Old 01-29-2014, 06:46 PM   #85
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Sweet. Thanks for the feedback! I'm still debating if this is the path I want to take. I plan on autocrossing at least a few times this summer, so would be nice to stiffen up the suspension just a tad bit AND have a drop, instead of just lowering the car on springs.
Old 01-29-2014, 07:34 PM   #86
DarkestBuddha
Drives: BRZ limited GBS
front is maxed, back is almost
raised 1inch all around from the previous pic
DarkestBuddha is offline   Reply With Quote
The Following User Says Thank You to DarkestBuddha For This Useful Post:
chanomatik (01-29-2014)
Old 02-10-2014, 07:46 AM   #87
damaster32
Drives: 2014 BRZ Limited
Question, for install can someone tell me when parts from stock you keep to put on the coils? Same for rear?
damaster32 is offline   Reply With Quote
Old 02-10-2014, 09:43 PM   #88
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
3, 4, 5(two nuts), 9, 11, 13...and 12(or is it 2?...they're the 3 nuts to secure the top strut to the car).
Same for front/rear
The Following 3 Users Say Thank You to continuecrushing For This Useful Post:
coupeae86 (06-02-2014), LXXXV1 (11-29-2014), stevohl (03-17-2014)
Old 02-10-2014, 10:40 PM   #89
damaster32
Same for front/rear
Thanks,
I thought it was only 3,4,5, and 11, didn't know you had to use #9. I wanted to keep the stock suspension intact and just buy upper mounts all around.
Old 02-10-2014, 11:21 PM   #90
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
I believe #12 are the three bolts you re-use for the top hat to bolt to the frame (two for the rear). #2 is the top shock screw... you'll use the one that comes with the coilovers...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 02-15-2014, 03:30 AM   #91
NoVtec
NoVtec's Avatar
Hey guys,
If I were to run 17x9 +35 with 245/40-17 tires square,
would I be needing the camber bolts for my st-coils to set them up properly?
I love driving slow cars fast!
NoVtec is offline   Reply With Quote
Old 02-15-2014, 03:46 AM   #92
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Originally Posted by Subaru CBRZ 600RR View Post
The front is maxed out and the rear is about midway. I think you could technically take out the helper spring in the front to go lower though. I'm no expert, but it seems to me the helper springs aren't doing much of anything because they are fully compressed.
I did not adjust the perches from this before installing.
That's kind of the point. Helpers are not supposed to be uncompressed. They are there to keep compression when there is weight off of the wheel, such as when you are cornering hard. It prevents the springs from getting loose in the assembly. (bad explanation, but I'm sure you get it)
Old 02-15-2014, 12:32 PM   #93
jhstealth
Drives: 13 FR-s, 84 911
Did anyone get a pamphlet with theirs about setting the height to shock spec. The ones I have on my M3 had a sheet with all types of measurements for the highest and lowest you can set them within spec of the damper and how to measure before and after install. And yes these are kW v1 but just not stainless.
jhstealth is offline   Reply With Quote
Old 02-17-2014, 04:48 PM   #94
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Here it is:
The Following User Says Thank You to switchlanez For This Useful Post:
chanomatik (02-18-2014)
Old 02-17-2014, 05:06 PM   #95
switchlanez
About a month ago, I installed these with out-of-the-box settings of 0 turns/threads remaining in front and 15 threads (not sure exactly how many turns) in back. My fronts settled down around 8 mm and rears a little less. Today, I adjusted the fronts 3 full turns upward (exposing about 1.5 threads) and rears 1 full turn upwards (still about 15 threads) which brought the fronts up about 8 mm and rears up about 4 mm to compensate for the settling...
Factory wheel hub center to fender edge distance for front is 14 7/16" and rear is 14 5/8" which averages about 14.5" or 368 mm. I adjusted my coilovers to 333 mm. That's 35mm below stock height which is smack dab in the middle of KW's recommended 20-50 mm adjustment range. I'm locking this in and doing my 3rd alignment since I installed these coilovers and hopefully last one for awhile (glad I opted for Firestone's lifetime alignments option the first time I went).
Old 02-18-2014, 04:29 PM   #96
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Yeah I'm pretty sure I'm getting these. Thanks @switchlanez for your thorough research. You've helped me a lot in my decision-making processes. Once my bigger projects are revealed I'm definitely giving you a shout out in my build thread!
I also really appreciate everyone's pics!
The Following User Says Thank You to chanomatik For This Useful Post:
switchlanez (02-18-2014)
Old 02-18-2014, 07:35 PM   #97
damaster32
So I just got my ST's in today. Packaging from ST sucks. Coils were all over the place. So I gave a call to KW/ST to ask. Found out that the first sets of ST's were made/ assembled and packaged in Germany. Now they are made in Germany, assembled in USA and packaged in USA.
Old 02-18-2014, 07:36 PM   #98
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Yeah, figured as much. All that man-handling. Good to know, though, as I'm hoping mine make it to Alaska in one piece! Congrats btw.
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
RS*R Sports-i Coilover system installed (pics) R0ME0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 139 02-05-2015 03:38 PM
Pics of you!? Pics of your life?! seven Off-Topic Lounge [WARNING: NO POLITICS] 66 12-25-2012 04:49 AM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-11-2012 11:29 PM
