Old 01-24-2014, 01:21 PM   #1
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
We need to start implementing this here...
...all of a sudden I thought I was inside a Best Motoring video! After sticking a plastic container onto my windscreen with a sucker, they added one bottle’s worth of water. This would be the ultimate test in smoothness, getting around the handling course without spilling a drop. This has to probably be the hardest thing I’ve had to do in a car, I kid you not!
The water was swinging around like crazy but it never spilled over the very edge of the container. After the WTF look had cleared from my face I had lots of chances to get some practice in. Initially it was tough: I always had to keep an eye on what the water is doing and literally recalibrate my entire driving style and the way in which I used the controls. It took some time, and quite a lot of water, but I slowly began to get the hang of it. The key is about progression: smooth doesn’t mean you have to be slow, what you have to do it rethink HOW you apply your inputs and the interaction between them. Let me elaborate…
Say you want to enter a corner as fast as you can; if you just throw your car inside you will upset its balance and there goes the water, or more generally, your smoothness. You have to be decisive about the way you apply lock, progressive with how you feed it and at the same time your smoothness also needs to stretch to how you back off your brakes as you turn in. Jump off the middle pedal and you could upset the car and its momentum. Same with the throttle: smoothness is the key, maybe less so with a turbocharged engine which is a little less instant to respond, but you get the idea. Start playing with this stuff and like me, you will discover just how aggressively you can drive your car by keeping the way you interact with each of the controls smooth, and in this particular case translating to less spilled water. It was then, after practising for a bit, that it hit me – this exercise was nothing short of genius! It was like a real-time smoothness indicator
The part i like the most...
Spill some water however and time would be added. For every 10 cc of water you dropped, two seconds would be added onto your time. This really got me nervous as there was just so much to concentrate on!
Link: http://www.speedhunters.com/2014/01/...ess-is-the-key
The Following 3 Users Say Thank You to dem00n For This Useful Post:
Eric@ptuning (01-24-2014), Itsjusdame (01-26-2014), SpeedR (01-24-2014)
Old 01-24-2014, 01:23 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
WTF, cheaters, it was raining...
...or did they spill that much water?
Old 01-24-2014, 01:26 PM   #3
dem00n
dem00n's Avatar
Drives: Scion FRS
I think it stopped before they start.
I'm looking into buying one of these.
I've heard of an app that acts the same way, you put it on your windshield inside the car and it gives you a digital glass full of water, if you spill any then you're simply driving too rough. To much braking, turning, throttle, etc...
Old 01-24-2014, 02:01 PM   #4
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
I like that idea better than balancing a ball on the hood.
PoorMansRacing is offline   Reply With Quote
Old 01-24-2014, 03:15 PM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
random thoughts
1. this is awesome
2. the cup would need a rock-hard mount, the one in the photo looks like it would bob around.. maybe not a lot, but enough to matter
3. punishing in seconds for spilled water is too harsh, but i think any series could easly have a "Cup Championship" where the goal is to spill as little as possible, recordings would be made by a designated person at the end of a particpiant's run
4. this is awesome
Old 01-24-2014, 11:38 PM   #6
RCL
Drives: subaru BRZ
idk how realistic that is around a real racetrack trying to get real results where you're no penalized by spilling water. lol
RCL is offline   Reply With Quote
Old 01-25-2014, 03:26 AM   #7
Bushman7140
Drives: 2013 FRS M/T Firestorm
It's actually called "a glass of water" and it's put out by Toyota of Europe.. Haven't tested it at all,'just found it after reading your post.
Bushman7140 is offline   Reply With Quote
Old 01-25-2014, 04:08 AM   #8
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Just buy a packet of tofu, cut open the top cover, place it in a pan. set it on the back seat. dont let the water spill.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 01-25-2014, 04:08 AM   #9
fatoni
i get the concept but im sure there are tracks where the lateral transitions are more than enough to get water out of the bowl regardless of how smooth you are. just get a data logger. that way you will have tons more info while not getting kicked of the track for fluid spills
Old 01-26-2014, 10:41 AM   #10
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
i may be the only other person who gets this reference
jbailey8748 is offline   Reply With Quote
The Following 3 Users Say Thank You to jbailey8748 For This Useful Post:
BRZPDX (01-26-2014), SirBrass (01-26-2014), SubiePig (01-31-2014)
Old 01-26-2014, 04:54 PM   #11
mrk1
Drives: Sterling BRZ Ltd
I like the tofu reference. And I think this definetly a good exercise. Don't think it would translate to a track but it's just something very simple. I could see this being a blast with some friends.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-26-2014, 10:42 PM   #12
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Where on a hachi forum. In sure most people get the initial d references.
FRSfan111 is offline   Reply With Quote
Old 01-27-2014, 12:39 AM   #13
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
CSG Mike posted that here:
http://www.ft86club.com/forums/showt...t=speedhunters
Old 01-31-2014, 12:56 AM   #14
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Initial d anyone?
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
ECU: Where do I start???? chiefshayan Software Tuning 11 07-17-2013 11:42 PM
No maf no start? Silverdub Engine, Exhaust, Transmission 14 03-30-2013 11:21 AM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 04:06 PM
