Old 02-02-2014, 03:18 PM   #3123
Powersfrs
Drives: Frs
Sorry I'm a noob at this!!!...so will I feel the torque if I'm driving normal n shifting around 3300~ Or will I only feel it when I'm at wot
Powersfrs is offline   Reply With Quote
Old 02-02-2014, 03:32 PM   #3124
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
You will only get more power over stock when the recirculating valve closes.. This is only dependent on throttle position. NOT RPM.. I don't know what % of throttle will start to close the bypass valve and boost will be generated (maybe around 1/4 to 1/5). You CAN build boost at idle. but you don't have to.. that is the point i am trying to make..
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 02-02-2014, 03:54 PM   #3125
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
This explains exactly why I feel what I would call a "hesitation" around 3k under 1/4 and increasing throttle input. It has to be the bypass valve closing and going into boost. I know it's not the tune....delicious tuning is excellent.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 02-02-2014, 04:05 PM   #3126
calispec
calispec's Avatar
I am tuned by delicious as well. I don't have much of a hesitation at all. But it might have something to do with it. Make sure you have the most recent tune by him. The intercooler may help because it displaces some of the volume that would need to be compressed.
www.GT86Mounts.com
Old 02-02-2014, 04:12 PM   #3127
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
^^ I had this issue for the longest time. Revised ROM from Toni at FA20club took care of it now. Car down low drives like it did stock.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-02-2014, 08:37 PM   #3128
evan
Drives: fr-s
Originally Posted by Boxer486 View Post
Who? Anyone at a a stop sign or light. Or anyone not wanting to fuck up their engine before the thermostat opens. That's who. Good you answered your own question. You obviously haven't looked at a lot of supercharger dynos compared to stock below 2.5-3k. Read some of the impressions of some supercharger installations having lag. While a well dialed in tune can help, I'm not sure it will always be the fix for such issues. Believe me, I don't need a lesson 101 from you about a twin-screw lysholm positive displacement compressor or any forced induction methodology. If I did, I would have asked so don't be so flippant in your response.
My, a bit touchy aren't we? Lol
evan is offline   Reply With Quote
Old 02-03-2014, 10:03 AM   #3129
swift996
swift996's Avatar
I bought a flowmaster cat-back and will install and hit the dyno (hopefully before the weekend).
For those interested in the boost plot, this is on e85 with the 72.5mm pulley (intercooled)
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-03-2014, 11:44 AM   #3130
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
72.5mm gave me 10.8psi on 91oct. So the kits are performing pretty much on par
Ryan86 is offline   Reply With Quote
Old 02-03-2014, 12:00 PM   #3131
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Originally Posted by evan View Post
Noticed too. @stockysnail Might wanna have Bobby check that out. Mine is flat across the powerband.
@NickFRS -- when Bobby retuned your car did they charge you for the dyno time? He just put a new tune into my car, but they didn't throw the car on the dyno after... which seems really strange to me.
Old 02-03-2014, 02:44 PM   #3132
swift996
swift996's Avatar
Again! WARNING on those supplied bolts. Opened my hood to check my coolant level and two of the bolts broke. The tops just came right off. They were properly torqued.
Old 02-03-2014, 02:55 PM   #3133
Boxer486
Drives: small
Ouch! They should be supplying those higher grade bolts with the black oxide finish at a minimum. Thermal change and vibration must be too much.
Boxer486 is offline   Reply With Quote
Old 02-03-2014, 03:01 PM   #3134
TemeCal
Drives: 86
I have two that broke off as well. In fact, one of them is the same bolt you had snap.
Let me know how successful you are extracting the bolt. I've been putting off extracting them.
TemeCal is offline   Reply With Quote
Old 02-03-2014, 03:16 PM   #3135
Ryan86
Road Warrior
Ryan86's Avatar
I mentioned this problem awhile back, got told I over tightened.
I replaced all the bolts with black high tensile as Boxer 486 picture. Especially the pulley nuts, which I've snapped 2 with changing pulleys.
My mechanic used a hex head, knocked into the broken bolt and came out easy.
Old 02-03-2014, 03:17 PM   #3136
swift996
swift996's Avatar
Also FWIW, I tried to merge two logs I captured from EcuTek on some pulls with the 72.5mm (intercooled) and the 75mm (non-intercooled), take it with a grain of salt:
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
