Old 02-10-2014, 03:25 PM   #1149
jamesm
Originally Posted by 2point0 View Post
I've been noticing some "cold start" issues lately as well. At first I assumed it was morning temps, but it doesn't get nearly as cold here as people who have legitimate cold seasons. But I had trouble starting yesterday afternoon when the car sat all night and half the day, but ambient temp was warm.
Basically, the first start attempt ends in sputters and the second try starts it right up. This morning I played with the throttle a bit on the first try and did get it to finally catch.
I'm on v1.42. Any thoughts? I think the coldest outside temps I see here are around 40-50 F.
if giving it throttle causes it to start, it's likely that the values in the cranking ipw tables are too high.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
2point0 (02-10-2014), Luckrider (02-11-2014)
Old 02-10-2014, 03:27 PM   #1150
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I have had luck with very aggressive fueling on propel e85 cranking. Every time I back off, it doesn't start well. Pm me your email address and I will send you what I have.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 02-11-2014, 08:42 AM   #1151
troek
troek's Avatar
Drives: 2012 Toyota 86
Sorry if this has been brought up before, but i havnt seen it. Im trying to familiarize my self with the tunes while i wait for my OFT, and i noticed it has a value for catalyst warm up, but its all zeroed out. Is the crazy loud valve over lap thing disabled in this tune. If not has anyone found a way to disable it? i dont mind 1500+ rpm idle while warming up but that 20 or so seconds of insanity has got to go!
troek is offline   Reply With Quote
Old 02-11-2014, 08:51 AM   #1152
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I couldn't believe that pushing the accelerator LOWERS the IPW during cranking (causing less fuel to be injected). The fact that it helps things get started makes sense after I did some research on e85 and its flash point, it made much more sense. It isn't a smooth progressive scaling for the IPW for e85 that is need, it is more like, like scaling from 30-50 degrees, a little bit more fuel down to about 10, and then things need to get aggressive.
Luckrider is offline   Reply With Quote
Old 02-11-2014, 09:03 AM   #1153
jamesm
it does, believe it or not. there is a compensation for cranking ipw vs. throttle position... shown here:
seemed weird to me too...
Old 02-11-2014, 09:34 AM   #1154
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
You beat me to it, James...
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
jamesm (02-11-2014)
Old 02-11-2014, 03:07 PM   #1155
Mirko
Mirko's Avatar
Drives: Subaru BRZ
Sup guys
I finally made my decision and chose the OFT over ecutek. I've done my homework and read all the FAQs and lots of threads about it, but I still have a doubt: will I be able to find a tune that suits my needs between the "off the shelf" tunes? I really have no idea of how many tunes are offered...
Cheers
Mirko is offline   Reply With Quote
The Following User Says Thank You to Mirko For This Useful Post:
Shiv@Openflash (02-11-2014)
Old 02-11-2014, 03:09 PM   #1156
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Mirko View Post
Sup guys
Cheers
Glad to have you on board! What other engine-related modifications do you have?
Shiv@Openflash is offline   Reply With Quote
Old 02-11-2014, 03:24 PM   #1157
Mirko
Mirko's Avatar
Drives: Subaru BRZ
First of all I live in Italy so Im not sure if the tunes are going to be the same.. standard fuel here is 95 octane and I have a drop-in air filter, catless UEL headers and 2.5'' all-catless overpipe, test pipe and catback.
Thank you for your help and time
Old 02-11-2014, 03:30 PM   #1158
Luckrider
Luckrider's Avatar
The regular Stage 2 UEL Tune will work for you, it just needs to match your CAL ID. 95 in Italy is like 92 here in the US if I remember correctly.
The Following User Says Thank You to Luckrider For This Useful Post:
Mirko (02-11-2014)
Old 02-11-2014, 03:36 PM   #1159
Shiv@Openflash
Drives: 2013 FRS
I concur
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Mirko (02-11-2014)
Old 02-11-2014, 04:29 PM   #1160
PMok
Codename: Stitch
PMok's Avatar
@shiv@vishnu,
I have a question for you. I was talking to a local wheel & alignment shop and they mentioned that as part of the alignment they do a steering position sensor calibration, and that led me to ask whether that calibration info is stored in the same area of the ECU as is being reflashed (whether by OFT or Ecutek or other means). The shop owner/alignment did not know where that info is stored. But he said that the steering position sensor definitely is important to have calibrated, since it is tied into how the traction and stability control functions. And since the calibration is unique to each vehicle, it's something I'd worry about being overwritten using an OTS tune ... any ideas on whether that is an issue or not?
Thanks.
Old 02-11-2014, 04:37 PM   #1161
jamesm
@shiv@vishnu,
Thanks.
It is not. Completely different computer.
The Following User Says Thank You to jamesm For This Useful Post:
PMok (02-11-2014)
Old 02-11-2014, 04:40 PM   #1162
OmarYasin
OmarYasin's Avatar
@shiv@vishnu sent u a pm regarding purchasing oft
Sent from my SGH-T599N using Tapatalk
OmarYasin is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
