Old 01-26-2014, 12:52 AM   #1
frumplejoon
Drives: '99 Camry, E36 M3 (RIP), BRZ
Wheel Directory: OEM Subaru Legacy GT 16x6.5 +55
OEM Subaru Legacy GT Wheels (1997-2004)
Wheel Size: 16x6.5 +55
Wheel Weight: 20 lbs
Tire Size: 205/60R16
I found a few others with this setup scattered after a bit of searching, but didn't see this wheel size in the stickied wheel directory. It's a bit tight in the front; very close to the calipers and also pretty close to the lower spring perch. Still, it all fits with no clearance or rubbing issues. There are also other OEM Subaru wheels with 16x6.5 +55 dimensions that can be found for cheap used. Great winter setup if you're looking to save $$ and still have good tire options (even cheaper than TireRack's recommended 205/55R16s).
frumplejoon is offline   Reply With Quote
Old 01-26-2014, 10:25 AM   #2
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I feel like going rallying, very nice.
Old 01-27-2014, 01:24 AM   #3
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 02-04-2014, 12:51 AM   #4
Mikeez
Engineering Student
Drives: Scion FR-S 2015
someone suggest me to do the same thing as you, but he said to get spacers? How do I get 16inch winter tires with rims like you?
Mikeez is offline   Reply With Quote
Old 02-04-2014, 02:02 PM   #5
frumplejoon
I have enough clearance so I didn't need spacers. You could always add them though, get those online or from your local auto parts store. Used 16" rims can be found cheap from other Subaru forums or Craigslist. Usually there are sets of 4 available for ~150. Tires can be had from your fav tire store online (i.e. TireRack).
Old 06-11-2014, 12:43 PM   #6
Weasel Soup
Veteran RallyCrosser
Weasel Soup's Avatar
Drives: 10 Series FR-S, 95 Escort Rally Car
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal
2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive
Weasel Soup is offline   Reply With Quote
Old 11-30-2015, 11:18 AM   #7
ivtaku7
ivtaku7's Avatar
Drives: 2015 Ultramarine FRS
Tire Size: 195/60R16 (Blizzaks)
Perfect fitment, no rubbing even at full lock. I noticed 195 is a bit narrow for dry pavement, but safe driving should be implemented in winter weather anyway so I think they'll be perfect in the snow.
ivtaku7 is offline   Reply With Quote
Wheel Directory: OEM Subaru Forester XT (2006) 16x6.5 +48 SamS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 12-02-2013 10:11 PM
Subaru Legacy Concept Whitigir Other Vehicles & General Automotive Discussions 18 11-19-2013 04:46 PM
Subaru Legacy on BRZ wheels Turbowned Other Vehicles & General Automotive Discussions 7 10-06-2012 07:11 PM
Subaru Legacy GT Spec B vs BRZ warman FR-S / BRZ vs.... 17 07-23-2012 11:10 AM
