Old 01-27-2014, 10:54 AM   #141
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
I've had oft for a while. Flashed to stock for last two visits and the service I got Saturday was actually to change to a new calibration on the ecu. I had my stock 700c, and they updated me to b01c without any question or concern. If ever it was going to show up to a dealership it would be something like this and there was zero issue.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 01-27-2014, 11:00 AM   #142
1086
1086's Avatar
Drives: UM86 - 6MT
Why did you need to get your stock re-flashed from 700c to b01c?
1086 is offline   Reply With Quote
Old 01-27-2014, 11:11 AM   #143
Cross
It's the Mad Cow
Cross's Avatar
Originally Posted by SubaSteve View Post
I don't like your attitude either. Please people stay on topic.
Ok thanks for letting me know, not going to say that changes anything but I can respect anyone's opinion.
As for on topic I have both OFT and EcuTek. I have only left an OFT flash on when I sent the car in for its first oil change and they didn't say anything about it other than complementing the car and asking how the Vette was doing. (Oddly enough all my cars have come from that Toyota dealer)
It's almost time for my next oil change so I will leave the EcuTek flash on it and see if they say anything. In FRSDuke's situation it's a good thing he went back to stock since the dealer updated his firmware I'm not sure the OFT would have liked that had he left a custom tune on it. That might be a good topic for Shiv to touch on.
Sent from Spaceball 1
Old 01-27-2014, 11:14 AM   #144
nelsmar
Originally Posted by Heru Farukon View Post
So much back and forth bantering on this thread.
I would like to know if anyone has brought their vehicle in for service with either the software flashed their ecu and if it left a footprint
Sent from my SM-N900W8 using Tapatalk
No issues here. I just tell the dealer the ECU has been refreshed and ask them to not run any checks on it and that it already has the most recent update. But not every dealer is as accepting as this.
My flickr - Canibeat
Local magazine scout
Old 01-27-2014, 11:32 AM   #145
Malt
Drives: 2015 WRX
I'm sure it was more about "want" and less about "need".
Malt is offline   Reply With Quote
Old 01-27-2014, 11:34 AM   #146
FrsDuke
Fanboy
FrsDuke's Avatar
I was able to demonstrate a reasonable need finally. But yes, I did it because I wanted it
TL;DR:
-Duke
Old 01-27-2014, 11:36 AM   #147
FrsDuke
Fanboy
FrsDuke's Avatar
He has, and yeah had I not returned to stock and unmarked the tablet it could have caused issues. Was very easy to do, and everything is working great.
TL;DR:
-Duke
Old 01-27-2014, 11:45 AM   #148
1086
1086's Avatar
Drives: UM86 - 6MT
I see but what did you get out of it? Would this be something you recommend we all do? I haven't come across someone stating that before so I am a little lost lol
Old 01-27-2014, 11:58 AM   #149
Malt
Drives: 2015 WRX
The only thing gained is the idle improvements that the new roms have. Shiv has already merged the other improvements from the other series roms into all the OFT maps and he had commented that he'll look into the new maps
The Following User Says Thank You to Malt For This Useful Post:
1086 (01-27-2014)
Old 01-27-2014, 12:04 PM   #150
FrsDuke
Fanboy
FrsDuke's Avatar
I didn't get anything the oft didn't already give me. It did allow me to try the 1.5x .dev release for oft, but once out of beta they will be available for all cals anyway. Basically it was impatience and a personal mission to force Toyota to update my shit the way I feel they should.
TL;DR:
-Duke
The Following User Says Thank You to FrsDuke For This Useful Post:
1086 (01-27-2014)
Old 01-27-2014, 12:23 PM   #151
1086
1086's Avatar
Drives: UM86 - 6MT
ps4. I don't need xbox looking down my blouses
[ame="http://www.youtube.com/watch?v=t3KskO3_2YQ"]Game: Blouses. - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=t3KskO3_2YQ"][/ame]
Old 01-27-2014, 12:50 PM   #152
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by jamesm View Post
in response to @DeliciousTuning stating that racerom extends the usable range of the stock injectors, i would ask for an explanation as to how that is possible. i've used racerom and custom maps more extensively than most 'master tuners', and haven't seen anything that would allow that. if it's a map definition that would enable it, that's kind of a moot point being that with romraider, you can define any map you want and use it (not the case with ecutek). the only thing i could imagine that you are referring to is port/di ratio or di fuel pressure targets, both of which are defined in all three of the software packages i've tuned 86s with iirc. i'm very curious to know what you mean by that statement.
