Old 02-14-2014, 05:44 AM   #155
brn12345
brn12345's Avatar
While logging and comparing 1.55 to previous tunes, I noticed something interesting. My engine load before the 1.55 never got into the 1.3g/rev range. Most I saw was in the 1.2x range. With the 1.55 the engine load post 6200 goes to 1.332g/rev and remains static to nearly redline. I tried looking into the mapping to see what is causing this but couldn't find anything. Shivs reply in another post :
Originally Posted by shiv@vishnu View Post
.... Definitely before we change the format/size of the OFT .bin files.
Got me thinking and this is a question to Shiv. Is more going on in the 1.55 roms that we cant see with the current file definitions?? The reason I am asking is that my log now with the 1.55 is very different from previous logs with older OFT roms, yet the changes made to 1.55 are somewhat minimal in what can be seen with the editors in the top end. In particular I am interested in why my engine load now reads mostly in the 1.3g/rev range as opposed to 1.2g/rev range. Even MAF voltage is higher than before.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 02-14-2014, 06:17 AM   #156
steve99
Drives: FT86
Originally Posted by 8686 View Post
Yes the headers are catless.
And yes, our gas is like shit so with each visit to the gasstation I add one bottle of Lucas Octane Booster.
ROM type is K.
Should I add 2 bottles for every tank.
If you can add more octane booster you could try that if its within the usage directions. Otherwise better fuel
Old 02-14-2014, 06:56 AM   #157
Kodename47
Kodename47's Avatar
Drives: UK GT86
The obvious things to check are MAF Scaling and AVCS Timing. A change in the cam timing could result in changed airflow.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-14-2014, 04:57 PM   #158
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
OpenFlash Tablet v1.55b: BIN files added!
No ones asked yet but I'm dying to know what shiv thinks of the vortech.
Installed Mods:
Old 02-14-2014, 05:29 PM   #159
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I dropped our test car off on Wednesday. Will be flying back down next week to work with their chief calibrator on the dyno. Then driving it back to the bay area. Then will install the OFH and some other exhaust bits and custom tune it some more. So I will have some good insight late next week
Shiv@Openflash is offline   Reply With Quote
Old 02-14-2014, 07:07 PM   #160
Sojhinn
Sojhinn's Avatar
I know this sounds crazy but does the plumbing of the vortech allow the phantom to be installed as well?
Installed Mods:
Old 02-14-2014, 10:21 PM   #161
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
doesnt anyone know how to adjust trims while coasting (off throttle). vvt fuel ign anything?? its always 0 cam timings, fully leaned af and 32 deg timing... any way to play around with these numbers?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 02-15-2014, 01:42 AM   #162
8686
8686's Avatar
Drives: 86
Originally Posted by normancw View Post
I've been shopping for an SC and narrowed it down to JR or Innovate. But since you announced support for the Vortech, it's now near the top of my list!
The idea of a SC package with the OFH and free OTS tunes for life is very appealing. Very keen to see your results!
+1
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 02-15-2014, 03:33 AM   #163
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
It is fully leaned on coasting because there is no fuel in the system. You want this.
Luckrider is offline   Reply With Quote
Old 02-15-2014, 10:01 AM   #164
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ya i know but id still like to know how to adjust this area, just for referance. i dont think we have access to it in the xdf files do we?
IG-Joey_Soul
Old 02-15-2014, 07:08 PM   #165
Kodename47
Kodename47's Avatar
Drives: UK GT86
You can't adjust the fuelling when on the over-run. I'm not sure why you'd even want to? For the other setting, just see where the corresponding load matches RPM and a just the table accordingly.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-16-2014, 11:16 PM   #166
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I'm not 100% but I believe MAF voltages is a decent indicator of air flow and thus power output and/or potential. The higher the better.
Old 02-17-2014, 12:01 AM   #167
jamesm
Exactly right. More maf voltage at a given rpm == more air in the cylinder == more potential power, thanks to improved volumetric efficiency in this case.
Old 02-17-2014, 10:32 AM   #168
brn12345
brn12345's Avatar
Then if that's the case a big thanks to shiv@vishnu for unlocking this extra power. Suffice to say I am very happy. The car screams.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
