Old 08-28-2013, 04:51 PM   #57
Ben_G
Drives: Blue BRZ
Originally Posted by JBV88 View Post
For those that did the soft hack/update did the software itself change? How does it compare to the original? Have you had apps like aha and pandora working? I see going the Pioneer upgrade route effectively changes the AVIC-X9310BT into a AVIC-X940BT. Is the hack essentially the same file?
I couldn't get Aha or Pandora to work properly..... but I figured that mostly had to do with us being in Canada and promptly forgot all about it.... I listen only to the radio or to my SD card....
If anyone knows how, please share how I can edit the source bar on the side of the screen? I want to REMOVE Pandora/Aha and other sources I don't use.
Ben_G is offline   Reply With Quote
Old 08-29-2013, 02:15 PM   #58
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
How much of a difference will there be between the 2013 and 2014 units?
FLYFISHR is offline   Reply With Quote
Old 09-09-2013, 12:40 PM   #59
rip curl
Drives: 13 BRZ
Is the torrent file on the first post the latest firmware? I'm aware this thread is a bit old, but just got my BRZ and want to do the hack!
rip curl is offline   Reply With Quote
Old 09-11-2013, 01:28 PM   #60
DmkMedia
OctaneFix.com
Drives: '13 BRZ Sportech SWP/'07 Audi A4
im working in a subaru delearship...
we received one 2014...
the changes are only the US radio now in the canadian model and red and gray are the two new colors ....nothing else
DmkMedia is offline   Reply With Quote
Old 09-11-2013, 01:39 PM   #61
FLYFISHR
FLYFISHR's Avatar
Thanks DmkMedia
I take it that it means if we get the 2014 CND models we will be able to follow all the DIY mods that the guys have done in the US with their 2013 radio's.
Old enough to know better but young enough to do it again
Old 09-13-2013, 01:27 AM   #62
Enemies
Drives: '13 SWP Sport-Tech (Limited)
Definitely interested in updating my Maps. I've found myself using Navigation on my Android lately instead of trying to deal with the GPS in my car. I find a lot of the time the car's GPS takes me the long way, even when it comes to roads that have been there forever.
Anybody want to offer any input on whether this is the best way to do things as of now or if there is a better/safer/simpler way of doing things as of September 2013?
Also curious if you need to use updated steps when it comes to the 2014 map updates or if you can still follow these steps completely and just switch to the newer downloaded navigation files and still have it work great?
Enemies is offline   Reply With Quote
Old 10-27-2013, 05:41 PM   #63
rip curl
Drives: 13 BRZ
Originally Posted by 8987846 View Post
Step 3: Backup the new version of the navi as in Step 1, save it to a safe place. From you backup, create a copy of “navi.exe” in x:\......\mybackup\PRG0\Apl\
Not sure how many people have ran into this, but the navi.exe file I had to edit was located in x:\......\mybackup\PRG1\Apl\
Otherwise, I successfully updated my Nav Software! Only issue I'm having is getting the bluetooth to connect properly, but I suspect its a phone compatibility issue (I'm trying to connect with a Samsung Galaxy S2).
Old 10-28-2013, 12:47 AM   #64
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Originally Posted by Walla Walla View Post
i completed the wiring harness trick to play video while driving, and it worked really easy
i grounded the E-brake from the standard plug, and the mute wire from the plug I bought from amazon (after relocating it) and it work
there are a lot of walkthrough on the web, but maybe i can take a few picture tomorrow. it's really basic re-wiring, if I'm able to do it, anybody with two hands can!
yeah, did the same, soo much easier
ucsmfu is offline   Reply With Quote
Old 12-15-2013, 08:56 PM   #65
punkrawkpunk88
Drives: 2008 Tiburon GS Sport, 2013 BRZ WRB
Thank you so much for this tutorial! I managed to get the Pandora app going with my phone (I have a Galaxy S3 with a US proxy for the pandora app) and it is so awesome now. The album art shows up, I can rate songs, and overall it is just better in every way
punkrawkpunk88 is offline   Reply With Quote
Old 01-25-2014, 06:49 PM   #66
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Did this - worked like a charm.
Unfortunately the navi still gives totally nonsensical directions.
daiheadjai is offline   Reply With Quote
Old 03-10-2014, 01:26 AM   #67
laksman91
Drives: BRZ Sport-Tech, Evo X GSR, E92 M3
Would it be possible to upgrade to V4.600 with the 2012 Maps?
http://www.pioneerelectronics.com/St...600_NOTICE.pdf
I'm guessing that would require a different softmod
laksman91 is offline   Reply With Quote
Old 03-14-2014, 08:01 AM   #68
congee
congee's Avatar
Drives: SSM BRZ
Is there a hack to have two bluetooth devices connected at once?? Tried connecting my ipod and phone but doesn't work
congee is offline   Reply With Quote
Old 03-30-2014, 04:26 PM   #69
kolpap
Drives: 2013 SWP Subaru BRZ
"When possible, make a legal u-turn"
Interpret as,
"When possible, make illegal u-turn"
AFAIK It seems to be able to store multiple profiles, but can only actively search for one.
However, you can use your phone and ipod at the same time if you register your phone as just hands-free and the ipod as just audio. That way you can listen to your ipod's songs via bluetooth but still receive calls via the head unit.
kolpap is offline   Reply With Quote
The Following User Says Thank You to kolpap For This Useful Post:
congee (03-30-2014)
Old 03-30-2014, 07:55 PM   #70
congee
congee's Avatar
Drives: SSM BRZ
Interesting, never knew that.
Thanks
BRZ Navi in the FRS? nocurfew Electronics | Audio | NAV | Infotainment 15 11-19-2012 05:37 PM
Canadian BRZ Navi EQ settings? Burrcold CANADA 10 11-13-2012 10:49 PM
BRZ Canadian Navi (Pioneer) Ipod Issue zex Electronics | Audio | NAV | Infotainment 0 08-15-2012 09:04 PM
Adding navi to FRS Pake1 Cosmetic Modification (Interior/Exterior/Lighting) 9 06-04-2012 10:14 AM
Adding Navi to the FRS? Pake1 Electronics | Audio | NAV | Infotainment 3 06-01-2012 01:26 PM
