| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 | |
Drives: Subaru BRZ Sport Tech Satin White
The other settings are to compensate for vehicle attitude if the trunk or back seat is loaded. Frankly, the springs are firm enough that you will probably never use any other setting. If a number of oncoming drivers flash their high beams at you then it is polite to drop your low beams by one number, and so on if the objections keep coming. |
#16 |
Owner's manuals says it should be set at '0'. Only turn it to 1 or 2 if u carry heavy passengers/cargo in the rear.
| The Following User Says Thank You to reeves For This Useful Post: | BadMoon (01-30-2014) |
#17 |
Drives: 2010 MS3
We can't put heavy passengers in the backseat anyway unless they don't have legs.
So, I guess the only time we have to toggle it up is when we have crapload of stuff in the trunk. |
#18 |
Drives: Subaru BRZ
Yup, 0.
#19 |
Drives: 2014 GLI Autobahn/Nav
#20 |
Drives: Yes
I wish it went just ONE LEVEL higher than 0... you really can't see that far ahead when there are no street lights. It's fine for city driving, but definitely inadequate for illuminating upcoming turns on twistier back-roads. Yea, I do end up using high beams in those cases, but that means I have to constantly trigger them off and on for oncoming traffic, which is a nuisance
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#21 |
Trust me, I'm the Doctor
it's generally bunk, though. With this car, you're not going to raise the level too much if at all with passengers or "heavy cargo." So, set it to 0 and leave it there.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#22 |
Drives: car
One thing to consider though when driving in the hills, coming up over a hill the headlights set to 0 go over at a higher angle and possibly become dazzling or blinding to other drivers in those cases. So, I'm saying that those who drive on relatively flat roads don't need this consideration, this is more for those who drive around twisties and hills.
I've had it happen to me before by another car that was fitted with factory HIDs, coming over a hill in my direction I was absolutely blinded by their beams coming down on me. That's why I go to the 1 setting. |
#23 | |
#24 |
Drives: 2014 DGM BRZ MT
This is an example of the gratuitous use of technology normally associated with BMW.
#25 | ||
Drives: 2015 Series.Blue
Same for pretty much any car out there (my gf's house is down a very hilly and winding road and I have to use my high beams constantly) Quote:
Happens even with halogens, but HID's are nearly 3x brighter, so yeah, it can suck. Many of the expensive euro cars have leveling systems to stop such an event, but even they aren't perfect in this case. |
#26 |
Drives: Yes
Anyone know if moving the knob also adjusts the high beam level? Does the motor move the entire projector assembly?
#27 |
You don't adjust high beam level. the leveling scroll wheel is for low beams only.
#28 | |
This is why you don't adjust the actual alignment of your lights, as you would with conventional lights, but have an electric control instead. Some bi-Xenons are auto self level and this is actually required in some jurisdictions. |
| WTB Stock headlight projectors from retrofit OR a broken headlight | official_george | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-02-2013 03:32 PM |
| Best Position for Mids and Tweets, SQ | kmbkk | Electronics | Audio | NAV | Infotainment | 18 | 08-26-2013 05:40 AM |
| Satnav antenna position | notout86 | Electronics | Audio | NAV | Infotainment | 1 | 06-14-2013 03:01 AM |
| Shift position Indicator | Ryan86 | AFRICA | 17 | 04-12-2013 07:24 AM |
| Headrest position | Sigh-on-Rice | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-15-2012 01:28 PM |
