Old 01-25-2014, 12:04 PM   #659
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Originally Posted by FT-86 SpeedFactory View Post
If you get a tune a catless one will be just fine. And if you have not cat, you will want a resonated front pipe and a resonated exhaust to keep the rasp out and the rumble rocking.
That's the plan. Currently my wishlist has the Nameless resonated and catted front pipe/down pipe combo and the resonated PERRIN catback exhaust. I'm no expert but from what I've seen of the two, the Nameless should be relatively reserved, while the PERRIN catback is a little meaner. I'm hoping they work well together. Bolt this header to the top of that and bam, good match.
Nevermore is offline
The Following User Says Thank You to Nevermore For This Useful Post:
FT-86 SpeedFactory (01-25-2014)
Old 01-25-2014, 12:47 PM   #660
xDanger_208x
xDanger_208x's Avatar
Drives:
I'm seriously considering ordering one of these in a catless version.
If I don't have a tracking # for my items from JDL by Friday, I'll cancel and get one of these
xDanger_208x is offline
Old 01-25-2014, 05:01 PM   #661
jonbonazza
I could be mistaken, but isn't the nameless piping 2.75" OD while the perrin cat back is either 2.5" or 3" OD? If this is the case, you are probably killing any hp you would have gained by the catless header by mismatching the diameters. If I am wrong, ignore me. XD
jonbonazza is offline
Old 01-25-2014, 07:54 PM   #662
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I hope you're wrong. That'd devastate my plan.
Old 01-25-2014, 09:24 PM   #663
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
He is, check the nameless site. There is one system that is 2.75 inch, but it's not perrin or nameless.
Freeman is offline
The Following 2 Users Say Thank You to Freeman For This Useful Post:
jonbonazza (01-25-2014), Nevermore (01-25-2014)
Old 01-25-2014, 09:45 PM   #664
jonbonazza
Thanks for the correction!
Sent from my Nexus 4 using Tapatalk
Old 01-25-2014, 11:15 PM   #665
Astroboy
Astroboy's Avatar
Drives: None
What's the diameter of that catalytic converter compared to stock
Sent from my LG-D800 using Tapatalk
Astroboy is offline
Old 01-26-2014, 12:20 PM   #666
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Both are the prototype versions. Just a heads up there.
FT-86 SpeedFactory is offline
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Tylub (01-26-2014)
Old 01-26-2014, 12:24 PM   #667
xDanger_208x
Drives:
That catless piece is calling my name!
I think I just might call PayPal tomorrow and get some money back from another vendor so I can give it all to you guys
Old 01-26-2014, 12:24 PM   #668
JHarperFRS
JHarperFRS's Avatar
Drives: 2013 Scion FR-S "White Out"
Very nice, I can't wait for the UEL catted header special emails. When will you be emailing ?
Sent from my SCH-I545 using Tapatalk
JHarperFRS is offline
Old 01-26-2014, 12:25 PM   #669
nelsmar
Originally Posted by *LongFella View Post
Will you guys be able to provide any MAF data or any volume changes in air flow?
Assuming someone has a tune for an sc kit, will a new tune be needed? I'm guessing not because this is intended as a bolt on setup requiring no special tune. If that is true, then the volume changes are so miner it essentially mirrors the stock header. Thanks!
Depends on the tune. removing the front cat tends to drop EGT and allows more aggressive timing and may allow slightly adjusted cam tuning. Also if you are on a speed density tune your VE values will change due to changed efficiency of your header. It is best to speak with your tuner on the subject.
My flickr - Canibeat
Local magazine scout
nelsmar is offline
Old 01-26-2014, 12:26 PM   #670
FT-86 SpeedFactory
Originally Posted by JHarperFRS View Post
Very nice, I can't wait for the UEL catless header special emails. When will you be emailing ?
Catless one is on the website right now. 2-3 weeks before shipping is all on those.
Old 01-26-2014, 12:29 PM   #671
xDanger_208x
Drives:
Now is that 2-3 ACTUAL weeks... or 2-3 JDL weeks??
The Following 2 Users Say Thank You to xDanger_208x For This Useful Post:
husker741 (01-26-2014), R2RO (01-27-2014)
Old 01-26-2014, 12:30 PM   #672
FT-86 SpeedFactory
BTW I'm out filming interior videos of the red car right now. FT86 Catted UEL, Motiv Over Pipe, Invidia Resonated front pipe, Resonated V1.
It's definitely a unique sound. At idle you get the rumble but in the higher RPM band it smooths out. This header is only 32% unequal and someone was saying the stock header is 30% unequal so we're close there. I need to measure the borla and stock one later. The Borla is extremely unuqual which is why it rumbles all through the rev range.
shaunsweeney (01-26-2014)
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
