Old 03-05-2012, 06:03 PM   #71
OrbitalEllipses
Drives: Attitude
Originally Posted by cyde01 View Post
if it's laughable why are you still here and why are you still a sucker for this car? what's truly laughable is subaru was just gonna stick the fb20 in there as is until tada insisted on something more powerful, which led to the fa20 being built from scratch.
Because I can appreciate this car in its whole, which requires an understanding of its shortcomings as well.
Old 03-05-2012, 06:08 PM   #72
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
ok whatever floats your boat, but don't be surprised if not everyone sees 150 lb/ft of torque as a shortcoming the same way you do. yes in an ideal world i would like more torque, hp, 500lbs lighter weight and a $50 msrp. but it ain't gonna happen, and i for one am gonna at least test drive the car before i complain about a weak low end/mid range.
cyde01 is offline   Reply With Quote
Old 03-05-2012, 06:16 PM   #73
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
My spec.B gets up and goes, and this will be quicker (post-launch). I don't think I'm going to be worrying too much about the available power.
Old 03-05-2012, 06:26 PM   #74
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by serialk11r View Post
For you, I'd think that the bigger problem would be the very fast drop off in torque below 3000rpm...it will probably feel slower than your RSX there if I remember how the RSX is geared correctly... the dip in the middle isn't that big.
That's the price of high revs, fixed cam profile. I'm happy about it, because the mpgs should be better :P
the drop isnt that bad, and that drop a "boxer thing", most 4 banger boxers have the dip at 3000 rpms due to header design and is, that is the NA boxer engines
its been explained in another thread... :/
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 03-05-2012, 06:29 PM   #75
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Compromises are made into every car but for some people it isn't a compromise. To each his own. Every car I wanted to own had a compromise or two but I can still appreciate all of them.
370Z- No back seats
GC 3.8 Track -250 lbs to heavy at 3,472 lbs(I wish it was 3200 lbs)
S2K- No back seats and high revving is where the real power lies
FRS- ? TBD.
Aventador - Too expensive..
M3 - maintenance sucks and weight is 250 lbs to heavy
I could go on but I love all those cars and more.
SUB-FT86 is offline   Reply With Quote
Old 03-05-2012, 07:08 PM   #76
MrBonus
MrBonus's Avatar
Drives: 2012 Boss Laguna Seca
Originally Posted by SUB-FT86 View Post
Its funny you say that yet you own a 2012 Boss. I think 444hp is way too much for the streets and you could've gone with a 305 hp v6 with the sport package. To me your post seems like a contradiction.
I agree. The Boss is largely too powerful and too grippy on the street which is why I bought it for track events. While I will probably do a few errant HPDEs with the BRZ, I look forward to a small, pleasant car for daily driving and cruising.
2012 Jeep Wrangler
2012 Ford Mustang Boss Laguna Seca
2013 Subaru BRZ - On Order
MrBonus is offline   Reply With Quote
Old 03-05-2012, 07:18 PM   #77
serialk11r
Drives: '06 AM V8V Coupe
lol, reread my post, I said below 3000. The dip on this engine is at ~4000, because of the intake manifold probably. Below 3000 the torque is shitty because the cam is way too big for good VE.
Old 03-05-2012, 07:33 PM   #78
carbonBLUE
Reverse Burnouts
yeah i looked at it again my bad but yeah below 3000 sucks just cause its 4 cylinder, plain and simple, a small cam would result in a poor top end :/ and i like good top ends on my engines
(wont forget you)
2011 Infiniti G37x
Old 03-05-2012, 07:54 PM   #79
spin9k
spin9k's Avatar
Drives: RX-8
Speed/ Power at the wheels/ Power at the engine
35 mph 8 hp 9 hp
60 mph 20 hp 23 hp
80 mph 38 hp 44 hp
100 mph 64 hp 75 hp
120 mph 102 hp 119 hp
140 mph 152 hp 178 hp
160 mph 220 hp 257 hp
180 mph 304 hp 356 hp
200 mph 409 hp 479 hp
220 mph 537 hp 628 hp
250 mph 776 hp 908 hp
My 8 has 232HP / 159ft-lbs and it's top speed is speced @148mph. It would take the salt flats and a qtr tank of gas to get going that fast lol. I was't using any real numbers, just showing how a 350HP car can pass another lower HP car at higher speed becuase of available HP.
However you slice it, lower p/w ratio cars hit the drag wall faster than those with excess HP to use. And that typically means lower useable top end.
spin9k is offline   Reply With Quote
Old 03-05-2012, 10:19 PM   #80
tachi1247
tachi1247's Avatar
Drives: 04 BMW 330i & 03 Mazdaspeed Protege
Originally Posted by fatoni View Post
Why do you drive a protege?
because buying a house was more important than spending the cash on a g35 which is what I wanted at the time. My protege also has slightly more torque that is available at a lower rpm and weighs almost the same as this car will so I have experience driving a car with an almost identical p/w ratio.
Originally Posted by MrBonus View Post
Why? Where do you "need" that additional horsepower?
daily driving. It would be nice not to wind it out to 6000 rpm to feel like I'm in a sports car. A very small percentage of these cars will actually see time on the track so any justification that the car will have all the power it needs on the track is bs.
+1. I may still buy one after I drive it, but I know right now I would have a deposit down already if it had 270 HP & 220 ft-lb.
tachi1247 is offline   Reply With Quote
Old 03-05-2012, 10:24 PM   #81
OrbitalEllipses
Drives: Attitude
230/190 or 250/200 would have this car on my driveway with a $1k markup.
Old 03-05-2012, 10:26 PM   #82
FRSDREAMER
FRSDREAMER's Avatar
Drives: 2013 FRS (hopefully)
Hey Man, if you don't mind me asking....
What do you do for a living?!
FRSDREAMER is offline   Reply With Quote
Old 03-05-2012, 10:29 PM   #83
serialk11r
You like peaky low end turbo torque? 230/190 can only come from a turbo that makes power early (aka chokes off high rpm), or a poorly tuned 2.7 ish liter which will feel barely faster.
I have a feeling picking up about 10-20hp shouldn't be too hard on this motor given how it just dies after 7000. More than that will take some work.
Ideally, if I had a good amount of cash to throw around I'd like to see a 9000rpm redline 2.0L, with extensive weight reduction so it has about 1hp/10lb, so people driving giant displacement cars can't laugh at it lol. I figure a variable intake should be able to improve the low end performance a little bit.
Old 03-05-2012, 10:42 PM   #84
tachi1247
tachi1247's Avatar
I'd be willing to pay $35k for a limited trim with the power figures I listed. Another reason I'm waiting...still think an sti version with the upcoming wrx engine is on the horizon.
Question jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 9 10-23-2020 11:31 AM
Question about the nomenclature.. RadOnc Scion FR-S / Toyota 86 GT86 General Forum 46 12-14-2013 11:55 PM
Stupid Question Canibuz Engine, Exhaust, Transmission 24 03-05-2012 09:50 AM
Engine Question alex05 Engine, Exhaust, Transmission 4 02-21-2012 06:08 AM
