Old 01-24-2014, 02:12 PM   #127
Sniper2606
Sniper2606's Avatar
Originally Posted by xDanger_208x View Post
I pretty much have this same setup except I'm using the stock shifter.
My shifts are amazing!.. and I'm still on the factory fluid.
I could not believe how much of a difference those 2 lil MTEC springs made
Good job MTEC
Sniper2606 is offline   Reply With Quote
The Following User Says Thank You to Sniper2606 For This Useful Post:
JB86'd (01-24-2014)
Old 01-26-2014, 05:28 PM   #128
PMPB
Drives: BRZ Sport-tech
Good job MTEC
What do they do? Serious question. How do they change the feel?
I like the existing stiff feel, but twice I've gotten stuck half way into gear thinking I was all the way in, and had a grind.
PMPB is offline   Reply With Quote
Old 01-27-2014, 07:07 AM   #129
Ibanezboy21
Drives: 2014 Subaru BRZ (S pack)
oh so its this is why i struggle getting into 2nd gear sometimes.......
my cars done 700kms and sometimes it so hard to get into 2nd, i have to sometimes 'ram' it in or go back to neutral and try again.
so changing the oil is a 100% fix? or 50/50?
Ibanezboy21 is offline   Reply With Quote
Old 01-27-2014, 02:45 PM   #130
reeves
Only if you use a different (i.e., better) aftermarket brand of tranny fluid. Pentosin worked for me. Other people have said Motul is good too.
Old 01-27-2014, 11:22 PM   #131
sid325
Drives: Ultramarine FR-S 6MT
Even using Pentosin is not a guarantee. I'm switched to Pentosin and still have issues with 2nd gear and I live in the SF Bay Area, not cold.
sid325 is offline   Reply With Quote
Old 01-28-2014, 12:08 AM   #132
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
I'm fairly sure someone effed my 2nd gear synchro a little bit on a test drive. It never becomes completely easy to get into second like the other gears do, no matter what temp.
This is with the stock fluid, redline MTL, and now Motul Gear300. It's better, but not cured.
Sellout is offline   Reply With Quote
Old 01-28-2014, 08:52 AM   #133
HunterGreene
Hail Magnet
HunterGreene's Avatar
If its still causing issues, Id have gotten it replaced under warranty before trying to swap out all kinds of fluids. You should still be able to get it replaced under warranty, but expect resistance if they note you are using non-OEM fluids.
It has priests in it?
Old 01-28-2014, 01:43 PM   #134
DrewIsAmus
Drives: Dark Grey Metallic 2013 Subaru BRZ
Switched the diff and trans to Motul and the trans is smooth like butter now!
DrewIsAmus is offline   Reply With Quote
Old 01-28-2014, 02:36 PM   #135
chas3wba0
chas3wba0's Avatar
Drives: Yes
2000 miles later on the factory fluid and all my gears are pretty "notchy", but not alarmingly so. It sometimes gets caught between gates when I'm downshifting from 5th to 4th at higher RPMs, but that might just be bad form on my part.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post:
RJasonKlein (10-03-2014)
Old 01-30-2014, 02:39 PM   #136
cycleboy
Drives: 2013 Scion FR-S - Argento
This may be a dumb question, but when I change out mine (hopefully tomorrow), I'm assuming I want to wipe off whatever gunk is stuck to the plugs?
cycleboy is offline   Reply With Quote
Old 01-30-2014, 02:48 PM   #137
mfbmike
Drives: 2013 FRS, 2008 R32
Yes.
mfbmike is offline   Reply With Quote
Old 01-30-2014, 03:18 PM   #138
996garage
996garage's Avatar
Drives: 03' NSX & 13' BRZ 6spd Ltd white
Anyone else have problems with slight gear grinding when Downshifting from 2nd to 1st gear?
For example when rolling less than 5mi/hr to a stop sign or to make a right turn, and you want to put it in 1st gear to be able to roll off quickly. About half the time I get some grinding when trying to do this. Doesn't seem to matter if it's hot or cold. Double clutching doesn't always prevent it either.
I've owned 8 different sports cars with manuals, and have never experienced this issue on any of them. Just wondering if I'm the only one?
996garage is offline   Reply With Quote
Old 01-30-2014, 05:43 PM   #139
sid325
Yes, I pretty much have to be at a dead stop going from 2nd to 1st or it grinds.
Old 01-30-2014, 05:54 PM   #140
suaveflooder
Same here. Haven't swapped fluids yet. Motul is on it's way though. We shall see.
suaveflooder is offline   Reply With Quote
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
