Old 01-20-2014, 04:33 PM   #29
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
And I also agree that the car shoudld not know that the alignment is messed up UNLESS it changed the spacing between the ABS sensor and the wheel.
This makes no difference; the ABS sensor reads off teeth that is cast into the hub assembly.
It doesn't matter if you run +100 offset or -100 offset wheels, there is no way the car will know what wheels you have on the car unless you have physically swapped out the hub assembly.
-alex
Old 01-20-2014, 04:35 PM   #30
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
-alex
if I took my car to the dealer tomorrow, would they possibly void my warranty or will they simply turn me away?
Eelusive is offline   Reply With Quote
Old 01-20-2014, 04:36 PM   #31
Pneub
Drives: Dark Grey BRZ
Originally Posted by Eelusive View Post
Why would they void my warranty?
I'm not sure if this would affect your warranty or not (seems unlikely but it could depend on the dealership) but they'd charge you a lot of money to do something you can do for cheaper.
Pneub is offline   Reply With Quote
Old 01-20-2014, 04:44 PM   #32
mav1178
mav1178's Avatar
The warranty is never void, however they can deny to cover repairs under warranty.
-alex
Old 01-20-2014, 04:46 PM   #33
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
Well I guess we'll have to see.... its 175 for a speed sensor but we don't know which one it is. My speedo doesn't work and my fuel gage is acting up. I think it was throwing up a instrument cluster code as well.
Old 01-20-2014, 04:49 PM   #34
Pneub
Try and swap with a local to see if it fixes your problem. Should only take a few minutes.
Old 01-20-2014, 04:52 PM   #35
mav1178
mav1178's Avatar
Your issues sounds bigger than a simple "sensor"... if I were you, I'd put the stock suspension back on and get the car serviced.
-alex
BRZ21 (01-21-2014)
Old 01-20-2014, 04:54 PM   #36
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
Wish I knew someone willing
Old 01-20-2014, 05:22 PM   #37
ubersoph
I had this problem after installing my ground control coilovers and rear LCAs. It went away after a (very precise) alignment.
If you're still having trouble after an alignment then maybe something is wrong with the speed sensor, but make sure the toe and camber are even before you assume something else is broken.
ubersoph is offline   Reply With Quote
The Following User Says Thank You to ubersoph For This Useful Post:
HATED1 (01-20-2014)
Old 01-20-2014, 05:37 PM   #38
stugray
Drives: 2013 GBS BRZ Limited
That is what I meant. They either damaged the sensor or somehow moved them so they cannot "see" the teeth in the hub. The sensor has to be very close to the teeth to sense them.
As others posted, it will not "void" the warranty.
If you say: "I had these guys put coilovers on and they must have broken my speed sensors, will you replace them for free? "
What do you imagine they will say?
Old 01-20-2014, 05:43 PM   #39
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
Well guess I'll have to see tomorrow... If the dealer doesn't do it then the shop has agreed to pay for the expenses and do the work.
Old 01-20-2014, 05:58 PM   #40
Pneub
If you had this done at a shop they should be taking care of this without you needing to go to a dealership.
Old 02-05-2014, 06:19 PM   #41
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
P.S. This has been resolved. Both rear abs sensors were replaced. Car is back to normal ��
Old 02-06-2014, 10:28 AM   #42
stugray
Did the dealer do it under warranty, or the guys who broke them?
Door Unlocked dash light coming and going after installing subwoofer tbertran Electronics | Audio | NAV | Infotainment 0 01-01-2014 10:22 PM
BEWARE when installing aftermarket tail lights, you must seal the area ! Kayzer Soze Cosmetic Modification (Interior/Exterior/Lighting) 5 08-27-2013 01:52 PM
All RED interior dash lights and hvac ? Mrqb22 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-05-2013 09:41 PM
Holy crap tail lights!! raul Cosmetic Modification (Interior/Exterior/Lighting) 9 10-05-2012 07:11 PM
HELP!!! FR-S Shutdown all lights on the dash came on!!! tric Scion FR-S / Toyota 86 GT86 General Forum 64 09-15-2012 02:57 PM
