Old 02-14-2014, 12:58 PM   #3627
Robftss
Drives: VW
Name:  DPDT switch.JPG
Auto on/off mod.
-pull back loom
-cut green & yellow wire
-solder to DPDT relay (N.O.) as shown.
-relay coil: 1) to chassis ground, 2) run wire through firewall to switched +.
Any DPDT relay will do (2A minimum)
Thks, Rob.
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
DAEMANO (02-14-2014)
Old 02-14-2014, 01:00 PM   #3628
fenton
Today is going to be the day this thread hits 250k views! Would have never believed it starting out 6 short months ago. We are all truly lucky the Rob has developed such a awesome product for such a awesome car....and the gains, i never thought i would see the day that 80tq and 50 - 30 hp was so damn EASY!
Lets see some vids guys
fenton is offline   Reply With Quote
The Following 3 Users Say Thank You to fenton For This Useful Post:
DAEMANO (02-14-2014), normancw (02-14-2014), Pug (02-18-2014)
Old 02-14-2014, 01:03 PM   #3629
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Originally Posted by Robftss View Post
Auto on/off mod.
-pull back loom
Thks, Rob.
If anyone needs one, I still have one left over, just PM me your address.
EDIT - all gone
VR46 is offline   Reply With Quote
Old 02-14-2014, 01:04 PM   #3630
Robftss
Drives: VW
Originally Posted by migueralliart View Post
If this kit is using a brushless controller another thing is to consider the use of a slightly better FET. Again I'm not sure what it uses but for 200 amp currents I'm pretty sure 4-6 irf3077 in parallel and properly heatsinked will suffice per phase. Their Rdson is one of the lowest at less than 55v of operation.
Can someone give more details about the controller etc? There should be a separate board handling the charging I'm pretty sure.
Pretty interested in the 30024v version. Damn you guys for bringing these near the tax refund season!!!
The 3077 MOSFET is to small.
Current applied video.
[ame="http://www.youtube.com/watch?v=41L6HoKqEeM"]http://www.youtube.com/watch?v=41L6HoKqEeM[/ame]
The Following 2 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (02-14-2014), Pug (02-15-2014)
Old 02-14-2014, 01:05 PM   #3631
migueralliart
migueralliart's Avatar
Drives: 2013 Firestorm FRS
No doubt the easiest plug and play solution.
migueralliart is offline   Reply With Quote
Old 02-14-2014, 01:17 PM   #3632
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
@DAEMANO you installing yet?
Installed Mods:
Old 02-14-2014, 01:31 PM   #3633
Robftss
Drives: VW
Originally Posted by stevo585 View Post
Just throwing this out there is it possible to run two (twin) ESC's?
[ame="https://www.youtube.com/watch?v=ErRb6H-uRDk"]https://www.youtube.com/watch?v=ErRb6H-uRDk[/ame]
Only on the bench. It is mad!
Boost = PR x PR
Rob
DAEMANO (02-14-2014), TM (02-14-2014)
Old 02-14-2014, 01:32 PM   #3634
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
Boost = PR x PR
Rob
Rob what do you think is the estimated psi you could hit with the dual setup?
Edit: couldn't watch video: he states 11 psi
Installed Mods:
Old 02-14-2014, 01:37 PM   #3635
migueralliart
If you click the video he mentions 11psi.
Rob I think you're need to start patenting some of these things man.
Ohh shoot looks like someone did back in 1997
http://www.google.com/patents/US5638796
The Following User Says Thank You to migueralliart For This Useful Post:
Sojhinn (02-14-2014)
Old 02-14-2014, 02:29 PM   #3636
DAEMANO
Time Traveller
A laypersons thoughts on this. No affiliation to Phantom superchargers at all.
1. I doubt this is the first attempt to patent the idea in the U.S. as the concept had been around as long as the internal combustion engine itself. Of course patents are meaningless without the means ($$$) to protect them and the jurisdiction to validate them. This is a U.S. patent, see point 3.
2. Rob sells a kit of parts that the buyer can install as a system, not the fully assembled system itself. Much in the same way there are kits sold that can be used to produce other patented ideas (e.g. kit cars, gun parts, etc.)
3. Rob's in Canada.
Old 02-14-2014, 02:30 PM   #3637
DAEMANO
Time Traveller
Bah, at work!
Old 02-14-2014, 02:38 PM   #3638
Sojhinn
Sojhinn's Avatar
Originally Posted by DAEMANO View Post
Bah, at work!
Bah!
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Old 02-14-2014, 03:02 PM   #3639
HunterGreene
Hail Magnet
HunterGreene's Avatar
Patent law is a funny thing. Given that the fee has gone unpaid, he may be able to file patent here.
It has priests in it?
Old 02-14-2014, 03:08 PM   #3640
migueralliart
Agreed.
Its funny thou in that patent it lists the voltage of the system significantly higher. This is ok for a car application but the main problem becomes the charging of the dump pack. If it is higher voltage then it gets more complicated and expensive. I agree with everyone else in that Rob did an excellent job keeping the cost down.
Rob,
In your research phase did you check the compressor performance maps? It seems some of the GT28 inlets hit high efficiency between 55k-65k. You're probably combining larger vanes into smaller housings which seems like the way to go.
If only cars were using a 36V system like the germans envisioned a while ago.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
