Old 01-25-2014, 09:57 PM   #421
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by switchlanez View Post
Do you know what's the rubber width of the STI genuine one as below?
Thanks again.
cslntuee is offline   Reply With Quote
Old 01-25-2014, 10:00 PM   #422
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Thanks again.
It has an "L" shaped cross section, about 1.25" to 1.5" per leg.
The Following User Says Thank You to switchlanez For This Useful Post:
Trap63 (02-27-2014)
Old 01-25-2014, 10:18 PM   #423
cslntuee
Did the home depot one has L shaped with similar size?
Thanks.
Old 01-25-2014, 10:38 PM   #424
switchlanez
Thanks.
You can see in the picture, the Home Depot one is a little bigger, maybe 2" and not a perfect 90 degrees. More like an obtuse L shape, probably 120 degrees between the legs. But it isn't as rigid (it's a soft foam-like rubber vs STI is stiff, dense rubber). If you are trying to see which offers better protection, I would go with STI because it has proven to protect my lip even in dips that are deeper than how high my front lip is. Because as the rubber skirt would rub down into the dip, it would conform to the dip and keep some spacing between the ground and front lip, pushing/bending the front lip up and away from the concrete. The Home Depot lip may be able to do this too, but I have no firsthand experience with it (I never scraped when I had it on).
The Following 3 Users Say Thank You to switchlanez For This Useful Post:
chanomatik (01-27-2014), cslntuee (01-25-2014), Trap63 (02-27-2014)
Old 01-25-2014, 11:01 PM   #425
cslntuee
How to install the STI rubber? It only uses tape or need to drill the hole to
the front lip?
Thanks.
Old 01-25-2014, 11:07 PM   #426
jflogerzi
jflogerzi's Avatar
Keeping it hush hush for now hoping nobody gets these wheels before I do. :p
hum the new ssr wheels?
Old 01-26-2014, 04:12 PM   #427
switchlanez
the front lip?
Thanks.
It comes with 3m tape already attached and plastic pins for you to use after you drill. I didn't drill and just used the tape.
cslntuee (01-26-2014)
Old 01-26-2014, 07:27 PM   #428
cslntuee
[QUOTE=switchlanez;1481185]It comes with 3m tape already attached and plastic pins for you to use after you drill. I didn't drill and just used the tape.
Is the hard rubber material same as STI Rear Wing Gurney Flap?
How many plastic pins they include? Where is the drill (or mount spot)
the installation guidance suggest?
Sorry for so many questions and Thanks again.
Old 01-26-2014, 07:37 PM   #429
switchlanez
Yes, it feels similar to the gurney flap. I don't remember how many pins nor the locations. The instructions seemed generalized (I think the diagram was for the Impreza and did not look like our car). The skirt already had some holes for the pins but they were not symmetrically placed (many holes on the right side and very few holes on the left side) nor evenly spaced. And it was a little longer than the lip (I think I cut off about 8 inches of unneeded material).
Old 02-06-2014, 12:04 PM   #430
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Bumping because curious of any updates. Any super secret squirrel projects brewin'?
Old 02-11-2014, 01:24 PM   #431
switchlanez
Not much to post as of now... maybe check back in a little more than a month and possibly a new photo set.
I'm currently debating if I should get a TRD short shifter (the JDM one). It'll make the inputs (w/ TRD steering wheel and TRD shift knob) feel complete but I'm hesitant to pull apart interior pieces and decipher Japanese instructions. >_< I'd rather torque nuts and bolts outside the cabin.
chanomatik (02-11-2014)
Old 02-11-2014, 01:31 PM   #432
trd_kid
13anned.
trd_kid's Avatar
Drives: Firestorm FR-S
@switchlanez First off nice car I actually showed my friend who just purchased a wrb brz your build so he can have a proper car for inspiration! Second how do you like the trd steering wheel I'm considering purchasing one after I rebuild my wheels.
Originally Posted by Rocket.Brz
She was not and never was 13 years old during the prom thread.
trd_kid is offline   Reply With Quote
Old 02-11-2014, 01:40 PM   #433
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
I've been eyeballing the GT-86 Limited steering wheel for a long time now. I probably won't pull the trigger for another couple of months. Concerning the short shifter, it's honestly not that bad to deal with. Easier than an early model Impreza, I'm sure, and maybe harder than my 2011 WRX since the car is inherently smaller and more cramped. I'm sure a bunch of local guys would be willing to help, too.
Why TRD and not STI? I was kinda maybe considering the STI one since the price came down a lot.
I should be creating a Member's Car Journal thread here shortly as well. I've been trying to get used to my Nikon D5000 with this new 35mm lens while tackling more techniques. It's been frustrating, but hopefully I'll have nice pics to share when the car is ready.
I can't wait for your updates!
Old 02-11-2014, 01:42 PM   #434
switchlanez
Thanks bud! The girth isn't exactly ergonomic and can make your hand(s) tired after gripping it for an extended period of time compared to stock. But that and the slightly smaller diameter make the feel a touch more fun than stock. I used to want the OEM steering wheels Momo made for old school Toyotas such as the MR2 so my preference is biased. Momo made this one noticeably lighter than stock as well (though I didn't have a scale to weigh it). I chose it over other wheels for its uniform shape rather than lumps at 2 and 10 o'clock and flattened bottom at 6 o'clock. If you don't care for a uniform shape, other JDM options such as Prova or Cusco are simply gorgeous.
The Following 2 Users Say Thank You to switchlanez For This Useful Post:
chanomatik (02-11-2014), trd_kid (02-11-2014)
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
August 1st Charity Lapping Day - Subaru Canada - Davenport Subaru - SPDA - TSC wparsons CANADA 10 07-22-2015 01:24 PM
Subaru Cross Sport Design Concept = Subaru BRZ Shooting Brake Hachiroku BRZ First-Gen (2012+) — General Topics 91 04-01-2014 06:53 PM
Subaru LIBIRD Supercar Concept & BRZ (April Fools) switchlanez BRZ First-Gen (2012+) — General Topics 18 04-15-2013 02:20 PM
Subaru BRZ - RAW Subaru | Official Subaru Australia Ad Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 15 07-20-2012 08:20 AM
