Old 01-30-2014, 01:29 PM   #1
radroach
Drives: car
HID headlight position setting
What is the appropriate setting for the HID headlight cutoff? I find when I'm driving at night alone I'll go to the 0 position setting on the switch and bring the headlights to full tilt, and when I approach a car I'll set it down to 1. But wondering, if I leave it in the 0 setting is it obtrusive to oncoming drivers?
Old 01-30-2014, 01:33 PM   #2
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Our cars are low enough that 0 is just fine with factory HIDs.
^GT5 Replay Photo Mode^
Old 01-30-2014, 01:40 PM   #3
meeskee2
meeskee2's Avatar
Drives: World Rally Blue BRZ Limited, MT
I usually leave mine on 1. I which they went higher though.
- World Rally Blue BRZ | Limited | Manual -
"Some guys think that having a better car makes them better than other guys, and those guys are right." -Top Gear
meeskee2 is offline   Reply With Quote
Old 01-30-2014, 01:42 PM   #4
SirBrass
SirBrass's Avatar
They do. Go to 0.
The Following User Says Thank You to SirBrass For This Useful Post:
Grayian (01-30-2014)
Old 01-30-2014, 01:45 PM   #5
Vides990
Drives: 13 BRZ (sold) 20 BRZ TS (sold)
I stay at the 0 position and have had a few cars flash me, then I hit them with the high beams and that fixes that.
Vides990 is offline   Reply With Quote
The Following 6 Users Say Thank You to Vides990 For This Useful Post:
AznKirby (02-07-2014), brzadrian (01-30-2014), italy7 (06-24-2014), JS + BRZ (01-30-2014), SirBrass (01-30-2014), zc06_kisstherain (01-31-2014)
Old 01-30-2014, 01:46 PM   #6
radroach
Drives: car
Thanks for the replies, it's definitely easier to see the road with the position at 0.
Old 01-30-2014, 01:49 PM   #7
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I go with 1 in the city, 0 outside the city at night, and 5 when its foggy + fog lights.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 01-30-2014, 01:50 PM   #8
JS + BRZ
Drives: 2010 MS3
I like your style.
I put mine on 0.
JS + BRZ is offline   Reply With Quote
The Following User Says Thank You to JS + BRZ For This Useful Post:
Vides990 (01-31-2014)
Old 01-30-2014, 01:51 PM   #9
meeskee2
meeskee2's Avatar
Originally Posted by SirBrass View Post
They do. Go to 0.
I guess I was unclear. I know they go to 0 but I want them to go even higher than they do at the 0 position.
Old 01-30-2014, 02:11 PM   #10
DarkSunrise
DarkSunrise's Avatar
On my STI, the "0" position was designed for normal driving. You would only switch to "1" if there were passengers or cargo weighing down the rear.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
radroach (01-30-2014)
Old 01-30-2014, 02:16 PM   #11
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Yeah I know what you mean. 0 is not high at all. The lights cut off below the rear license plate of most cars. I don't think there's a physical adjustment to the lights other than the one inside the car.
I have mine on 0 the entire time. Going up on numbers only lower the lights.
Old 01-30-2014, 03:07 PM   #12
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
0 and never had anyone flash me.
sprintertrueno86 is offline   Reply With Quote
Old 01-30-2014, 04:15 PM   #13
SirBrass
SirBrass's Avatar
We're really too low-slung to need to put the headlights anywhere other than 0.
I think going to something a little (not much though) higher power and higher tempurature (something like 6k) could help with the light casting.
That said, hi beams are perfectly adequate. Use them when canyon carving at night, exclusively unless following or I see oncoming traffic.
But yeah the low beams definitely need to be projected further out. Them being HIDs in the BRZ certainly helps a great deal (the difference between the low beams in my 08 WRX, which were standard halogens, and the HIDs my STI came with was very significant in the positive sense), but the low height of our cars still puts us at a bit of a disadvantage.
Problem is that if we angle them up farther, then farther out, they will be blinding other drivers. Higher power may work, but it can't be too high power, else we will dazzle drivers like they had a 150 lumen tac light strobe their eyeballs from 5 yards away.
The Following 3 Users Say Thank You to SirBrass For This Useful Post:
chas3wba0 (01-30-2014), meeskee2 (01-30-2014), sprintertrueno86 (01-30-2014)
Old 01-30-2014, 06:54 PM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
i need to tweak mine.. been running them at 0 right now, but really need a 0.5 setting.. 1 is too low...
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
Best Position for Mids and Tweets, SQ kmbkk Electronics | Audio | NAV | Infotainment 18 08-26-2013 05:40 AM
Satnav antenna position notout86 Electronics | Audio | NAV | Infotainment 1 06-14-2013 03:01 AM
Shift position Indicator Ryan86 AFRICA 17 04-12-2013 07:24 AM
Headrest position Sigh-on-Rice Scion FR-S / Toyota 86 GT86 General Forum 2 06-15-2012 01:28 PM
