Old 02-09-2014, 06:52 AM   #1
350matt
Drives: toyota mr2/ Toyota GT86
EcuTek Live tuning - now available?
Chaps
take a look at this
[ame="http://www.youtube.com/watch?v=bB3PDkSqNo0"]EcuTek Live Tuning with Cosworth - YouTube[/ame]
350matt is offline   Reply With Quote
Old 02-09-2014, 07:32 AM   #2
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Yup, just need a 5v input into the evap and rear o2 sensor, and two custom racerom maps for both, good stuff. We used a recycled PC power supply, and then just put in two potentiometers
Xero-Limit is offline   Reply With Quote
Old 02-09-2014, 07:56 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Does this mean that I can already connect the output of my Failsafe Wideband to the rear O2 and be able to log it in a custom map?
Old 02-09-2014, 08:40 AM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
Looks like it.
http://us7.campaign-archive1.com/?u=...a&e=1803a1cb50
Rear O2 Sensor Voltage as an Input into Custom Maps
This additional input can be used for any number of options when you need a 0 to 5v input into Custom Maps.
Sportsguy83 (02-09-2014)
Old 02-09-2014, 10:52 AM   #5
Sportsguy83
Drives: Limited BRZ
Originally Posted by xjohnx View Post
Awesome!!
Now need @jamesm and/or @nelsmar or anyone else to tell me what pin (on the rear O2 plug) I need to connect to.
Old 02-09-2014, 11:00 AM   #6
jamesm
Awesome!!
Here you go... from page 48 of the ecutek docs. Get that thing wired in and it'll make both of our lives much easier
The Following User Says Thank You to jamesm For This Useful Post:
Old 02-09-2014, 11:10 AM   #7
Sportsguy83
Drives: Limited BRZ
Great! Was thinking doing it at the O2 connector (in the engine bay) so need to figure out which one there. Not to fond of splicing the oem harness
Old 02-09-2014, 11:11 AM   #8
jamesm
that is a far cry from live tuning... but it's a step in the right direction. i usually just use the map modes to load 4 different fuel or timing maps and switch between, which seems like a lot simpler way to gain most of the benefit. with the pots you'd have to go back in and blow away the custom maps, remove all the wiring, then restore whatever you had wired in before and all of the custom maps associated with them. a decent idea, but probably only for someone doing research work on an engine dyno or something like that.
Old 02-09-2014, 11:13 AM   #9
jamesm
Great! Was thinking doing it at the connector so need to figure out which one there.
oh yes... i'll see if i can find that for you. probably a cleaner solution. maybe even de-pin it and make it nice and reversible.
Old 02-09-2014, 11:14 AM   #10
Sportsguy83
Drives: Limited BRZ
Yes, that's what I'm thinking
Old 02-09-2014, 02:12 PM   #11
Sportsguy83
Drives: Limited BRZ
So from the wiring diagram:
This is the A34 connector, and we need to connect to pin 21:
Pin 21 takes signal from the C13 Rear O2 connector, blue wire (see below) #3 on C13
Finally, below is C13, the Rear O2 connector. I'm in the process of connecting the Failsafe White cable (analog AFR output) to pin #3 in C13.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
jamesm (02-09-2014)
Old 02-09-2014, 02:27 PM   #12
jamesm
sweet! i'll have a new rom with the scaling added in your email by the time you're done with that.
Old 02-09-2014, 02:51 PM   #13
Sportsguy83
Drives: Limited BRZ
This is the table AEM gives for output AFR vs. Volts.
Old 02-09-2014, 03:34 PM   #14
350matt
well the CPC pressure sensor input isn't used on most cars so you can leave that one wired in and as others have said you can run to the signal pin on the o2 sensor plug so its just a case of plugging that one in
so you can assign the two pots to different things on different modes
say mode 1 pot A does spark adding/ subtracting, and pot B swings the exhaust cam
then in mode 2 Pot A swings the inlet cam and Pot B swings the DI timing
in mode 3 Pot A swings the fuel target lambda
so you can map the car properly and quickly without having to stop and re-flash it all the time
so you only have to have 1 ROM version with all the pot tuning then when you're done flash back in the road version of the ROM not that much of a hassle really
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
Possibility of Live Tuning brn12345 Software Tuning 17 03-30-2020 04:39 PM
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
EcuTeK tuning available *BRZ & FR-S* Cotnoir Engine, Exhaust, Transmission 29 07-11-2012 07:15 PM
