Old 02-04-2014, 10:16 AM   #15
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Originally Posted by mikalem View Post
Honestly I'm not sure - just trying to offer up as much as I can so you don't have the problem again. Honestly I think subaru got a bad batch early on in the run for these cars (mine was built Oct 2012) - that control unit I know of at least 4 different people that got it replaced. Not sure if it was still a problem for the others but mine was fine the second time around.
Sent from my SGH-M919 using Tapatalk
and you replaced all your lights to stock before going to the dealership correct ?
Do you think I have to remove my license plate leds as well ?
Also, do you think the dealership will blame you for aftermarket taillights or relay flasher ?
ucsmfu is offline   Reply With Quote
Old 02-04-2014, 10:27 AM   #16
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
I replaced the stock bulbs for the lights in the doors before I took it in, had LEDs in the overhead light and visor mirrors though - my dealership didn't make a huge deal about it. I didn't have led flashers yet so the relay wasn't changed either at the time. I would put the stock bulbs back in before you take it, just to avoid problems.
mikalem is offline   Reply With Quote
Old 02-08-2014, 04:00 AM   #17
Abdo
Drives: gt86
hi
is BIU same thing as ECU?
Thanks
Abdo is offline   Reply With Quote
Old 02-09-2014, 09:44 AM   #18
Dantical
Drives: Mr2 3S-GTE GEN 3 - GT86 MT
.. had the same issue here,.. Body Controll unit blew up,.. it is the main controll unit,.. the hole fusebox gets it signals from it! And when you produce a short cut while placing the leds in,.. the fuse does not blow, but some part in the Body ecu blows up,...
The Body ECU is providing GROUND to the bulbs,.. and when you get a short,.. the ground is not supported anymore,..
Dantical is offline   Reply With Quote
Old 02-10-2014, 02:05 AM   #19
Abdo
Drives: gt86
you right, Do have to replace ECU? Can be fix?
Old 02-10-2014, 08:39 AM   #20
buddy32
Drives: WRB Subaru BRZ Limited
No, the BIU is not the same thing as the ECU. It is a separate unit.
Please refer to the following link.
http://www.subaruforester.org/vbulle...ed-unit-41719/
buddy32 is offline   Reply With Quote
BRZ Driver's Door Courtesy Light Won't Work delusional Issues | Warranty | Recalls / TSB 31 05-29-2022 07:15 AM
Door lights on FRS DanoFA20 Scion FR-S / Toyota 86 GT86 General Forum 11 03-02-2013 09:05 AM
