Old 02-13-2014, 09:57 PM   #57
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
I know plenty of folks abandoning apple in droves as OSX becomes more locked down and more like iOS than the old Mac OSX. Apple seems to like the idea that Windows RT has.
See ya, Apple. Let us know when you start being inventive again and stop suing everyone that has a white phone with a single physical button...
And how DO you bring back the traditional start menu button in 8? I've looked and can't find that option. Instead I have about 3 different ways of getting to the Metro UI when I only really need one (charm bar).
^GT5 Replay Photo Mode^
Old 02-13-2014, 10:12 PM   #58
olorin
olorin's Avatar
Drives: GBS Premium
I use a spare mac book to run win7 on bootcamp for flashing and logging. Works fine. Never use windows outside of that.
olorin is offline   Reply With Quote
Old 02-13-2014, 10:26 PM   #59
SirBrass
SirBrass's Avatar
And it takes forever to flash with windows on a Mac. Ask @nelsmar
Old 02-13-2014, 11:17 PM   #60
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
he said it only is a problem when dynoing. so if you aren't dynoing save your money and use bootcamp
3 minutes vs a minute minute? negligible
86-tundra is offline   Reply With Quote
Old 02-13-2014, 11:21 PM   #61
86-tundra
Troll Hunter
86-tundra's Avatar
@SirBrass @DJCarbine @jamesm @nelsmar
I've looked at the T-100, Lenovo Miix 2 and Dell Venue 8 Pro.
I need to know from experience, which one of this will absolutely flash the car in 1 minute or less.
I have a mac, have run parallels, bootcamp and vmware and they are all within 3-4 minutes.
I would only get a new device if I can get flash times to 1 minute or less. Now that I am fine tuning the car, I hate to have to sit 12-15 minutes a night just to see the car flashed.
I believe @nelsmar uses the Lenovo miix 2 and it is close to 1 minute? If so, what USB adapter are you using?
Again, this device will be use solely and exclusively to run Ecutek, don't care about nothing else and want to know it flashes in about minute.
Thanks.
ECU tek should consider using usb3. This will significantly increase write speeds. I don't know much about the data transfer speeds of ecutek, writing a rom to our car. but in general, usb is going to be a bottleneck when writing data.
Old 02-13-2014, 11:22 PM   #62
mswhong
Drives: FT86
Yes there is.
You can accept the fact that the "metro UI" is the new start menu and functions almost the same as the start menu of old or use one of the many options to bring the "traditional" start menu back and quit your bitching.
Originally Posted by AdrianG View Post
This is what I'm so sick of hearing about Microsoft products. Whenever there's a major change almost everyone hates it and are just told to suck it up and learn to use it. You shouldn't have to re-learn an operating system!
When vista came out, everyone clung to XP. When. 8 came out everyone clung to 7. Meanwhile Apple is breaking records for user adoption rates.
- AdrianG
^take that as reference, why does microsoft ALWAYS have to fuck around with their OS? Why do we as paying customers have to always re-learn how to use their damn OS? XP to vista wasn't too bad but the jump from 7 to 8 is fucking terrible.
As a long user of microsoft products, I wish they just kept it the way it was back with windows 98 and not have to re-learn how to use a freaking OS.
mswhong is offline   Reply With Quote
Old 02-13-2014, 11:41 PM   #63
nelsmar
Because that USB3 performance will significantly help boost the performance of the ISO 15765-2 connection that is running at 500kbs. Oh wait... no it wont. The issue with the flash time is due to latency of hardware not the actual transfer throughput. A lot of hardware is used as passhrough allowing the actual computer to send commands via canbus vs buffering the data to transfer on the hardware (the cable). The cable is capable of processing full speed and the software expects there to be a specific latency due to it being a pass through device and a virtual environment does not provide this, as well as some older chipsets.
I haven't read up on the USB3 spec's but im going to assume the newer standard doesn't improve latency just throughput. However I could be incorrect about this. Also flash time could in theory be slowed down due to heavy can bus traffic.
