#2787 |
I Love custom Turbo kits
Drives: Limited BRZ
That exhaust looks nice!
#2788 |
Boosted
Drives: Not a supra....yet
@AVOturboworld is it only me or does the exhaust seem to have bends and tapering from a 3" to smaller ?
Sent from my IBrick
#2789 |
Boosted
Sent from my IBrick
#2790 | |
Drives: 2013 Scion FRS "Raven"
We do not recommend tracking your car on stock exhaust as it will build up to much back pressure and heats up the gaskets. Also did you check to see if the bolts were tight before starting. From the sound of your post you had a shop do the work, if so did they check every bolt before install. AVO does a great job assembling this kit, but you should always double check. |
#2791 |
#2792 |
any pics or the clearance for the 3" over pipe?
#2793 |
Drives: Subaru BRZ Limited
this.
And dammit, please put me on the list to get this full setup. I need the upgraded turbo and parts from you guys.....killing me here. |
#2794 | |
#2795 |
Not good shots - in the next week or two, I'll get a set over to fit while taking pictures + video of the install.
It's tight, no argument there, and we do certainly suggest (strongly) putting in harder engine mounts at the same time. The reason it's going to be sold as an overpipe/frontpipe combo is due to the tight space, we had to redo the bends differently than a stock setup to make it fit properly. So unlike our 2.5" system, you can't mix and match with stock/aftermarket. |
| The Following User Says Thank You to AVOturboworld For This Useful Post: | DAMotorsports (01-31-2014) |
#2797 | |
Living the dream
Drives: Fensport AVO Turbo GT86
Milltek Over-Pipe Berk Catted Front Pipe ARK Grip Rear Exhaust. AFAIK, it is 2.5" throughout. His kit was fitted by Fensport (the same shop that fitted mine, which was their first customer fitment). They are very meticulous in checking everything with the kit both before and after fitment. I 'believe' that it was the manifold to head gaskets that went (Fensport always fit new ones with the kit). Could be something to do with the unfortunate fact that most of the kits seem to come with warped flanges. I know that they had to face mine before fitment. I have had my kit now for about six months, with no problems apart from the fact i now want more power that the current 10.5psi boost is giving. Roll on the upgrade kit
#2798 | |
| The Following User Says Thank You to DAMotorsports For This Useful Post: | Pitman (01-31-2014) |
#2799 | |
#2800 | |
Thanks. |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
