Old 01-30-2014, 03:20 PM   #43
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Originally Posted by stockysnail View Post
Not all but hopefully at least a couple at PIR. I want to try ORP at least once too as I've never been.
Nice, ill go to as many as work allows.
FRSfan111 is offline   Reply With Quote
Old 01-31-2014, 02:15 AM   #44
stockysnail
Just the tip
stockysnail's Avatar
@FRSfan111 here are the pics so you can judge if the APR splitter is a possibility with my driveway.
Old 01-31-2014, 07:36 AM   #45
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
What mounting points did you use for under the vehicle? I just received mine, but no instructions. I was curious how you lined up drill points, and what you secured it to. From my recollection underneath there is a liner attached with push-click fasteners which are probably too weak for this.
Also, did you remove the underliner all together, or trim it?
Cheers
OjiGeorge is offline   Reply With Quote
Old 01-31-2014, 10:07 AM   #46
FRSfan111
Cheers
I have to take pics. But I picked up these alen headed screws that have a clip that I put on/drilled through on the plastic underline that is part of the bumper. The factory rubber underliner is currently off my car. I could trim it and use it, but the splitter covers that entire area so I chose not too.
For install the quick and dirty way is set up against the bumper on the car. Find out how far u want it to stick out while clearing the space where the factory skid plate goes. (The splitter should just about butt up against the skid plate) then mark it with tap. This will take a few sets of hands. The remove bumper, clamp it together drill ur holes, install and profit.
Old 01-31-2014, 10:11 AM   #47
FRSfan111
Attachment 65593
Attachment 65594
Attachment 65595
Attachment 65596
Would be really tight. But at max angle an slow you should clear it. But it would def be really close. The lip isn't thick but it sticks out about 2 inches or so on the side.
Just Added APR front splitter and side splitter Pekingduck Cosmetic Modification (Interior/Exterior/Lighting) 42 08-31-2016 10:22 AM
Password JDM 3 piece front splitter BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 3 05-21-2013 11:54 AM
APR Carbon Fiber Front Wind Splitter now available GuerillaRacing Exterior Parts - The Rest 65 03-27-2013 11:36 AM
Front Air Splitter sw20kosh Tracking / Autocross / HPDE / Drifting 6 02-17-2013 05:41 PM
New Apr FRS/BRZ front splitter, rear diffuser & wing? VENOM~ Cosmetic Modification (Interior/Exterior/Lighting) 7 09-11-2012 12:59 AM
