#15 |
Drives: 13 FR-s, 84 911
Is the top of the Steve resting directly on the top of the shock? I know with my e46 there was an issue of the sleeve getting caught up on a wide spot of the shock and then needed some trimming. To get them truly low though I needed to get some slim camber plates, sort of the Cosmo racing style.
#16 |
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
my fronts as low as they can go are still stock ride height.
annoyed.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
#17 | |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
What lengths are you guys getting that has this problem? 7"? Is the problem only in the rear? What is the height adj range in the front? or, what the lowest adj you can go in the front? |
#18 | |
Drives: Asphalt FR-S
I have plenty of travel on the front, it was the rear that was the problem. GC's "fix" for it was to send me 6 inch springs to replace the usual 7 inch rear springs. Not sure if I'm going to use them as I just got the car corner- balanced and it handles great and rides fine. Just lots of clunking from front and rear over sharp bumps. |
#19 |
Much title. Wow.
6''spring, lowest in the front.
installing the last rear now
#20 |
#21 |
Much title. Wow.
Rears are in, the drop is even. but it sure is high. I had 6'' front and rear springs.
Two fingers front and rear between the fender and the tire at maximum drop. I'll go to the car wash and take a few pics, im very disappointed so far.
#22 | |
It's odd that both sets of springs were 6 inches. Mark at GC confirmed that the rears are supposed to be 7s. |
#23 |
Much title. Wow.
#24 |
Much title. Wow.
I'm going to try and return my kit. This is unsat for me.
#25 |
Hmm..that is a bit high. Does everyone with the sleeves end up being so high at max drop?
#26 |
#27 | |
Much title. Wow.
I spent nearly $600 on this, because everyone charges all the arms and legs to ship to canada, duty fee's and tax's.
#28 | |
Ground Control Coilover Problem
I would take them off, but I already invested 250.00 in corner balancing. I'm gonna leave them till I get some real coil overs. I was going to get Koni yellows, but GC said these sleeves don't work with Konis. Those sleeves are an additional 44.00 per end. |
| Tags |
| coilovers, ground control, springs |
| Ground Control Coilover Kit ? | ... | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 02-16-2014 01:41 PM |
| Ground Control Complete Coilover Suspension Kit and Adjustable End Links | Eric1855 | Brakes, Suspension, Chassis | 12 | 05-26-2013 12:02 AM |
| Ground Control Complete Coilover Kit | D1cker | Brakes, Suspension, Chassis | 2 | 04-06-2013 10:05 PM |
| Ground Control needs your Help | GC_Adam | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 11-13-2012 05:08 PM |
