of experience installing spyder lights on a number of different cars. It is not uncommon for them to require you to remove wires from the plugs and rearrange them. Knowing spyder that probably wasn't in the instructions... if it even came with instructions. Also from experience you might want to put a thin bead of silicone around where the lens connects spyder lights are pretty netorius for condensation problems.
Sent from my Q10
Old 08-20-2013, 02:17 AM   #3
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
You should have messaged me I could have told or helped you repin them
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 09-06-2013, 05:40 AM   #4
alakim
Toyota 86 Driver
alakim's Avatar
Drives: Toyota 86 Velocity Orange
Are those Spyder's or Sonar's? I ordered the latter from Umnitza.com, I hope they're fine!
Cheers,
A.
alakim is offline   Reply With Quote
Old 07-29-2014, 10:59 PM   #5
bigred18
MJLONIR Program Member
bigred18's Avatar
Drives: 2014 Scion FR-S
I just installed mine and found out the wiring was wrong. Directions were in the box (that I found later) explaining how they worked. I had yellow-to-yellow and a green-to-green wire connection. The paper explained if you were in the U.S., the wires should be yellow-to-green/yellow-to-green. If you were not U.S., it would be y-to-y and g-to-g. If your wiring is messed up, see if what I stated helps, if not I'm sorry it wasn't useful information for you.
ドラゴンに乗る
Instagram: Komodo_Actual
My car build: http://www.ft86club.com/forums/showthread.php?t=81094
bigred18 is offline   Reply With Quote
Old 11-10-2015, 07:29 PM   #6
iiviiojica
Drives: Scion Frs
Thanks
I had the same problem and I had them like that for months. Im happy I found this. This did fix my problem, lights are working good now. I did switch to yellow to green. Thank you for sharing
iiviiojica is offline   Reply With Quote
Fr-s Spyder tail light wiring. ettorres15 Southern California 4 04-17-2017 12:31 PM
Spyder LED Tail Light, SEIBON Carbon Fiber, & C-West Aero eauto Exterior Parts - Lighting 301 10-15-2014 01:44 PM
Sonar (Spyder) Tail Light Unboxing and Review Yruyur Cosmetic Modification (Interior/Exterior/Lighting) 28 10-20-2013 03:42 PM
Sonar or Spyder Tail Lights P5yk0t1c Cosmetic Modification (Interior/Exterior/Lighting) 26 06-27-2013 01:12 AM
