Old 11-03-2013, 03:25 PM   #43
qqzj
Drives: MDX, Camry
Originally Posted by Garstang View Post
Okay I am really confused. I have a FRS what exactly is the problem with the window switch. I have having a brain fart.Help
My car is made in 07/13. So it should not have this problem, right? All these issues made me really concerned.
qqzj is offline   Reply With Quote
Old 11-03-2013, 03:49 PM   #44
Garstang
Garstang's Avatar
Drives: FRS
How to tell the date of the car
How do you get the date of the car ?? Then I will check mine and let you know. I know how you feel about all these problems. I feel like getting rid of my FRS.
Garstang is offline   Reply With Quote
Old 11-04-2013, 01:43 PM   #45
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
There's a tag in the door. Pretty standard for most cars built in the last 40+ years.
ineedyourdiddly
Garstang (11-04-2013)
Old 02-11-2014, 02:55 PM   #46
captainzib
Oompa Loompa of Science
Drives: Scion FR-S
Thumbs up
Originally Posted by fledonfoot View Post
The correct Toyota part number is SU003-04628 according to the part I just ordered for myself at work.
So is SU00302457 the old switch? Because they agreed to change my switch and that's the P/N for the new switch that arrived.
Also I was skimming through this thread and didn't see anything on a Toyota TSB. I printed off the Subaru one though, in case I end up with a disagreement at the dealership.
*Edit* Just talked to a guy at the parts department of my local dealer. He did find the part number you listed, informed me there is a TSB, though I forgot to ask for a TSB number, and ordered the new part for me.
Thanks
captainzib is offline   Reply With Quote
Old 02-11-2014, 05:03 PM   #47
fledonfoot
Drives: Asphalt FR-S
The part has since been updated, again, with the new TSB that includes replacement rollers and belt molding pieces.
fledonfoot is offline   Reply With Quote
The Following User Says Thank You to fledonfoot For This Useful Post:
captainzib (02-11-2014)
Old 02-11-2014, 06:09 PM   #48
captainzib
Drives: Scion FR-S
S-SB-0001-14 : Window Freezing, Losing Initialization
That one?
Just talked to the service manager again, and he said they have to inspect the car to verify it qualifies for the TSB. Sounds like a bunch of bs to me, especially considering this TSB is weather dependent. If the parts are faulty enough to warrant a TSB, then I feel they should replace them at the customer's request.
Old 02-13-2014, 09:31 AM   #49
fledonfoot
That one?
Yes, that one.
Technically, we have to verify the condition is present before we can perform a TSB - they are for specific condition as listed. We then also must double check that it happens, and it falls within the vin range applicable. A TSB is not a recall, and vice versa. Issues in TSB's don't occur in every vehicle within the VIN range.
TSB's are not carte blanche for a dealer to just throw parts at a car. If the tech just follows the TSB blindly without properly diagnosing the issue, rolls the car out of the dealer, and you return a few days, weeks or months later with a similar/the same issue, Toyota may either charge the dealership back for the failed repair (this TSB costs about $900 or so depending on the dealer's warranty labor rate) and/or bounce the claim for the second/repeat repair. Some smaller dealers or dealers with higher than usual warranty numbers can be hesitant to do much warranty work.
The parts themselves are not faulty. They are not defective - your windows actually work as designed, and they shut down when they freeze so they don't burn out the motors, rip apart the weatherstrips, etc. The new parts are updated so it happens less often.
Your best bet is to call another dealer, tell them that this issue is happening and you know of the TSB and want to schedule an appointment.
captainzib (02-13-2014)
Old 02-13-2014, 10:00 AM   #50
captainzib
Drives: Scion FR-S
The issue did occur in my vehicle, but under certain weather conditions. Do they plan to put my car in an environmental chamber over night?
Sent from my HTC One using Tapatalk 2
Old 02-13-2014, 03:52 PM   #51
calidus
Drives: 2013 SWP BRZ Premium
Welp this happened to my 2013 BRZ this week. Time to call the dealer.
calidus is offline   Reply With Quote
Old 04-13-2014, 03:34 PM   #52
Rustyspoon
Drives: FR-S, XJS, C10
I got my car in for this. I was told it was an easy repair. ....3 days later.....
It was their first try at this. Turns out they had to make a tool to get at a certain bolt. But now I am noticing a lot of wind noise from the windows. Anyone else run into this?
Rustyspoon is offline   Reply With Quote
Auto-Up/Down and Passenger Window Not Working chanomatik Issues | Warranty | Recalls / TSB 106 05-09-2021 02:25 AM
BRZ jammed window issue/blinking auto light? Superhatch Issues | Warranty | Recalls / TSB 28 02-15-2015 06:45 AM
Passenger window stuck. Marshman Issues | Warranty | Recalls / TSB 6 03-08-2013 08:39 AM
Passenger Window Switchs Out LarryGP Issues | Warranty | Recalls / TSB 10 11-13-2012 07:04 PM
Teaking Tail light and Driver side passenger window auto down feyrerm Issues | Warranty | Recalls / TSB 2 08-11-2012 01:32 AM
