Old 01-22-2014, 04:45 PM   #85
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by taiquach View Post
thank for reply shiv. you're right,my unit does not come with preloaded maps. anyway with the help of my brother, I was able sorted through. flashed with stage 1,car run so good and smooth and it really come alive when hit 4k rpm and up. after the test drive I hook up the oft to check out real time data feature, I found that the iam and kc learn remain 0 all the time. what should I do to make it work ? THANKS
Glad you hear you got it all sorted out We will be adding additional datalogging support for all ROM types in the next big datalogging update that we are working on how. Don't have an ETA just yet. It's a pretty big undertaking but we are doing what we can to speed things up.
Shiv@Openflash is offline   Reply With Quote
Old 02-01-2014, 08:03 PM   #86
tonylop33
Certified Car Nut
tonylop33's Avatar
Drives: 2013 BRZ WRB Limited 6MT
I tried the DEV file method and decided I wanted to go back to the old way. Now I can't save my bin files. I get an error message when I try to create a backup of the bin files. Any ideas?
Prior cars: 2011 GT-R (still owned), 2007 Saleen Parnelli Jones Mustang, 2007 Mini Cooper S, 2004 MazdaSpeed Miata Turbo, 2003 G35 Sports Coupe, 2002 WRX, 2001 Z28 SS, 2000 300ZX, 1995 BMW M3, 1882 Nissan 280ZX, 1981 RX7, 1978 Camaro Z28, 1968 Shelby GT 350
tonylop33 is offline   Reply With Quote
Old 02-01-2014, 08:10 PM   #87
Shiv@Openflash
Drives: 2013 FRS
No need to do a back-up since none of the ROMs have any unique vehicle data (vin number, etc,.) And there is a bug in the newest OF Manager software that prevents back-ups anyway. When you generate tune ROMs using the .dev file, they cannot be saved/downloaded from the OFT. Just upload files normally and they will over-write the .dev generated ROMs.
Old 02-01-2014, 08:14 PM   #88
tonylop33
Certified Car Nut
tonylop33's Avatar
So how do I save a copy of the original ROM that came with the car? I would like to have it someplace in addition to on the OFT.
Old 02-01-2014, 08:25 PM   #89
steve99
Drives: FT86
use the "download" option in Open flash manager software
Old 02-01-2014, 08:29 PM   #90
tonylop33
Certified Car Nut
tonylop33's Avatar
That is how I have done it in the past. Now it says "downloading error" when I try. I think that is the glitch Shiv referenced above. I am trying to find a work around.
Old 02-01-2014, 08:43 PM   #91
steve99
Drives: FT86
Only thing left to try would be
Write stock ROM back to car
Erase OFT with OFM software
Read stock ROM again
Save stock ROM
Load up .bin tunes
tonylop33 (02-01-2014)
Old 05-07-2014, 02:46 PM   #92
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Just received my OFT and I plugged it in and saved my stock tune(like the YouTube video) but its not letting me write files. What could be the problem?
Juanito08 is offline   Reply With Quote
Old 05-07-2014, 03:01 PM   #93
steve99
Drives: FT86
Usually this means your car's Rom is either unknown type or you Rom was not completely stock. Ie some other tuning device such as ecutek / brzedit has been used previously.
if so try erasing the mod file database tunes and load up .bin tunes it should write those
Old 05-08-2014, 12:59 AM   #94
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Usually this means your car's Rom is either unknown type or you Rom was not completely stock. Ie some other tuning device such as excited has been used previously.
Turned out I got an OFT with no pre-loaded files, just download the files from there website.
Old 05-08-2014, 01:07 AM   #95
Shiv@Openflash
Drives: 2013 FRS
Do you know the Calibration ID? Any previous tune?
Old 05-09-2014, 10:48 PM   #96
phrosty
Has anyone flashed back to stock and taken their car in for a flash from dealer?
Interesting experience tonight. Took my car back in for 15k service, and in the meantime inquired about the idle drop TSB. I watched them try to flash it for a little over an hour and the software kept coming up with an "unable to communicate with ECU" error. I'm going back in on Monday for them to try and diagnose the issue.
This was their first time trying to flash an FR-S. It could be an issue on their end. I do, though, wonder if it's an issue OFT could have caused -- anyone else done this successfully?
phrosty is offline   Reply With Quote
Old 05-09-2014, 11:14 PM   #97
steve99
Drives: FT86
If you can read and flash your ecu with your OFT then all is ok.
If you carn't after the dealer has touched it check the fuse for the 12v supply to the obd port .
OFT tunes do not lock, encrypt change seed keys or change anything to do with flash process.
The dealer gear is either crook or they are "wombats"
Old 05-10-2014, 05:21 PM   #98
phrosty
OFM 1.08.0, hmm
Key FOB programming milkesfrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 10-21-2015 03:56 PM
Anybody have any experience programming MiniDSP? mid_life_crisis Electronics | Audio | NAV | Infotainment 2 12-02-2013 09:07 AM
