Old 01-21-2014, 11:18 AM   #43
kuhlka
Drives: 2013 BRZ Limited AT
Originally Posted by Blackdragon View Post
Good to hear about this TSB.
Less than a month ago I scraped all the ice off my window. opened the door and closed it.
Out of the corner of my eye I saw a thin black strip appear on my window.
I realized what it was and squealed like a little girl.
The felt on the weather strip all ripped off the rubber and stuck to my window.
I scraped them off the window and saved them for my dealership to look at.
I've had the exact same problem, but nowhere near as bad. I hope this TSB completely replaces those strips.
kuhlka is offline   Reply With Quote
Old 01-21-2014, 11:27 AM   #44
Muskokan
Drives: white Sport-tech
hey guys if weve got a scratch going down the length of the window because we lost the felt strips can we go after them to fix this? and i read this this quick and didnt see an answer to the question
Is there a subaru tsb? part number? something to give them when most every brz owner tries to get a subaru dealership to do something, ANYTHING
Muskokan is offline   Reply With Quote
Old 01-21-2014, 11:28 AM   #45
HunterGreene
Hail Magnet
HunterGreene's Avatar
Should be covered under your bumper-to-bumper warranty, if you still qualify for it.
It has priests in it?
Old 01-21-2014, 11:34 AM   #46
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I asked about this at my dealership but they told me they haven't received the replacement parts yet.
Nevermore is offline   Reply With Quote
Old 02-06-2014, 10:54 AM   #47
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Any updates on the Subaru TSB or perhaps a link to the document? After the freeze in Tennessee last week I'm having issues now...
Subaru STI :
Old 02-06-2014, 12:46 PM   #48
Here ya go.
Kimsey47 (02-06-2014)
Old 02-06-2014, 01:08 PM   #49
Kimsey47
Kimsey47's Avatar
Here ya go.
Thanks, but I was hoping for a Subaru letterhead... I have the Scion copy from the inital post but I'm not sure the idiots at my local service would understand that its the same #### car!
Subaru STI :
Old 02-06-2014, 01:43 PM   #50
Maybe just white out the "Scions" and print in "Subaru"....??
OR, if Bubba down at the dealership, can't make the leap from Scion to Subaru ..... maybe you don't want him messen wich your car's windows .....
Old 02-06-2014, 01:56 PM   #51
Kimsey47
Kimsey47's Avatar
Yeah... If only I'd bought a Fox body Mustang...
Subaru STI :
The Following User Says Thank You to Kimsey47 For This Useful Post:
humfrz (02-06-2014)
Old 02-06-2014, 04:35 PM   #52
andrew20195
Drives: 2013 Subaru BRZ
FYI, Subaru updated their version of this TSB with new part numbers as of 1/28/14.
Originally Posted by NOHOME View Post
I have the situation where, in cold weather, the door glass jig where it goes "down-up" as you open and close the door, get abbreviated to "down and stay down".
Unfortunately, this appears to be a "safety" feature built in to the window indexing. There is a note about it in your owner's manual. However, with this fix, it looks like they reduced the distance the window drops, so it should seal better when it's frozen.
andrew20195 is offline   Reply With Quote
Old 02-06-2014, 04:42 PM   #53
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Anyone else get their weather stripping strip away?
It's almost the entire length of the seal and it'll suck the stripping in when it's wet or cold. The motor itself is fine.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 02-06-2014, 04:57 PM   #54
tinma
Drives: '13 BRZ
dont have the link to the TSB but the TSB # is 07-79-13
I actually gave that # to my dealership and now my car is going in for it tomorrow to be replaced.
tinma is offline   Reply With Quote
The Following User Says Thank You to tinma For This Useful Post:
Old 02-06-2014, 07:10 PM   #55
Kimsey47
Kimsey47's Avatar
Thanks, sounds like that's what I'll try. Probably a good test for a different dealer since mine sucks so bad to see how they take care of it.
Subaru STI :
Old 02-07-2014, 10:24 AM   #56
andrew20195
That is one of the issues covered by the TSB.
The Following User Says Thank You to andrew20195 For This Useful Post:
slicktop (02-07-2014)
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Windows freezing in the winter. Garstang CANADA 26 11-15-2013 10:14 AM
Windows freezing in the winter. Garstang Scion FR-S / Toyota 86 GT86 General Forum 9 10-23-2013 07:07 PM
summer or all-season tires? freezing temps? rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 04-07-2013 01:11 PM
Windows freezing? L3P47 Scion FR-S / Toyota 86 GT86 General Forum 11 12-22-2012 12:49 PM
