Old 08-26-2013, 01:31 PM   #1
Kayzer Soze
Drives: 2013 BRZ 6MT Satin White Pearl
BEWARE when installing aftermarket tail lights, you must seal the area !
Just a heads up, i installed Collins tail lights a couple months back, and i probable should have had the common sense to notice this when installing, but there is no gasket on back of the light sealing the holes that lead to your trunk....
a few bad days of rain will lead to what you see below, water pretty much flows through the trunk. thanks go i had no damage to the car or wiring, but had i not noticed this sooner, the 2 inches of water wouldve been 2 feet!
solution, i got sealing tape used mainly for windows and joints on the house, i bought a compressed roll which expands up to 1/2 inch in thickness to fill gap, and applied two layers as seen in photo, it wont expand since being comrpressed between the light and the body (they sell a thicker version that expande to an inch, using that would avoid needing a double layer)
after application, i tested it and it seems to have sealed off the trunk
Kayzer Soze is offline   Reply With Quote
Old 08-26-2013, 02:54 PM   #2
djdnz
1337
Drives: 2013 BRZ WRB S/C
Wow that's a lot of pooling water. The valenti's come with a seal.
djdnz is offline   Reply With Quote
Old 08-26-2013, 07:47 PM   #3
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
Yeah good thing the valenti had seal.
Minovsky is offline   Reply With Quote
Old 08-27-2013, 11:44 AM   #4
Mitch
form follows function
Drives: RIP '13 BRZ
TOM'S has a gasket/seal comparable to the stock unit.
Mitch is offline   Reply With Quote
Old 08-27-2013, 12:12 PM   #5
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Yeah Colin's are the only aftermarket tails I've personally seen that do not come with a gasket. I ordered a set of stock gaskets from my Subaru dealer for that very reason, but yeah I would never install a tail without one for obvious reasons and your pics prove that.
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 08-27-2013, 01:52 PM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
I used these when replacing my OEM lights with red painted OEM lights:
http://gasketninja.com/
Just bought these aftermarket tail lights BuBlake Cosmetic Modification (Interior/Exterior/Lighting) 282 05-12-2014 10:01 AM
FS: OEM Tail lights (OC Area) WRB5titch Exterior Parts (Aero, Lighting, Etc.) 3 09-26-2013 09:48 PM
Q for those w/ Spyder aftermarket tail lights Iddoit2er Cosmetic Modification (Interior/Exterior/Lighting) 2 08-03-2013 06:23 PM
FS: Aftermarket tail lights, stock sway bars, etc Zangetsu Australia Classifieds 19 02-16-2013 01:34 AM
