Old 01-30-2014, 08:18 PM   #15
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by radroach View Post
What is the appropriate setting for the HID headlight cutoff? I find when I'm driving at night alone I'll go to the 0 position setting on the switch and bring the headlights to full tilt, and when I approach a car I'll set it down to 1. But wondering, if I leave it in the 0 setting is it obtrusive to oncoming drivers?
The headlights are correctly aimed at 0 with only the driver on board and no luggage.
The other settings are to compensate for vehicle attitude if the trunk or back seat is loaded.
Frankly, the springs are firm enough that you will probably never use any other setting.
If a number of oncoming drivers flash their high beams at you then it is polite to drop your low beams by one number, and so on if the objections keep coming.
Suberman is offline   Reply With Quote
Old 01-30-2014, 08:19 PM   #16
reeves
Owner's manuals says it should be set at '0'. Only turn it to 1 or 2 if u carry heavy passengers/cargo in the rear.
The Following User Says Thank You to reeves For This Useful Post:
BadMoon (01-30-2014)
Old 01-30-2014, 08:23 PM   #17
JS + BRZ
Drives: 2010 MS3
We can't put heavy passengers in the backseat anyway unless they don't have legs.
So, I guess the only time we have to toggle it up is when we have crapload of stuff in the trunk.
Old 01-30-2014, 08:26 PM   #18
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Yup, 0.
eSOLOR is offline   Reply With Quote
Old 01-30-2014, 08:48 PM   #19
BadMoon
BadMoon's Avatar
Drives: 2014 GLI Autobahn/Nav
This.
BadMoon is offline   Reply With Quote
Old 01-30-2014, 08:53 PM   #20
chas3wba0
chas3wba0's Avatar
Drives: Yes
I wish it went just ONE LEVEL higher than 0... you really can't see that far ahead when there are no street lights. It's fine for city driving, but definitely inadequate for illuminating upcoming turns on twistier back-roads. Yea, I do end up using high beams in those cases, but that means I have to constantly trigger them off and on for oncoming traffic, which is a nuisance
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 01-30-2014, 10:55 PM   #21
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by BadMoon View Post
This.
it's generally bunk, though. With this car, you're not going to raise the level too much if at all with passengers or "heavy cargo." So, set it to 0 and leave it there.
^GT5 Replay Photo Mode^
Old 01-31-2014, 12:46 AM   #22
radroach
Drives: car
One thing to consider though when driving in the hills, coming up over a hill the headlights set to 0 go over at a higher angle and possibly become dazzling or blinding to other drivers in those cases. So, I'm saying that those who drive on relatively flat roads don't need this consideration, this is more for those who drive around twisties and hills.
I've had it happen to me before by another car that was fitted with factory HIDs, coming over a hill in my direction I was absolutely blinded by their beams coming down on me. That's why I go to the 1 setting.
Old 01-31-2014, 12:55 AM   #23
SirBrass
SirBrass's Avatar
That's going to happen no matter what the squirrel finder is set to, unless it's set so low (max) that it isn't illuminating anything but what the factory fogs would.
Old 01-31-2014, 01:29 AM   #24
993Fan
993Fan's Avatar
Drives: 2014 DGM BRZ MT
This is an example of the gratuitous use of technology normally associated with BMW.
993Fan is offline   Reply With Quote
Old 01-31-2014, 02:24 AM   #25
Poodles
Drives: 2015 Series.Blue
Same for pretty much any car out there (my gf's house is down a very hilly and winding road and I have to use my high beams constantly)
Happens even with halogens, but HID's are nearly 3x brighter, so yeah, it can suck. Many of the expensive euro cars have leveling systems to stop such an event, but even they aren't perfect in this case.
Old 01-31-2014, 02:52 AM   #26
chas3wba0
chas3wba0's Avatar
Drives: Yes
Anyone know if moving the knob also adjusts the high beam level? Does the motor move the entire projector assembly?
Old 01-31-2014, 02:59 AM   #27
SirBrass
SirBrass's Avatar
You don't adjust high beam level. the leveling scroll wheel is for low beams only.
Old 01-31-2014, 10:58 AM   #28
Suberman
Technically, the levelling wheel alters the position of the low beam shutter. The aim of the lense doesn't change. Bi-xenon lights use only one fixed position filament for both beams, one beam but an adjustable shutter.
This is why you don't adjust the actual alignment of your lights, as you would with conventional lights, but have an electric control instead. Some bi-Xenons are auto self level and this is actually required in some jurisdictions.
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 04:32 PM
Best Position for Mids and Tweets, SQ kmbkk Electronics | Audio | NAV | Infotainment 18 08-26-2013 06:40 AM
Satnav antenna position notout86 Electronics | Audio | NAV | Infotainment 1 06-14-2013 04:01 AM
Shift position Indicator Ryan86 AFRICA 17 04-12-2013 08:24 AM
Headrest position Sigh-on-Rice Scion FR-S / Toyota 86 GT86 General Forum 2 06-15-2012 02:28 PM