My flickr - Canibeat
Local magazine scout
Old 02-13-2014, 11:51 PM   #64
nelsmar
I disagree... But for the record i never did try flashing via my mac using bootcamp only parallels. I used to flash in ~2mins but was told directly from Xavier @ Ecutek to stop doing this due to the latency issue in which I am familiar with since I have been developing canbus based hardware as of late.
When it comes to time... the money is well worth spent for a cheap tablet JUST for flashing for my own purposes. I have been doing ~ 100 flashes a week and thats an assload of time staring at the gauge cluster lol.
The Following User Says Thank You to nelsmar For This Useful Post:
Sportsguy83 (02-14-2014)
Old 02-14-2014, 12:26 AM   #65
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Take your Macbook. Install a SSD in it. Install W7 on a bootcamp partition. Call it a day.
You can run W7 in a VM but flashing is way slower that way.
Bg8780 is offline   Reply With Quote
Old 02-14-2014, 12:49 AM   #66
86-tundra
Troll Hunter
86-tundra's Avatar
nope you got it right. That's why I'm saying I'm unfamiliar with this territory of computing. usb3 wont help in this case. In the simple solution of writing a rom to a device, usb will be the bottleneck.
definitely something I'm interested in learning. Coming from a world where I'm daily dealing with 10gigabit connections, kinda weird to think about such slow data transfer speeds
Old 02-14-2014, 01:14 AM   #67
jamesm
I just wish I wouldn't have sold that old netbook...
The Following User Says Thank You to jamesm For This Useful Post:
Old 02-14-2014, 05:32 AM   #68
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Install windows 8.1.
I'm not talking about people switching to Mac from another platform, I'm taking about when they release a new a major update to their OS. When Mavericks was released they broke a record for adoption:
http://www.computerworld.com/s/artic...doption_record
Windows 8 on the other hand has been available for 15 months now and companies like Dell and Lenovo are STILL selling windows 7. Dell even recently released a new generation of their Optiplex SFF's and they come with Windows 7! Do you see anyone complaining that Apple isn't releasing new computers that run Snow Leopard?
As for the USB3 discussion: USB2.0 gas a potential throughput of 480mbps, and the full rom is 1.25mb including whitespace. If USB 2.0 were the limitation it would flash in under 1 second. Hell, it would have time to write and do a verify on the write at least 5 times in 1 second.
Also I have flashed using ecuflash in VMware fusion on my mac and it is exactly the same speed as on a bare metal laptop. The limiting factor is the ecu.
- AdrianG
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
86-tundra (02-15-2014)
Old 02-14-2014, 07:50 AM   #69
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
FWIW, my old laptop does not flash any fast at all.
I would like to find out what is the determining factor in the speed (I'm only interested in FLASHING, nothing else).
Is it the SSD drive, is it the USB 3.0 port, is it lots of RAM, is it a really fast processor?
I'm inclined to think its the processor.
Old 02-14-2014, 07:54 AM   #70
Sportsguy83
Drives: Limited BRZ
- AdrianG
It is not the ECU. I have a retina Mac (SSD, usb 3.0, i5 proccesor) and I flash between 3-4 minutes on VMware, Parallels or Bootcamp.
@nelsmar flashes with his 8.1 tablet in 1 minute and 35 seconds.
Laptop + Tactrix cable + BRZEdit personal - $400 Dodzilla Engine, Exhaust, Bolt-Ons 5 02-14-2014 04:30 PM
SOLD: Toshiba C855D Laptop swift996 Miscellaneous 0 01-10-2014 06:06 PM
Carbon Fiber Laptop Sleeves - Introducing DFWcomposites to ft86club DFWcomposites Announcements, Contests, Giveaways 4 08-12-2013 02:42 AM
Carbon Fiber Laptop Sleeves - DFWcomposites DFWcomposites Miscellaneous 3 08-12-2013 02:42 AM
ALIENWARE LAPTOP brichard0625 Off-Topic Lounge [WARNING: NO POLITICS] 68 11-06-2012 01:01 PM
