| Software Tuning Discuss all software tuning topics. |
Drives: toyota mr2/ Toyota GT86
EcuTek Live tuning - now available?
Chaps
take a look at this [ame="http://www.youtube.com/watch?v=bB3PDkSqNo0"]EcuTek Live Tuning with Cosworth - YouTube[/ame] |
#2 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Yup, just need a 5v input into the evap and rear o2 sensor, and two custom racerom maps for both, good stuff. We used a recycled PC power supply, and then just put in two potentiometers
#3 |
I Love custom Turbo kits
Drives: Limited BRZ
Does this mean that I can already connect the output of my Failsafe Wideband to the rear O2 and be able to log it in a custom map?
#4 | ||
Grip>Slip
http://us7.campaign-archive1.com/?u=...a&e=1803a1cb50 Quote:
| The Following User Says Thank You to xjohnx For This Useful Post: | Sportsguy83 (02-09-2014) |
#5 | |
Drives: Limited BRZ
Now need @jamesm and/or @nelsmar or anyone else to tell me what pin (on the rear O2 plug) I need to connect to.
#6 |
| The Following User Says Thank You to jamesm For This Useful Post: | Sportsguy83 (02-09-2014) |
#7 |
Drives: Limited BRZ
Great! Was thinking doing it at the O2 connector (in the engine bay) so need to figure out which one there. Not to fond of splicing the oem harness
#8 |
that is a far cry from live tuning... but it's a step in the right direction. i usually just use the map modes to load 4 different fuel or timing maps and switch between, which seems like a lot simpler way to gain most of the benefit. with the pots you'd have to go back in and blow away the custom maps, remove all the wiring, then restore whatever you had wired in before and all of the custom maps associated with them. a decent idea, but probably only for someone doing research work on an engine dyno or something like that.
#9 |
#10 | |
Drives: Limited BRZ
#11 | |
Drives: Limited BRZ
This is the A34 connector, and we need to connect to pin 21: ![]() Pin 21 takes signal from the C13 Rear O2 connector, blue wire (see below) #3 on C13 ![]() Finally, below is C13, the Rear O2 connector. I'm in the process of connecting the Failsafe White cable (analog AFR output) to pin #3 in C13.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | jamesm (02-09-2014) |
#12 | |
sweet! i'll have a new rom with the scaling added in your email by the time you're done with that.
#13 | |
Drives: Limited BRZ
#14 | |
well the CPC pressure sensor input isn't used on most cars so you can leave that one wired in and as others have said you can run to the signal pin on the o2 sensor plug so its just a case of plugging that one in so you can assign the two pots to different things on different modes say mode 1 pot A does spark adding/ subtracting, and pot B swings the exhaust cam then in mode 2 Pot A swings the inlet cam and Pot B swings the DI timing in mode 3 Pot A swings the fuel target lambda so you can map the car properly and quickly without having to stop and re-flash it all the time so you only have to have 1 ROM version with all the pot tuning then when you're done flash back in the road version of the ROM not that much of a hassle really |
| Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps | DeliciousTuning | Software Tuning | 1213 | 06-17-2025 04:02 PM |
| Possibility of Live Tuning | brn12345 | Software Tuning | 17 | 03-30-2020 04:39 PM |
| Let's get tuning! EcuTek tuning now available! | carbonBLUE | Southwest | 6 | 06-29-2015 02:37 PM |
| EcuTeK tuning available *BRZ & FR-S* | Cotnoir | Engine, Exhaust, Transmission | 29 | 07-11-2012 07:15 PM |
