Old 02-01-2014, 05:38 PM   #99
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
I'm sold on the STs, anyone have a better price than the ones i found on these? Best I found was $850 new
eddieEndo is offline   Reply With Quote
Old 02-01-2014, 06:01 PM   #100
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Originally Posted by *LongFella View Post
Mine weren't set to anything and packed bad... hence needing to file a claim and have ST(KW) send me two me springs...
My current setup is 0 left in front and 16 in rear... I made some small turns to get everything matching measurement wise (center hub to top fender)... Matching threads are not 100% perfect to each other...
I just received my ST coilovers this week and mine were also boxed terribly. Every spring had some kind of ding in the yellow coating. Very frustrating. Thankfully the shocks look fine, but still.
How long did it take to get new springs sent and did you have to return the messed up springs before they sent you new ones?
jprice130 is offline   Reply With Quote
Old 02-01-2014, 06:08 PM   #101
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
I think mine were a bit messy when I opened them but that's because they went from CA to the Midwest back to me in CA (to avoid CA sales tax through my vendor). Might've had some dings but I didn't take special notice since pebbles will ding at them anyway. Can you count how many threads are exposed starting from bottom of the shocks up to the bottom of the adjustment collars?
Old 02-01-2014, 06:12 PM   #102
jprice130
AutoX Nut
Originally Posted by switchlanez View Post
Can you count how many threads are exposed starting from bottom of the shock up to the bottom of the adjustment collar?
The collars on the front struts were 2 or 3 threads from the bottom. The rear struts were both completely different. One was right in the middle of the threads and the other was near the bottom.
Unfortunately, I already moved the collars all the way down and installed my top hats so I don't remember exactly where they were when I unboxed them.
Old 02-02-2014, 12:38 AM   #103
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
where did you guys buy from and for how much??
Old 02-02-2014, 10:45 AM   #104
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
You should be able to find some in the $750-$800 price range. I know some forum members paid between that price (group buys, online sale etc.)
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 02-06-2014, 01:33 PM   #105
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
From a sheer performance standpoint, how do the ST's compare with the stock suspension? Is it significantly better or about the same?
smg1138 is offline   Reply With Quote
Old 02-06-2014, 01:36 PM   #106
*LongFella
*LongFella's Avatar
My personal opinion:
Better than stock and the ride is just a tiny bit stiffer than stock. Worth every penny...
Old 02-10-2014, 12:53 AM   #107
jflogerzi
jflogerzi's Avatar
But for that you can just get springs now like the RCE Yellows and shocks later on after stock wears out a bit.
Old 02-10-2014, 08:57 AM   #108
*LongFella
*LongFella's Avatar
True, but I like the adjustability factor of having coilovers and being able to get really low to the ground. In addition, I won't have to worry about rim-to-suspension clearance.
To each their own I guess
Old 02-10-2014, 11:09 AM   #109
switchlanez
+1 for enabling a wider selection of wheel/tire sizes. Also costs less than the spring/strut combo I would've went with (Eibachs+Bilsteins) and will cost less in the long term with its 5 year warranty.
Old 02-10-2014, 11:10 PM   #110
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
You can purchase @468Power ,yes the price will vary from about $750-850.
I haven't gotten to drive the car that much NY has been hit with snow just about every week.
Ny Brz is offline   Reply With Quote
Old 02-15-2014, 08:26 PM   #111
Dpforlife
Dpforlife's Avatar
Drives: Scion FR-S Raven
I was just about to ask how are these holding up in east coast conditions, Im worried about rusting issues with all this snow and road salts being used.
Dpforlife is offline   Reply With Quote
Old 02-17-2014, 03:47 PM   #112
damaster32
Drives: 2014 BRZ Limited
Do I need to buy camber bolts for the front if I will be dropping max on these coils?
damaster32 is offline   Reply With Quote
RS*R Sports-i coilovers - install & review ultra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 50 07-27-2022 05:29 PM
Suspension Review: KW v3 Coilovers DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 07-09-2015 11:42 PM
Mann Engineering Coilovers review l8apexr CANADA 10 03-11-2014 12:11 PM
FR-S Coilovers Review sraggs42 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-14-2013 12:16 PM
Who likes blue? FT-86 SpeedFactory Review - Standard R3 Coilovers FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 04-27-2013 03:50 PM
