Old 01-29-2014, 07:57 PM   #1
...'s Avatar
Drives: 13 SWP BRZ P
Ground Control Coilover Kit ?
Searched but couldn't find much info. I know they are for sale in the vendor section, but I don't see much talk about them. Any reason why they aren't discussed much? Can any owners chime in or give a quick review? I'm interested.
... is offline   Reply With Quote
Old 01-29-2014, 08:36 PM   #2
Alfr-s
Alfr-s's Avatar
Drives: Scion Fr-s and Honda civic
hey Luis_GT has it on his 10 series
Alfr-s is offline   Reply With Quote
Old 01-29-2014, 08:37 PM   #3
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Had them on my civic years ago
DrDuquette is offline   Reply With Quote
Old 01-29-2014, 08:55 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@Luis_GT
Old 01-29-2014, 11:40 PM   #5
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
If you know exactly what you are doing, you could do better with Motion Control or Ohlins, etc.
Otherwise, you should consider saving lots (lots)of money and going with Ground Control. Unless you have a very competent local dealer, I would contact them directly with you needs:
http://www.ground-control-store.com/products/index.php
You see, Ground Control doesn't just make one setup for any car. The have a range of options that can be customized to meet each customer's needs. Also, Ground Control does a lot of track and street testing for a car before releasing a suspension solution. Discussing your needs with them (or a good dealer) is the best way to get a great suspension.
I have not driven an FR-S/BRZ with a ground control setup, but I have driven an E46 BMW M3 with one. Best handling car I have ever driven – it was just great and much better than stock, which is saying something. In my opinion, Ground Control is by far the best of the [relatively] inexpensive suspensions available for our cars.
Old 01-30-2014, 02:25 PM   #6
...'s Avatar
thanks guys.
I know they've been good with past cars but I was just curious why they're not all over the forum. Costs a little more than springs but a lot cheaper than coilovers.
Just a dd btw
Old 01-30-2014, 06:08 PM   #7
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
GC = the way to get quality custom spring rates at a very affordable price and under $500
fooddude is offline   Reply With Quote
Old 01-31-2014, 03:09 PM   #8
jonzhuxD
Drives: Ultramarine FR-S
So for this do you need anything that doesn't come in their kit? I want to be able to retain factory (or similar) camber and height adjustability. Car is strictly a daily driver, with some spirited driving every now and then.
jonzhuxD is offline   Reply With Quote
Old 02-04-2014, 12:27 PM   #9
...'s Avatar
pretty sure you don't need anything else
... bump,
Anyone else have these?
Old 02-04-2014, 06:51 PM   #10
Turbo Den
Drives: FRS, IS300, 911sc
to me, the most attractive feature of CG is the front camber adjustment with their camber plate, which does NOT fit stock or any lowering springs.
Turbo Den is offline   Reply With Quote
Old 02-05-2014, 09:09 PM   #11
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I have had the ground control street kit using OEM upper mounts (no camber plates) for about 8 months. Zero issues.
Old 02-05-2014, 09:29 PM   #12
fatoni
those are just sleeves with springs. its pretty much just a spring on an adjustable perch for corner balancing or ride height purposes. if you are diligent enough, you can find an appropriate shock and top hat to match your purposes. for example, a couple years ago i had some bilsteins revalved for specific spring rates and used the gc sleeves in conjunction with the complete suspension setup i was after.
its hard to review them since they are a piece of a whole. the quality is there but a well built piece wont work if its not part of the puzzle youre trying to put together.
Old 02-16-2014, 01:14 PM   #13
YodrOne
Drives: 2013 Scion FRS
Looking for input on these as well. I'm primarily interested in how the stock damper deals with the much stiffer spring rates that GC offers over the various sport kits (which I won't consider). Is it possible to just install the springs without the adjusters yielding a set ride height?
I'm basically looking for a quality spring to significantly reduce roll for track/autocross use.
YodrOne is offline   Reply With Quote
Old 02-16-2014, 01:41 PM   #14
...'s Avatar
There's another thread currently discussing these in this suspension forum. Sounds like GC is taking some heat from a couple owners.
Ground Control Complete Coilover Suspension Kit and Adjustable End Links Eric1855 Brakes, Suspension, Chassis 12 05-26-2013 12:02 AM
Ground Control Complete Coilover Kit D1cker Brakes, Suspension, Chassis 2 04-06-2013 10:05 PM
Ground Control for 86/FRS/BRZ phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-14-2012 07:56 PM
Ground Control needs your Help GC_Adam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-13-2012 05:08 PM
