Old 01-27-2014, 11:17 PM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
backed into a support column
I accidentally backed into a cement column at a parking lot. I tried my best to fix it but if you look close you can still see the scratches. Anyone have suggestions to make it even less visible?
Before:
After: This is the best i can do. You can still see the scratches. Some are deep. Process was Scratch X 2.0 -> Touch up paint -> Ultimate Compound -> Ultimate Wax
chenshuo is offline   Reply With Quote
Old 01-29-2014, 12:10 PM   #2
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
wet sand
Atticus808 is offline   Reply With Quote
Old 01-29-2014, 01:24 PM   #3
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
build up, then wet sand
Old 01-29-2014, 07:01 PM   #4
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
I've never done wet sanding. After wet sand how do i bring back the color and gloss?
Old 01-29-2014, 08:04 PM   #5
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Then don't do it until you practice on something else, wet sand can do miracles if you know how to do it. I'd drive it like that and get a quote on painting it eventually.
Rayme is offline   Reply With Quote
Old 01-29-2014, 10:44 PM   #6
Atticus808
Atticus808's Avatar
when you wet sand you're inducing a bunch of scratches with very fine sandpaper. it'll look really dull and your scratches should be removed at this point. then you use a microfiber cutting pad with a compound and go over the area plus a bit more to blend it in. once removed use a polishing/finishing pad and a polish to bring it back to new
Old 01-30-2014, 08:49 AM   #7
SloS14
SloS14's Avatar
I would suggest using a soft sanding block on the built-up (and COMPLETELY cured) touched-up parts.
People have fingers, and fingers+sandpaper can cause grooves.
Old 01-30-2014, 06:48 PM   #8
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
do you guys think i can use Meguair's Ultimate Compound and use it with a machine to buff it out? without sanding?
Old 01-31-2014, 12:58 AM   #9
Atticus808
Atticus808's Avatar
try it
always find the least amount of aggression first
Old 02-03-2014, 06:36 AM   #10
troek
troek's Avatar
Drives: 2012 Toyota 86
good advice ^^^^
just be careful, if the scratches are deep enough you will burn through the clear coat trying to remove them. id say, if you can get them barely noticeable, leave it alone unless your 100% you can make it perfect without ruining it.
troek is offline   Reply With Quote
Old 02-03-2014, 07:44 AM   #11
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
U can barely see the scratches.
Good job!
Carlitoz3 is offline   Reply With Quote
Old 02-03-2014, 09:14 AM   #12
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
its too late already since you sanded the clearcoat by now
if your feeling adventurous spray the area with clear and wet sand (water + 1500 grit)
GT86drifter is offline   Reply With Quote
Steering Column Creak michaelahess Issues | Warranty | Recalls / TSB 12 06-27-2018 02:14 AM
Steering Column Cover Pablitomarrero Cosmetic Modification (Interior/Exterior/Lighting) 6 11-23-2013 12:29 PM
So my dad just backed into my car... klassick CANADA 6 05-16-2013 11:44 PM
WTB: Steering Column Cover (top one) Jamifra Interior Parts (Incl. Lighting) 6 11-27-2012 10:20 AM
How to remove steering column trim? Gen Electronics | Audio | NAV | Infotainment 1 10-29-2012 01:36 AM
