Old 02-17-2014, 10:03 PM   #15
wparsons
wparsons's Avatar
Slightly off the main topic, but if you're going to slam it 3" it's going to handle like garbage unless you add a bunch more parts to correct the geometry.
You're going to need to fix the roll centers, bump steer and camber all around (plus toe links out back if you get LCA's to fix the camber).
Have a look at what Robispec did to his to get it that low without ruining the geometry.
flickr
Old 02-20-2014, 01:27 AM   #16
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
Yeahhhhhhh lowering 3" and handling well + track should not be in the same sentence. You will need to fix A LOT to even be anywhere near that...
From what you listed, I would say FA, but since you're slamming..... I would choose BC, specifically the BC extreme low. It's going to ride rough that low, especially in that budget. Just being honest.
And in regards to the FAs, what is $150 that it doesn't just come with? They come with camber plates for the front and the thrust bearings are only $80 max.
Propaganda is offline   Reply With Quote
Old 02-20-2014, 10:19 AM   #17
Thekaylakrunkk
XE Autosport
Thekaylakrunkk's Avatar
Drives: 2013 Scion FRS Whiteout
Radial Bearing mounts is what they dont come with. I will be doing other things to correct the geometry. I think there is a mild misunderstanding in this thread about my expectations. I am not expecting the ride of a cadillac on a slammed FRS. I simply wanted to know the preferrence between bcs or fortunes, or if there is something in that general price range that is better.
Thekaylakrunkk is offline   Reply With Quote
Old 02-20-2014, 10:20 AM   #18
Thekaylakrunkk
XE Autosport
Originally Posted by Thekaylakrunkk View Post
And I am aware of dampening, spring rates, and all that stuff. I'm just needing a general opinion of which you find superior
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Old 02-20-2014, 10:36 AM   #19
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
if you were aware of these things, you wouldn't be asking your initial question.
you want the cake, you want to eat it, and you want it for cheap as well.
your goals of a good handling (grip wise), you want comfort (terrible roads), you want the car lowered by 3 (three!!) inches.... and all this for minimal investment
just ain't gonna happen.
Old 02-20-2014, 11:14 AM   #20
Thekaylakrunkk
XE Autosport
My initial question was fortunes or bcs. Didnt think that was too difficult to answer. I specified what I intend on doing to my car to skip all the interrogating questions I knew I would eventually receive. But as stated, preferences of bc or fortunes was clearly my question.
Old 02-20-2014, 11:29 AM   #21
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
in your case it really doesn't matter, if you're set on getting either coilover thinking they'll match your goals then just get whichever is cheaper.
neither will actually satisfy all your requirements.
The Following User Says Thank You to 7thgear For This Useful Post:
Thekaylakrunkk (02-20-2014)
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 07:30 AM
Need opinions! TakeNoL Electronics | Audio | NAV | Infotainment 13 01-26-2014 02:14 PM
Pro opinions before coilover install Thongpocket Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-07-2014 01:35 PM
Need Some Opinions Before I Buy Mr Kirmudget Cosmetic Modification (Interior/Exterior/Lighting) 0 09-27-2013 12:21 AM
So what horsepower level are people needing to upgrade the injectors/pump? seven Forced Induction 24 01-02-2013 12:28 AM
