Old 01-30-2014, 05:40 PM   #3011
TemeCal
Drives: 86
Originally Posted by wrxgoose View Post
I did. Secondary belt is on now. That makes 3 stock sized belts, and one smaller belt. Really starting to grow old
Sent from my VS840 4G using Tapatalk
I feel for you. I can't imagine what I'd do if I kept losing belts, like you have. I only have a few thousand miles on my supercharger, with the RB belt. I'm running the 70mm pulley too. I've done a road trip, a hard track day, and drive my car daily. I've yet to break a belt, and I don't see any indication of it happening.
I'd pester Innovate. Something just isn't right.
TemeCal is offline   Reply With Quote
Old 01-30-2014, 05:40 PM   #3012
DriftEm
DriftEm's Avatar
Same here, the smaller belt gone. Do you have aftermarket crank pulley? I have the Perrin, I'm going to install the stock pulley and see.
Sent from my SAMSUNG-SM-N900A using Tapatalk
DriftEm is offline   Reply With Quote
Old 01-30-2014, 05:42 PM   #3013
TemeCal
Drives: 86
How many miles are you and @wrxgoose getting on a belt? Like I said, I ran my car to Vegas...ran a full track day...and drive it daily. My belt seems to be fine.
Old 01-30-2014, 05:45 PM   #3014
DriftEm
DriftEm's Avatar
I've gone through 3 so far, it usually good for 3k miles and then booooooom
The Following User Says Thank You to DriftEm For This Useful Post:
TemeCal (01-30-2014)
Old 01-30-2014, 05:47 PM   #3015
swift996
swift996's Avatar
Originally Posted by stockysnail View Post
That's what I thought. I think the other guy was assuming I did not already have the supercharger on, which I do.
You should be fine, I'd just drive it easy until you can get it re-tuned.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
stockysnail (01-30-2014)
Old 01-30-2014, 05:54 PM   #3016
Kodename47
Kodename47's Avatar
Drives: UK GT86
I can't see any issues with running a non-IC tune on a car with a IC. It just means you won't gain any power. The only advantage of the IC is to make intake temps more consistent anyway,. it won't make you any more power, it just makes the power more reliable.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-30-2014, 05:54 PM   #3017
stockysnail
Just the tip
stockysnail's Avatar
The belt on mine is fine and I think there's just over 3k on it and I have the Perrin engine crank pulley on as well.
Old 01-30-2014, 06:14 PM   #3018
Calum
That Guy
Drives: 2013 asphalt FRS MT
Damn Goose, that sucks. Have you talked to Innovate about this? I can't believe they haven't helped you out on this.
By any chance can you get a hold of a dial indicator and magnetic base? I think it's time you took some measurements to see if you have a slight run out issue. Also, if the ridges of the pulley are touching the center of the valleys of the belt that could cause premature wear.
I've got a dial indicator and would be willing to ship it to you if you pay for the shipping. But I doubt that would be at all advantageous after the shipping was paid.
Edit, have all of these belt been on the same SC pulley?
Old 01-30-2014, 06:49 PM   #3019
stockysnail
Just the tip
I'm having a local company (Nameless Performance) make me a metal intake tube to replace the plastic innovate one. They are also ceramic coating then powder coating it red as well and adding a meth hole for future meth injection upgrade. I'll take a pic of it once I get it and put it on. Should bring out the sound a little more and keep the temps down, plus look much better.
Old 01-30-2014, 06:50 PM   #3020
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Stock crank pulley, and every belt that I've lost has been with the 75mm pulley. To be perfectly honest, I'm convinced it's because of the tensioner, but I'm still gonna go to a speed shop up here and have them check the alignment of all the pulleys
wrxgoose is offline   Reply With Quote
The Following User Says Thank You to wrxgoose For This Useful Post:
Calum (01-30-2014)
Old 01-30-2014, 07:03 PM   #3021
xjohnx
Grip>Slip
xjohnx's Avatar
Pretty sure @sw20kosh experimented with a meth injection setup, ended up ditching it eventually. Right?
Old 01-30-2014, 07:21 PM   #3022
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I am at 10,000 miles. 75mm stock pulleys. Original belt is still going strong! I feel for you though!!
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 01-30-2014, 07:23 PM   #3023
wrxgoose
WUB WUB
How is your tensioner, and what's the part code on your belt?
Old 01-30-2014, 07:40 PM   #3024
calispec
calispec's Avatar
tensioner is fine.. I thought i heard a little chirp from the bearing but i can't tell if it is the fuel pump or if it is might be the bearing. It only makes a sound every once in a while..
www.GT86Mounts.com
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
