Old 02-06-2014, 02:45 PM   #169
JS + BRZ
Drives: 2010 MS3
Nevermind. Found the answer.
Roughly 2.6 for the tranny and 1.25 for the diff
The Following User Says Thank You to JS + BRZ For This Useful Post:
Khyron686 (08-10-2015)
Old 02-06-2014, 08:11 PM   #170
roddy
roddy's Avatar
Drives: '13 Ultramarine
Originally Posted by Sellout View Post
Not according to the people who make it.
Thanks for pointing that out. It must have been a recent change...the quarts I bought last summer all say 70W80 on the bottle.
Old 02-06-2014, 11:10 PM   #171
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Swapped out my transmission fluid at a little over 1k miles and now a little past 19k miles. Redline MT-85 seems to be holding up fine no issue with shifts and never had any gear issues whatsoever with the car, plug hardly had anything on it when it was changed. Differential changed at the same time as well, plug was really goopey and lot of small metallic flakes. Changed rear end fluid to Redline 75W85.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 02-07-2014, 11:56 AM   #172
kayoh
kayoh's Avatar
Drives: 2014 SWP Limited BRZ
What color was your stock transmission fluid when you changed it?
kayoh is offline   Reply With Quote
Old 02-07-2014, 07:45 PM   #173
Vracer111
Vracer111's Avatar
Basically a little darker than new fluid...still pretty fresh looking.
Old 02-07-2014, 08:02 PM   #174
Carban
Grease Monkey
Carban's Avatar
Drives: Whiteout FR-S
@Vracer111 I changed my transmission fluid today with Red Line MT-85 75w85 also. Im curious if you used the same Red Line 75w-85 for your differential?
Our rear diff's call for gl-5 fluid whereas the red line mt-85 is gl-4. (The red line mt-85 bottle also says "not suited for gl-5 required differentials")
Just wanted to give you a heads up in case you used gl-4 in ur diff.
R.I.P. '92 Honda Prelude you will be missed
Carban is offline   Reply With Quote
Old 02-07-2014, 08:53 PM   #175
Vracer111
Vracer111's Avatar
No, Redline MT-85 for transmission and Redline 75W85 gear oil for differential...
Old 02-07-2014, 09:55 PM   #176
wheelhaus
wheelhaus's Avatar
That happens intentionally. The box locks you out until the synchro has had time to speed up the input shaft and clutch disk when you're downshifting. Hold it there and you can hear things speed up, then it will drop into first...
That's the same mechanism that locks us out of second when the transmission is cold.
I want to clarify this as it's a bit misleading... The gearbox does not have any special mechanism that locks you out of any gears, anytime, ever, it doesn't exist. The effect of the thick cold fluid however, prevents the synchros from generating the necessary friction to do their job effectively. This results in what feels like a lockout, but it's just the synchros unable to do their job.
Upshifting quickly and relatively firmly helps to ensure you catch the next gear as the revs drop. The thick cold fluid will slow the transmission internals down much quicker than normal when you clutch in. Downshifting is much more difficult as the synchros need to speed up the tranny. Double clutching is the best way to get the cold tranny to cooperate.
If you slow shift and the tranny internal RPM drops too far, it'll feel "locked out". Engage the clutch in neutral and blip the throttle a bit higher than it needs to be for the gear you want, and then quickly clutch-in and shift into it; should drop right in. (This is the essence of double clutching, as it bypasses the synchro's friction function and instead uses the engine to speed up the transmission internals before engaging a gear).
The Following User Says Thank You to wheelhaus For This Useful Post:
mrha (02-08-2014)
Old 02-08-2014, 11:02 AM   #177
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
The whole idea of the synchronizer system is to delay the system from sliding the locking ring down onto the gear you're selecting until everything is lined up. When the synchro system is working correctly it stops you from selecting a gear until the synchro and locking ring line up. The teeth on the synchro and locking ring are stuck pushing against each other on the ramp faces instead of sliding down next to each other and engaging that locking ring. That's what you feel when you're locked out of gear.
The gear stack is turning because you're moving. The input shaft may slow down after the clutch is disengaged, and at that point the synchros are doing what they would be doing on a downshift, they're not suddenly obsolete because the input shaft slowed down a little faster than normal.
What I said was quick and dirty, but misleading? I think that's a stretch.
Sellout is offline   Reply With Quote
The Following User Says Thank You to Sellout For This Useful Post:
wheelhaus (02-08-2014)
Old 02-08-2014, 06:42 PM   #178
wheelhaus
wheelhaus's Avatar
Sounds like we're just arguing semantics. Didn't mean any offense, I just wasn't sure if you were using the word "mechanism" to literally mean an additional device inside the gearbox, or a descriptor of how the synchros operate.
Sellout (02-08-2014)
Old 02-17-2014, 01:12 PM   #179
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Read through this entire thread and still not sure when the general consensus is to change your trany fluid?
I've got 800 miles on my 14 brz and have seen a lot of you guys change at 1k. Manual says (I believe) 30k before the first change.
I know stock engine oil is specifically designed to help break in the engine, and therefore changing it early will do more harm than good. Is it possible the stock tranny/diff fluids are meant to help break in the tranny/diff as well?
Also, does anyone know what other cars have the same trannies as our 86's? If we could find cars that have been around longer with the same tranny, we might be able to find more information about what long-term effects different fluids will have on ours.
xxBrun0xx is offline   Reply With Quote
Old 02-18-2014, 12:38 AM   #180
edsbreezy
edsbreezy's Avatar
Drives: 2014 Subaru BRZ Premium - Red
I'd like to know as well, I just changed my oil at 1500 miles on my 2014 today and did it since i've always changed it on or at around 1000 miles on my last 3 new cars. i've been reading through a lot of threads and am curious to know what the general concensus is on changing transmission and differential fluids. i'm looking at getting a short shifter, bushing, and mtec springs and figured i would change the fluid then.
edsbreezy is offline   Reply With Quote
Old 02-18-2014, 06:38 AM   #181
xxBrun0xx
xxBrun0xx's Avatar
Found this with regards to what fluid we should be using:
http://www.ft86club.com/forums/showthread.php?t=16604
Cliff notes, since I read the whole thing: Use Pentosin mtl 75-80 for your transmission, Motul Gear 300 GL4/GL5 75W90* for your rear diff. Alternatively, apparently Nissan dealerships stock stuff that is 100% identical to pentosin for a fraction of the price, although I haven't taken a trip my local dealer ship to get a part number for that yet.
Sent from my XT1053 using Tapatalk
The Following User Says Thank You to xxBrun0xx For This Useful Post:
chas3wba0 (03-28-2014)
Old 02-18-2014, 03:45 PM   #182
krulux
Drives: 2013 Scion FRS
Unless you are having real shifting trouble - i.e. grinding noise/feel between shifts then more than likely you are safe to wait until the first scheduled tranny/pumpkin fluid inspection.. which is 30K I believe.
That said, there is nothing wrong with being proactive and replacing with a quality solution as many here suggest.
Me personally, as I ramp up to a forced induction application.. and the prospect of upgrading the clutch comes into play - I'll be changing the fluid in my car at that time
krulux is offline   Reply With Quote
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
