Old 02-17-2014, 03:45 PM   #211
ayau
Drives: Some rust bucket
How would you go about in setting up multiple GPUs? Two GPUs mining different pools? Two different workers? Two GPUs mining for the same pool?
Old 02-17-2014, 04:54 PM   #212
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
Originally Posted by ayau View Post
Is there more profit in that than hashcow? Any reason to stick with hashcow?
I believe it is for simplicity. Not a lot of action needed to collect BTC.
If you monitor what coins are most profitable, you can make more money than Hashcows would for you. The issue with that is you have to be somewhat active in choosing what you will mine and making sure you have a wallet set up in that coin. Then, you have to worry about exchanging that coin for BTC.
rupert is offline   Reply With Quote
The Following 2 Users Say Thank You to rupert For This Useful Post:
ayau (02-17-2014), Luis_GT (02-17-2014)
Old 02-17-2014, 10:27 PM   #213
SoCal909
SoCal909's Avatar
Drives: 2014 WRB BRZ 6MT
I shouldn't have a problem using SSH & Putty to control a miner running Xubuntu if my main computer is running Win7 should I?
SoCal909 is offline   Reply With Quote
Old 02-18-2014, 12:27 PM   #214
ayau
How can I tell if my motherboard needs powered or non-powered risers? This is my board.
http://www.newegg.com/Product/Produc...82E16813121361
Old 02-18-2014, 12:44 PM   #215
Luis_GT
I haven't messed with risers yet, that's a question best asked on the forum I linked.
On a sidenote... new multicoin pool
wafflepool.com
The Following User Says Thank You to Luis_GT For This Useful Post:
ayau (02-18-2014)
Old 02-18-2014, 01:28 PM   #216
utekineir
blowhard
Drives: frs, project forester
wafflepool.com
hows waffle working for you? was reading it mentioned earlier today in my browsings
utekineir is offline   Reply With Quote
Old 02-18-2014, 01:48 PM   #217
ayau
wafflepool.com
I'm hashing that right now. We'll see how it goes.
Old 02-18-2014, 02:01 PM   #218
Luis_GT
Haven't tested it... still mining Ultracoins
Old 02-18-2014, 02:02 PM   #219
ayau
Maybe I was spoiled with hashcow, but I like how you can check your hash rate by just visiting their website. I have to remotely login to my mining box if I mine a different pool.
Old 02-18-2014, 03:26 PM   #220
ayau
So I'll have 2 280x GPUs by tonight. How do I set up cgminer to mine GPU 1 to pool A and GPU 2 to pool B? Do I run 2 cgminer instances? Thinking of running 2 different pools just to see how they each compare.
Old 02-18-2014, 04:23 PM   #221
utekineir
blowhard
Gpuminer makes managing different gpus individually silly easy.
Old 02-18-2014, 04:36 PM   #222
rupert
rupert's Avatar
You can add both pools to your configuration and tell cgminer/sgminer to load balance both pools. That should split your hashing power relatively evenly. Another bonus to this is if you set it up properly, if one of the pools goes down, it automatically makes the other card mine for the alive pool.
The Following User Says Thank You to rupert For This Useful Post:
ayau (02-18-2014)
Old 02-18-2014, 04:46 PM   #223
ayau
Do you mean guiminer? Cgminer seems to be faster according to most people.
Old 02-18-2014, 06:21 PM   #224
utekineir
blowhard
yeah that my bad, learn to tweak the settings it works fine, i get 430 each out of my 270x cards and 700+ out of the 280x with 0 over clocking.
