#15 | |
Drives: BRZ Limited
Do you think I have to remove my license plate leds as well ? Also, do you think the dealership will blame you for aftermarket taillights or relay flasher ? |
#16 | |
Drives: 2020 DGM BRZ Limited
Sent from my SGH-M919 using Tapatalk |
#17 |
Drives: gt86
hi
is BIU same thing as ECU? Thanks |
#18 |
Drives: Mr2 3S-GTE GEN 3 - GT86 MT
.. had the same issue here,.. Body Controll unit blew up,.. it is the main controll unit,.. the hole fusebox gets it signals from it! And when you produce a short cut while placing the leds in,.. the fuse does not blow, but some part in the Body ecu blows up,...
The Body ECU is providing GROUND to the bulbs,.. and when you get a short,.. the ground is not supported anymore,.. |
#19 |
Drives: gt86
you right, Do have to replace ECU? Can be fix?
#20 |
Drives: WRB Subaru BRZ Limited
No, the BIU is not the same thing as the ECU. It is a separate unit.
Please refer to the following link. http://www.subaruforester.org/vbulle...ed-unit-41719/ |
| BRZ Driver's Door Courtesy Light Won't Work | delusional | Issues | Warranty | Recalls / TSB | 31 | 05-29-2022 07:15 AM |
| Door lights on FRS | DanoFA20 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 03-02-2013 09:05 AM |