as for the whole sd vs. maf debate, i find it comical that the someone arguing that a large maf housing is a solution to maf reading limits would simultaneously argue that speed density has bad low speed drivability. large maf housings introduce problems with low speed drivability as intake velocity drops, and i'm sure you're aware of this. the only way to have your cake and eat it too is a hybrid setup, which can only be done with racerom.
speed density is just like a maf in that if you want good drivability you just have to take the damn time to achieve it. unfortunately, even with maf systems in my experience it seems that very, very few tuners actually do this (and none that etune that i'm aware of, unless there is some way to do it properly without process separation which is logically impossible given two separate, interoperating fuel systems). so as always, it's more about who you go with than any other detail of the implementation.
Thank you for asking questions it is appreciated.
With regards to DI/PI and RaceROM and extending the designed OE range. The designed OE range as I understand it the injectors DI/PI is ratio based. So if DI is using 40% of then the maximum PI can use 60%, or if PI is using 20% then DI can only use a maximum of 80%, and so on.
I am not going to give away the farm, but I have figured out a way with EcuTeK RaceROM, so that you can use use a maximum of 100% DI and 100% PI, effectively giving you 200% fuel delivery. It is not something within the standard operating procedures of EcuTeK, but it is in there (in RaceROM) if you know how to look at it. This is how a lot of my tunes work on 350+ whp vehicles (turbo kits and superchargers) running stock injectors on E85.
In regards to Speed Density etunes, you are more than welcome to speak to any of my customers running pure speed density on their turbo kits. There are a few out there now and all of them are running quite well and are very happy with the tune. Though I will say it took quite some time to figure out how to make it work well, while using EcuTeK RaceROM to dial in compensations, and of course it is still being revised for improvements.
Cheers,
William Knose
The Following 5 Users Say Thank You to DeliciousTuning For This Useful Post:
Cross (01-27-2014), jamesm (01-27-2014), jflogerzi (01-27-2014), nelsmar (01-27-2014), Sportsguy83 (01-27-2014)
Old 01-27-2014, 01:45 PM   #153
jamesm
Cheers,
William Knose
thanks i will definitely look into that for other tunes i'm working on, though with all the large injectors i've been tuning it's not a problem i've had to solve as of yet. i'm very interested to figure it out just for the sake of science, though . please don't be mad when i figure it out and sell the farm lol.
i'm going to be doing a full speed density tune this evening for a local turbo car, and i don't expect it present any major issues, especially given the ability to create any comp map i could imagine needing. it's being done because the maf on the particular kit he is using is extremely inconsistent below 1.4-1.5v, and is effecting drivability to the point that speed density looks like a better option until we can get a new maf tube. i'll be sure to update the community as to how that goes.
The Following 3 Users Say Thank You to jamesm For This Useful Post:
ATL BRZ (07-02-2014), Sportsguy83 (01-27-2014), vgi (01-27-2014)
Old 01-27-2014, 02:23 PM   #154
DeliciousTuning
Well when you sell the farm after you have figured it out I will definitely applaud your efforts, as it is thinking outside the box that makes things like this happen.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
jamesm (01-27-2014)
#fanboysthread, oftsupportgroup, unichip ftw
ECUTek question ATSAaron Engine, Exhaust, Transmission 12 04-03-2014 06:37 PM
Ecutek's 86 jpit FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 07-12-2013 12:35 PM
I need help on which ecutek I should get, stg 1 or 2 Frsexxxy Engine, Exhaust, Transmission 22 03-29-2013 10:45 PM
Which should I get ecutek stg 1 or stg 2? Frsexxxy Engine, Exhaust, Transmission 5 03-21-2013 01:10 PM
ECUTEK????? 20valvewynn83 Engine, Exhaust, Transmission 4 10-03-2012 09:34 PM
