Old 01-28-2014, 11:16 AM   #1
FullBlown
FullBlown's Avatar
Drives: Scion FRS
FBM Intake Manifold Release
We have decided to produce an intake manifold for the Fa20 motor and are in the beginning stages of the design.
The goal here is to design an intake manifold that will make power for both naturally aspirated and forced induction setups.
While the final product will be months out. We are hoping to have a plastic sample done that we can test shortly.
Once testing is done and we are happy with the results, we will move onto creating the production pieces in cast aluminum.
We will keep this thread updated as we go
FullBlown is offline   Reply With Quote
Old 01-28-2014, 11:17 AM   #2
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Finally.
husker741 is offline   Reply With Quote
Old 01-28-2014, 11:19 AM   #3
Frs300
Frs300's Avatar
Drives: Pile of junk
about time i was just sayn last night i wish someone would make one
Frs300 is offline   Reply With Quote
Old 01-28-2014, 11:33 AM   #4
FullBlown
FullBlown's Avatar
Drives: Scion FRS
I agree, it is about time. With rumors of cams from the big companies coming out. We feel this would be perfect
Old 01-28-2014, 11:39 AM   #5
Frs300
Frs300's Avatar
now just need to do some throttle body work :P
Old 01-28-2014, 11:51 AM   #6
nelsmar
Could you pre drill and install a plug for IAT? That would be wonderful for the higher powered / more on edge cars that are using speed density and have kits / intakes with the iat further from the manifold.
My flickr - Canibeat
Local magazine scout
Old 01-28-2014, 11:54 AM   #7
ModBargains.com
ModBargains.com's Avatar
Methanol bungs as an option maybe?
ModBargains.com is offline   Reply With Quote
Old 01-28-2014, 12:08 PM   #8
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Yes, we will have pre-tapped holes on the backside to eliminate vacuum blocks / Tees and have provisions for sensors
That can be an option for sure
Old 01-28-2014, 12:09 PM   #9
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We are starting with a 70mm opening on the manifold. DBW throttle bodies are a little tricky, but definitely on our to do list.
Old 01-28-2014, 12:10 PM   #10
nelsmar
Fantastic! I just figured you guys would know where the optimal location for an IAT would be due to the fact you designed it. I am extremely interested in this.
Do you have plans on some sort of heat resistant surface to keep heat transfer from the heads to a minimal?
Old 01-28-2014, 12:14 PM   #11
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Nice!
Old 01-28-2014, 12:19 PM   #12
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Yes sir, they will be provided with a thermal gasket. We are ditching the factory o-ring style seal.
Old 01-28-2014, 12:22 PM   #13
OrbitalEllipses
Drives: Attitude
Interesting.
Old 01-28-2014, 12:37 PM   #14
zerodark
zerodark's Avatar
Drives: 2015 Series.Blue (WRB Pearl)
With everything that FBM is doing.. I wish I was still living back in MN! Thanks for all you guys do for the tuning community (especially the BRZ/FR-S/GT86 platform).. keep up the amazing work!
zerodark is offline   Reply With Quote
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold cover protpibe Engine, Exhaust, Transmission 16 02-28-2014 06:44 PM
Wanted intake manifold ciro Want-To-Buy Requests 0 09-27-2013 12:03 PM
Aluminium intake manifold? Hempo Engine, Exhaust, Transmission 18 06-27-2013 01:19 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
