Old 02-02-2014, 05:11 PM   #57
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by solidONE View Post
@shiv@vishnu , was the cold cranking enrichment changed on the 1.55b from the 1.42b E85 roms?
I don't believe so.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
solidONE (02-02-2014)
Old 02-02-2014, 07:24 PM   #58
steve99
Drives: FT86
Originally Posted by shiv@vishnu View Post
I don't believe so.
Did you get a chance to include the XDF's in the 1.55 download ??
Old 02-02-2014, 07:51 PM   #59
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
@shiv@vishnu I'm on the v1.55b map for Stg1 B01D. The advanced multiplier isn't be read. It stays at 0.
Sent from my XT912 using Tapatalk
Terrapin77 is offline   Reply With Quote
Old 02-02-2014, 09:24 PM   #60
steve99
Drives: FT86
Pretty sure the IAM monitoring only works in USA ROM's.
Its a planned update
You can look at the "Kc learned" to determine if there is knock, it should track the values in the "Advance table" for logged RPM/LOAD if IAM is 1 and little or no knock detected
Old 02-02-2014, 09:30 PM   #61
Terrapin77
Terrapin77's Avatar
I live Atlanta so I can assure you I have a USA ROM.
The Following User Says Thank You to Terrapin77 For This Useful Post:
steve99 (02-03-2014)
Old 02-02-2014, 10:01 PM   #62
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
shiv i noticed some minor exhaust cam changes reducing aggressiveness, are these for power or saftey reasons? also i tryed playing with intake cam timing by advancing it a bit at higher rpm but data logs show the ecu ignores me and retards the intake cam anyway. near 6500rpm +
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 02-02-2014, 10:03 PM   #63
Victor Draken
Drives: Toyota Gt86
so EU ppl can't monitor IAM with OFT?
Victor Draken is offline   Reply With Quote
Old 02-02-2014, 10:06 PM   #64
Shiv@Openflash
Drives: 2013 FRS
Correct. Adv Mult is not log-able in the brand new B family USDM and some non-USDM ROMs yet. All ROMs will have it supported with the next data-logging update.
Old 02-02-2014, 10:18 PM   #65
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
give me a second opinion on my datalog? the fuel trims look good, advance multiplier is at 1, KC matches up with the values on the RPM vs Grev table. AFR looks a tad rich maybe?
http://www.datazap.me/u/andrew5826/o...0&data=1-2-4-8
andrew5826 is offline   Reply With Quote
Old 02-02-2014, 10:26 PM   #66
Shiv@Openflash
Drives: 2013 FRS
Definitely rich. How long have you driven on the new flash before you data logged. Looks like it may not have had enough learning time.
Shiv
Old 02-02-2014, 10:28 PM   #67
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
Shiv
datalogged 50km or so after flash. will i notice a bump in power after some learning time?
Old 02-02-2014, 10:41 PM   #68
Shiv@Openflash
Drives: 2013 FRS
Definitely needs more learning time than that. I'd datalog after at least 100km and see how things look. These engines don't really lose much power from running too rich so don't expect a big bump in power from hitting the desired AFR targets. But it should feel a bit better when that happens.
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
andrew5826 (02-02-2014), Burn (02-02-2014)
Old 02-02-2014, 10:44 PM   #69
Shiv@Openflash
Drives: 2013 FRS
UPDATE: G and J series Rom Raider XML files (with Flat-Foot Shift and Launch Control) are now available for download. Just click on the RomRaider XML link in the Downloads section of our website.
steve99 (02-03-2014), vynervt (02-02-2014)
Old 02-03-2014, 12:49 AM   #70
1086
1086's Avatar
Drives: UM86 - 6MT
Alright Shiv - here is my second run attempt for the v1.55. I re-wrote the "Stg2 EL E85 A01C.bin" and the results: http://datazap.me/u/1086/second-run-...el-e85-a01cbin
1086 is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
