AVOturboworld
Old 01-31-2014, 01:22 AM   #2787
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
That exhaust looks nice!
Old 01-31-2014, 01:24 AM   #2788
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@AVOturboworld is it only me or does the exhaust seem to have bends and tapering from a 3" to smaller ?
Sent from my IBrick
Old 01-31-2014, 01:24 AM   #2789
SmsAlSuwaidi
Boosted
Sent from my IBrick
Old 01-31-2014, 12:01 PM   #2790
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Originally Posted by GT86-Ian View Post
Steve from what I know all new Forester gaskets were used, didn't expect them to fail at the first test & on a wet track.
What exhaust do you have on your car?
We do not recommend tracking your car on stock exhaust as it will build up to much back pressure and heats up the gaskets.
Also did you check to see if the bolts were tight before starting. From the sound of your post you had a shop do the work, if so did they check every bolt before install. AVO does a great job assembling this kit, but you should always double check.
DAMotorsports is offline   Reply With Quote
Old 01-31-2014, 12:10 PM   #2791
DAMotorsports
Originally Posted by AVOturboworld View Post
Pictures of the new 3-inch exhaust system - a finished version was fitted for fitment check.
i now have a huge puddle of drool on my desk!
Old 01-31-2014, 12:10 PM   #2792
DAMotorsports
any pics or the clearance for the 3" over pipe?
Old 01-31-2014, 12:53 PM   #2793
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
this.
And dammit, please put me on the list to get this full setup. I need the upgraded turbo and parts from you guys.....killing me here.
gdrider77 is offline   Reply With Quote
Old 01-31-2014, 01:36 PM   #2794
AVOturboworld
Sent from my IBrick
Just the cheap P&S they are using to shoot the pictures with, there's a lot of distortion at the edges.
Old 01-31-2014, 01:39 PM   #2795
AVOturboworld
Not good shots - in the next week or two, I'll get a set over to fit while taking pictures + video of the install.
It's tight, no argument there, and we do certainly suggest (strongly) putting in harder engine mounts at the same time. The reason it's going to be sold as an overpipe/frontpipe combo is due to the tight space, we had to redo the bends differently than a stock setup to make it fit properly. So unlike our 2.5" system, you can't mix and match with stock/aftermarket.
The Following User Says Thank You to AVOturboworld For This Useful Post:
DAMotorsports (01-31-2014)
Old 01-31-2014, 01:40 PM   #2796
AVOturboworld
Originally Posted by gdrider77 View Post
this.
You will be in the initial batch, don't worry.
gdrider77 (01-31-2014)
Old 01-31-2014, 03:44 PM   #2797
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
I will answer on Ian's behalf. He has the following exhaust fitted:
Milltek Over-Pipe Berk Catted Front Pipe ARK Grip Rear Exhaust. AFAIK, it is 2.5" throughout.
His kit was fitted by Fensport (the same shop that fitted mine, which was their first customer fitment). They are very meticulous in checking everything with the kit both before and after fitment. I 'believe' that it was the manifold to head gaskets that went (Fensport always fit new ones with the kit). Could be something to do with the unfortunate fact that most of the kits seem to come with warped flanges. I know that they had to face mine before fitment. I have had my kit now for about six months, with no problems apart from the fact i now want more power that the current 10.5psi boost is giving.
Roll on the upgrade kit
Pitman is offline   Reply With Quote
Old 01-31-2014, 04:52 PM   #2798
DAMotorsports
Fensport does great work and I'm sure they checked everything. Once the leak is fixed I'm sure he will be problem free
The Following User Says Thank You to DAMotorsports For This Useful Post:
Pitman (01-31-2014)
Old 01-31-2014, 05:05 PM   #2799
DAMotorsports
Looking forward to the exhaust and upgrades season is about to start and we are looking to post the fastest 86 time!
Old 02-04-2014, 10:26 PM   #2800
gdrider77
gdrider77's Avatar
In regards to the above actuator, I cannot say because we haven't fitted one. And to be honest, we have no need - we've got actuator upgrades at 8, 12, and 15psi. All of them are adjustable for an additional 1~3 psi, so that would basically cover any range of boost you can run on this engine. Our upgraded actuators are also cheaper than the above, and they will fit.
When you say they are adjustable, is it a spring swap, etc? Or are you simply referring to adjusting the preload? Or something else?
Thanks.
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 03:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 02:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 08:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
